Aller au contenu principal
MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement, Battery Connector: étape 1, image 1 de 1
    • Remove the plastic cover adhered to the battery contact board.
  2. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: étape 2, image 1 de 1
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  3. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: étape 3, image 1 de 2 MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  4. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: étape 4, image 1 de 1
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  5. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: étape 5, image 1 de 2 MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: étape 5, image 2 de 2
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 264
