Introduction
Tutoriel préalable
Ce dont vous avez besoin
Retirez le cache en plastique couvrant la carte de contact de la batterie.
À l'aide d'une pincette, retirez le petit cache en plastique placé en bas à droite de la carte du connecteur de batterie.
when doing this with metal tweezers as instructed in the video, it was difficult to get off and apparently while i was trying to do it, the tweezers went too far under and i believe made contact with the screw underneath? there was a zzz noise, an orange flicker and a little stream of smoke that came out. i freaked out and put everything back together to see if the laptop even still worked, it turned on and everything but died right away (i drained it before doing the repair anyway, so i was surprised it turned on at all).
i finished the battery repair and did several other things while in there. i have charged it all the way as recommended and will use it later on to see how everything is, im hoping that it’s a okay, but could someone explain to me what happened and the possible consequences?
Pour remonter votre ordinateur, suivez ces instructions en sens inverse.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
The replacement cover doesn't seem to have the formed pads attached. I re-installed the original.
Adrien - Réponse
