Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
Replace the I/O board, which includes the SD card slot, the HDMI port and the right USB port.
This guide requires the removal of the heat sink. Don't forget to follow our thermal paste application guide before you reinstall your heat sink.
    • Two 2.3 mm Pentalobe screws
    • Eight 3.0 mm Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  1. Wedge your fingers between the upper case and the lower case.
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  2. The lower case is connected to the upper case with two plastic clips near its center. During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  3. If necessary, remove the plastic cover adhered to the battery contact board.
    • If necessary, remove the plastic cover adhered to the battery contact board.
  4. Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board. Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  5. Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  6. Carefully remove the rubber fan bumper from the edge of the heat sink. The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct. The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
    • Carefully remove the rubber fan bumper from the edge of the heat sink.
    • The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
  7. Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws. Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
    • Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
  8. Remove the following screws securing the heat sink to the logic board:
    • Remove the following screws securing the heat sink to the logic board:
    • One 2.7 mm T5 screw (silver)
    • Four T5 screws (black)
  9. Remove the heat sink from the laptop. When reassembling your computer, follow our thermal paste application guide to reapply the thermal paste.
  10. Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board. Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
    • Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
  11. Peel the iSight camera cable off the fan housing to fold it out of the way. Peel the iSight camera cable off the fan housing to fold it out of the way.
    • Peel the iSight camera cable off the fan housing to fold it out of the way.
  12. Use the tip of a spudger to flip the tab on the fan's ZIF connector. Carefully pull the fan cable straight out of its socket. Carefully pull the fan cable straight out of its socket.
    • Use the tip of a spudger to flip the tab on the fan's ZIF connector.
    • Carefully pull the fan cable straight out of its socket.
  13. Remove the following screws securing the fan to the upper case:
    • Remove the following screws securing the fan to the upper case:
    • One 5.0 mm T5 Torx screw
    • Two 3.6 mm T5 Torx screws
  14. Lift the end of the fan closest to the display hinge and remove the fan from the upper case. Lift the end of the fan closest to the display hinge and remove the fan from the upper case. Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
    • Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
  15. Insert the tip of a spudger under each of the antenna cables near their connectors and pry up to disconnect them from the AirPort board. The three cables are coded with black sleeves of different lengths. During reassembly: Connect the long-sleeved cable to the center socket.
    • Insert the tip of a spudger under each of the antenna cables near their connectors and pry up to disconnect them from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  16. Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket. Remove the I/O board cable bracket.
    • Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket.
    • Remove the I/O board cable bracket.
  17. Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the I/O board. Be careful to only pry up on the cable connector, not on the socket itself or you risk damaging your I/O board. Push the I/O board cable up to bend it out of the way.
    • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the I/O board.
    • Be careful to only pry up on the cable connector, not on the socket itself or you risk damaging your I/O board.
    • Push the I/O board cable up to bend it out of the way.
  18. Use the tip of a spudger to push on either side of the I/O board connector to walk it out of its socket on the logic board. Use the tip of a spudger to push on either side of the I/O board connector to walk it out of its socket on the logic board.
    • Use the tip of a spudger to push on either side of the I/O board connector to walk it out of its socket on the logic board.
  19. Remove the following screws securing the I/O board to the upper case:
    • Remove the following screws securing the I/O board to the upper case:
    • One 3.5 mm T8 Torx standoff screw
    • One 3.5 mm T5 Torx screw
  20. Lift the I/O board cable end of the I/O board and pull toward the logic board to free the ports from the upper case. Remove the I/O board. Remove the I/O board.
    • Lift the I/O board cable end of the I/O board and pull toward the logic board to free the ports from the upper case.
    • Remove the I/O board.
  21. Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
    • Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
  22. Lift the free end of the AirPort board up slightly and pull it straight out of its socket on the I/O board. Lift the free end of the AirPort board up slightly and pull it straight out of its socket on the I/O board. Lift the free end of the AirPort board up slightly and pull it straight out of its socket on the I/O board.
    • Lift the free end of the AirPort board up slightly and pull it straight out of its socket on the I/O board.
20 autre(s) ont terminé cette réparation.
Andrew Optimus Goldheart
Membre depuis le 17/10/2009
433 627 Réputation
411 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
108 membres
9 919 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 8
7 derniers jours : 65
30 derniers jours : 257
Total : 13,567
