Introduction
The ins and outs of replacing your trackpad control cable.
Ce dont vous avez besoin
Remove ten Phillips screws securing the lower case to the MacBook Air:
Six 2.8 mm screws
Two 3.8 mm screws
Two 5.4 mm screws
Lift the battery out of the Air.
Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Remove the two small Phillips screws securing the logic board bracket to the upper case.
Use a spudger to pry trackpad control cable connector up off the logic board.
5 autres ont terminé cette réparation.
1 commentaire de tutoriel
Hi, I was wondering if it's possible to remove the button pad on this model Air, and just install a regular trackpad like the ones in the Macbook Pro Unidbody's and up? Can someone let mek now if that is possible or do you need that click strip in order for it to function properly?
