Aller au contenu principal
MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy)
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy), Lower Case: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    J'achète
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    If don’t have one of those neat project mats, then you can use small pieces of flattened blu-tack to hold the screws. If you arrange them in the shape of your mac book cover, and put the screws down methodically, you can get a one-to-one mapping of the screws to the correct screw holes.
    Toby Thurston - Réponse
    Or you can use an ice tray where you put the screws and the parts in separate bays in the same order as they come in the instructions.
    timofej.se -
    This is great! I used a small magnetic white board, and wrote on it to identify the parts as I went. This whole process, from the fast shipment to the great instructions to the complete, high quality, tool kit has been great. I’m typing this comment on my resurrected laptop. Thank you! Sue
    Susan Greer - Réponse
    It would be a good idea if people recorded in the comments which screws go where so that, if someone lost their screw positions, they could recover them from the comments.
    Raymond Shpeley - Réponse
  2. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 2, image 1 de 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 3, image 1 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 3, image 2 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 3, image 3 de 3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  4. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy), Battery Connector: étape 4, image 1 de 1
    • Remove the plastic cover adhered to the battery contact board.
    The replacement cover doesn't seem to have the formed pads attached. I re-installed the original.
    Adrien - Réponse
  5. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 5, image 1 de 1
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  6. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 6, image 1 de 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 6, image 2 de 2
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
    Is adhered to screw beneath, so lift firmly and slowly.
    Andrew - Réponse
    when doing this with metal tweezers as instructed in the video, it was difficult to get off and apparently while i was trying to do it, the tweezers went too far under and i believe made contact with the screw underneath? there was a zzz noise, an orange flicker and a little stream of smoke that came out. i freaked out and put everything back together to see if the laptop even still worked, it turned on and everything but died right away (i drained it before doing the repair anyway, so i was surprised it turned on at all).
    i finished the battery repair and did several other things while in there. i have charged it all the way as recommended and will use it later on to see how everything is, im hoping that it’s a okay, but could someone explain to me what happened and the possible consequences?
    Kait D - Réponse
  7. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 7, image 1 de 1
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
    When reinstalling, be careful that the board lines up correctly and is completely seated in order for this screw to thread properly.
    Adrien - Réponse
  8. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 8, image 1 de 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 8, image 2 de 2
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  9. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy), Battery Contact Board: étape 9, image 1 de 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy), Battery Contact Board: étape 9, image 2 de 2
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
    How can I remove interposer I m not able to remove it
    Raunak - Réponse
    you must lift it absolutely vertically, or it fouls against the locator pin in the corner- you can easily get the impression that it won’t come over the end of this pin- almost like it’s rivetted in. it isn’t. get a good grip on it with the tweezers in the centre hole & one of the sides, & lift it STRAIGHT up.
    duncan rmi -
    I would recommend to use plastic tweezers in order to reduce risk of damage.
    Martin Sippel - Réponse
    Second that. If you have thin heat shrink tubing, form some over the tweezer tips. If the tubing is thin and small enough in diameter you’ll see the serrations of the tweezer tips.
    Raymond Shpeley -
    wat is the model this SSD
    thierry.wilow - Réponse
  10. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy), I/O Board Data Cable: étape 10, image 1 de 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy), I/O Board Data Cable: étape 10, image 2 de 2
    • Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
    • When prying the I/O board data cable connector from its socket, make sure to pry the connector itself and not the socket. Prying the socket may cause irreversible damage to the I/O board.
    I keep my fingernails fairly long, very handy for many computer repair jobs. This gives me 10 spudgers over which I have very fine muscular control. It is far easier to pop some of these tiny delicate MacBook parts loose with my nails.
    Ben Myers - Réponse
    Skip this step. For an easier, lower-risk repair, go straight to step 15 and just fold the speaker out of the way.
    .A. - Réponse
  11. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 11, image 1 de 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 11, image 2 de 2
    • Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector.
    • Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
    I also skipped this step as this data cable is not compromising the exchange of battery and less interaction with connectors is less risk of damage..
    Diesen Schritt habe ich ebenfalls weggelassen, da das Datenkabel den Austausch der Batterie nicht behindert und weniger Manipulationen an Steckverbindern bedeutet ein geringeres Risiko für Beschädigungen
  12. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 12, image 1 de 1
    • Lift and remove the I/O board data cable from the MacBook Pro.
