Introduction
此指南适用于 MacBook Pro 13” 2014年中期的固态硬盘更换或升级 。此款 MacBook Pro 由于使用了专用存储驱动器接口, 所以 不能 在没有转接卡的情况下直接使用普通的M.2固态硬盘。
在开始之前, 如果情况允许,请先 备份您现在的SSD. 然后参考以下指南 联网恢复系统 or 创建可引导的外部设备 以熟悉如何重新安装macOS到您的设备并导入原来的数据到新SSD中。
最后,在您替换原来的SSD之前,我们强烈推荐安装macOS 10.13 High Sierra (或者最新版本的macOS) 。因为大多数新SSD所需要的新版储存驱动在低于HighSierra的macOS中不存在。
拆下以下10个固定在上壳体上的螺丝
两个 2.3毫米 的梅花五角螺丝
八个 3.0毫米 的梅花五角螺丝
要重新组装您的设备,请按照本指南的相反顺序进行操作。
154 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
66 commentaires
Hello
Can you confirm that the ssd for the macbook pro mid 2014 really is replaceable?
I hear rumours that the ssd is stuck to the motherbord.
I changed the MacBook Pro 13' Mid 2014 SSD successfully from 120GB to 1000GB. Follow all the steps provided and everything will be fine.
I spoke with an apple expert at the genius bar and they said that the SSD is Soldered into the motherboard itself. Which is why I bought another MacBook pro for $1500 after mine had corrupted. Once I was informed you could change it out, I filed a complaint with Apple's Tech Support, which they did nothing about and said that their employees were uninformed.
Yes, I just replaced my MBP Mid 2014 128GB SSD with 480GB SSD. So, I can confirm it works.
Why is it necessary to disconnect the battery for the SSD replacement?
