Aller au contenu principal
MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement, Trackpad Cable: étape 1, image 1 de 2 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement, Trackpad Cable: étape 1, image 2 de 2
    • Use the flat end of a spudger to pop the trackpad connector straight up off its socket on the logic board.
  2. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: étape 2, image 1 de 2 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: étape 2, image 2 de 2
    • Lift the trackpad cable up off the battery to separate it from the adhesive securing it.
    • Be careful not to damage the cable. If it doesn't peel up easily, apply a little heat from an iOpener, heat gun, or hair dryer to soften the adhesive, and try again.
    • If you are installing a new trackpad cable, be sure to fold the new cable to match the shape of the old cable. The new cable will appear to be too long if it is not folded.
  3. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: étape 3, image 1 de 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: étape 3, image 2 de 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: étape 3, image 3 de 3
    • If necessary, peel back any tape covering the trackpad cable connector.
    • Use the end of a spudger to flip the retaining tab on the ZIF connector.
  4. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: étape 4, image 1 de 2 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: étape 4, image 2 de 2
    • Pull the trackpad cable straight out of its ZIF socket on the trackpad control board.
    • During reassembly, make sure that the retaining tab is in the up, "unlocked" position before you insert the cable into the socket.
  5. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: étape 5, image 1 de 1
    • Remove the single 3.7 mm T5 Torx screw securing the battery board to the upper case.
3 autres ont terminé cette réparation.
Sam Goldheart
Membre depuis le 10/18/12
465 870 Réputation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
17 243 tutoriels rédigés
3 commentaires
Why remove the screw in step 5?
Ari Cooper - Davis - Réponse
Yes @sam , why should you remove the screw in step 5? Is this a mistake?
lmdehaas - Réponse
Step 5: Remove the single 3.7 mm T5 Torx screw.
Step 6: Re-screw single 3.7 mm T5 Torx screw.
David Grabowski - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 13
Total : 1,795