    This step is useless. Could be skipped
    Pierre S. - Réponse
  13. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy), Right Speaker: étape 13, image 1 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy), Right Speaker: étape 13, image 2 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy), Right Speaker: étape 13, image 3 de 3
    • Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board.
    • Move the SSD cable connector out of the way.
    As per my comment on step 10, this is also not required. When you remove the SSD in step 22, you can just fold it over out of the way.
    .A. - Réponse
    This step is easy enough that I’d just remove it to be out of the way. I 100% agree with your other comments though. While you’re here, might as well do step 21 and remove the drive, just takes a sec.
    maccentric -
    I also strongly recommend not to unmount the speaker plugs, just flip them out of the way, same as with the SSD drive. Makes it much less complicated and less risky. It worked perfect for me.
    Ich empfehle ebenfalls, die Platinenstecker der Lautsprecher nicht zu lösen sondern die Lautsprecher einfach, so wie das SSD-Laufwerk, einfach aus dem Weg zu legen. Das macht die Sache weniger kompliziert und weniger risikoreich. Es hat bei mir super funktioniert!
  14. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 14, image 1 de 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 14, image 2 de 2
    • Wedge the pointed end of a spudger beneath the right speaker cable connector.
    • Gently pry the right speaker cable connector up off from its socket on the logic board.
    • Be sure you are prying up on the connector, not the socket itself.
    When reassembling be careful that the right speaker wire is flush against the battery. At first, it was slightly touching the airport/bluetooth board causing wifi and bluetooth to not work after restarting.
    Stu - Réponse
  15. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 15, image 1 de 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 15, image 2 de 2
    • Use a T5 Torx driver to remove the following screws securing the right speaker to the upper case:
    • One black 6.8 mm screw
    • One silver 6.3 mm screw
    • One black 4.9 mm screw
    • The silver screw (in the corner) may be covered with a foam pad. If so, use your tweezers to peel it up and remove it.
    If you manage to misplace any screws, particularly one of the speaker retaining screws, look under the speakers - they are magnetic and great at hiding missing screws :)
    Peter Newman - Réponse
  16. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 16, image 1 de 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 16, image 2 de 2
    • Lift and remove the right speaker out of the upper case.
    • If necessary, de-route the right speaker cable from its channel in the upper case.
    For those who don’t realize it, the speakers you are removing really are the plastic corner pieces that look like they’re just there to fill the space.
    S Cockerille - Réponse
  17. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy), Left Speaker: étape 17, image 1 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy), Left Speaker: étape 17, image 2 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy), Left Speaker: étape 17, image 3 de 3
    • Use the flat end of a spudger to pry the headphone jack cable connector straight up off its socket on the logic board.
    • Gently bend the headphone jack cable to 90° up from the logic board.
    • Bending the headphone jack cable will allow you to disconnect the left speaker cable connector without having the headphone jack cable in the way.
    For an easier, lower-risk repair, skip this step and step 18 - go straight to step 19 and fold the speaker out of the way.
    .A. - Réponse
    Agreed, this is the way
    maccentric -
  18. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 18, image 1 de 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 18, image 2 de 2
    • Wedge the tip of a spudger beneath the left speaker cable connector.
    • Gently pry the left speaker cable connector up off from its socket on the logic board.
    It's easier to follow Step 19 & 20 first and then come to Step 18 (this step). Doing so will make it easier to remove that speaker connector easily holding the cable of speaker without having to use a pry tool.
    Johhnie Doe - Réponse
  19. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 19, image 1 de 1
    • Use a T5 Torx driver to remove the following screws securing the left speaker to the upper case:
    Be very careful on this step. If you aren’t you can snap the plastic on the corners where the screws go in. Remember to go slowly when spinning the screws back in, it doesn’t take gorilla torque to tighten them, just take it easy!
    Stacey Deel - Réponse
  20. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 20, image 1 de 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 20, image 2 de 2
    • Lift and remove the left speaker out of the upper case.
  21. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy), SSD Assembly: étape 21, image 1 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy), SSD Assembly: étape 21, image 2 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy), SSD Assembly: étape 21, image 3 de 3
    • Use your thumb or finger to bend the plastic spring bar on the SSD tray, freeing the two clips at the front side of the device.
    • While holding the spring bar depressed, tilt the SSD assembly up out of its cavity.
  22. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 22, image 1 de 1
    • Remove the SSD assembly from the upper case.
