Introduction
更换硬盘时,必须将四个定位销(用T6螺丝刀拆下)从旧硬盘换到新的。
Ce dont vous avez besoin
移除下列将 MacBook Pro 13" Unibody后壳固定的 10个 螺丝:
7个3 mm Phillips螺丝
3个13.5 mm Phillips 螺丝
要重新组装您的设备,请按照该指南并按照相反的顺序重新组装。
568 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
笑得像个300斤的孩子 nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
16 commentaires
I'd suggest using the free software "Super Duper" to clone the hard drive. It worked wonders for me and after the 2 hour clone, I was up and running in 5 minutes!
I wholeheartedly agree. Super Duper! made the task effortless.
The T6 torx screws on the side of the existing Hitachi drive fit my Crucial M500 240GB replacement perfectly. Be aware that they were originally installed into the HDD with blue Loctite, so it takes a bit of effort to break them loose.
Thanks ifixit for excellent guidance!
What do you do when your laptop doesn't read your new hard drive?
If your hard drive dosent connect. you might need to change your hard drive connect cable . The second option is that you need a strip to replace your hard drive with DVD rom.
