Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Prereq for logic board.
Pièces
Aucune pièce spécifiée.
  1. Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board. When prying the I/O board data cable connector from its socket, make sure to pry the connector itself and not the socket. Prying the socket may cause irreversible damage to the I/O board.
    • Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
    • When prying the I/O board data cable connector from its socket, make sure to pry the connector itself and not the socket. Prying the socket may cause irreversible damage to the I/O board.
  2. Kits pour Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector. Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
    • Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector.
    • Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
  4. Lift and remove the I/O board data cable from the MacBook Pro.
    • Lift and remove the I/O board data cable from the MacBook Pro.
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 15