  23. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy), Battery: étape 23, image 1 de 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy), Battery: étape 23, image 2 de 2
    • Remove three 2.2 mm T5 Torx screws from each side of the battery (six screws total).
  24. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 24, image 1 de 1
    • The liquid adhesive remover provided in your kit can affect the antireflective coating on your MacBook Pro's display.
    • To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
  25. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 25, image 1 de 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 25, image 2 de 2
    • Now that your MacBook Pro is fully prepped, it's time to prep yourself.
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about skin irritation, put your gloves on now.
  26. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 26, image 1 de 2 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 26, image 2 de 2
    • Open your container of adhesive remover.
    • Fill the syringe included in your kit with a small amount (approximately 1-2 milliliters) of adhesive remover.
    • It's best to fill the syringe with no more than about 1-2 milliliters of adhesive remover at a time, so as to avoid accidentally applying too much.
    • Refill your syringe as needed throughout the rest of this procedure.
  27. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 27, image 1 de 1
    • Apply a small amount of adhesive remover (approximately 1 ml) evenly under the edge of the leftmost battery cell.
    • Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
  28. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 28, image 1 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 28, image 2 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 28, image 3 de 3
    Plastic Cards
    $2.99
    J'achète
    • Insert the flat edge of a spudger or plastic card underneath the leftmost battery cell.
    • Run your tool along the bottom perimeter of the battery cell and lift to begin separating the adhesive.
  29. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 29, image 1 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 29, image 2 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 29, image 3 de 3
    • Insert the spudger along the left-hand side of the leftmost battery cell.
    • Run the spudger up along the left side of the leftmost battery cell.
    • Slightly pry the leftmost battery cell to release it from the adhesive.
  30. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 30, image 1 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 30, image 2 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 30, image 3 de 3
    • Repeat the above steps to separate the adjacent battery cell from its adhesive:
    • Apply a small amount (about 1 ml) of liquid adhesive remover under the battery cell.
    • Wait 2-3 minutes for the adhesive remover to penetrate and soften the adhesive.
    • Carefully wedge a spudger or plastic card inwards, being careful to not damage the battery, and separate the battery cell from the adhesive securing it to your MacBook Pro.
  31. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 31, image 1 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 31, image 2 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 31, image 3 de 3
    • Insert the flat end of a spudger underneath the larger leftmost battery cell.
    • Carefully wedge the spudger inwards, being careful to not damage the battery cells.
    • Pry the larger leftmost battery cell up off the upper case.
  32. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 32, image 1 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 32, image 2 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 32, image 3 de 3
    • Grasp the battery cells and gently move (but do not remove) them from their recess in the upper case.
    • Leave the battery cells resting on top of the upper case as shown in the third picture.
  33. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 33, image 1 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 33, image 2 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 33, image 3 de 3
    • Switch sides and repeat the above procedure for the two battery cells on the right-hand side of the MacBook Pro.
    • Remember to add about 1 ml of liquid adhesive remover under each battery cell, and wait 2-3 minutes for it to penetrate before prying up the cell.
    • Be careful not to puncture or otherwise damage the battery cells.
  34. MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 34, image 1 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 34, image 2 de 3 MacBook Pro 13" Retina Display Late 2012 Battery Replacement (Legacy): étape 34, image 3 de 3
    • Lift the battery as a whole up out of the upper case, and remove the battery.
    • Before installing a new battery, remove all the old adhesive from the MacBook Pro's case.
    • With a little luck, you can slowly pull out each strip of adhesive with your fingers.
    • Otherwise, soak each section of adhesive with a bit of adhesive remover for 2-3 minutes, and then scrape it out with an opening pick or one of the other tools in your kit. This can take quite a bit of work, so be patient.
    • Mop up any remaining adhesive remover and give your MacBook Pro a few minutes to air dry.
    • The replacement battery included in your iFixit kit comes with adhesive pre-installed. Test the battery's fit and alignment carefully before peeling off the film covering the adhesive, and then press each cell firmly into place. If any additional films/liners are present that weren't on your original battery, remove them now.
    • Calibrate your new battery before using it: allow it to drain overnight, then charge it to 100% and drain it again until your MacBook Pro shuts down automatically. Charge it again and use it normally.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook Pro's SMC.
2 autres ont terminé cette réparation.
Un commentaire
Step 14 and Step 18 (disconnecting the speakers) are not really useful. But there should be a reason I didn’t catch for these steps. Thank you by the way, it was really clear and it worked perfectly!
Aslam CADER - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 629
