Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
Prereq only for upper case.
Pièces
Aucune pièce spécifiée.
  1. For this step, it is recommended to use a heat gun or hair dryer to soften the adhesive securing the microphone assembly to the upper case. You may be able to remove it without doing so, but will risk damaging the microphone cable.
    • For this step, it is recommended to use a heat gun or hair dryer to soften the adhesive securing the microphone assembly to the upper case. You may be able to remove it without doing so, but will risk damaging the microphone cable.
    • With the heat gun set to low, heat the microphone assembly to loosen the adhesive attaching it to the upper case.
    • Be very careful not to overheat the microphones or upper case. Keep in mind that the plastic keyboard is on the other side—too much heat in a single place can melt keys.
  2. Use the tip of a spudger to remove the piece of tape covering one of two microphones. Grasp the piece of tape with a pair of tweezers and remove it. Grasp the piece of tape with a pair of tweezers and remove it.
    • Use the tip of a spudger to remove the piece of tape covering one of two microphones.
    • Grasp the piece of tape with a pair of tweezers and remove it.
  3. Repeat the same procedure as the previous step to remove the tape covering the second microphone. Repeat the same procedure as the previous step to remove the tape covering the second microphone. Repeat the same procedure as the previous step to remove the tape covering the second microphone.
    • Repeat the same procedure as the previous step to remove the tape covering the second microphone.
  4. Wedge the tip of a spudger underneath the microphone assembly cable. Run the spudger up along the bottom of the microphone assembly cable to separate it from the upper case. Run the spudger up along the bottom of the microphone assembly cable to separate it from the upper case.
    • Wedge the tip of a spudger underneath the microphone assembly cable.
    • Run the spudger up along the bottom of the microphone assembly cable to separate it from the upper case.
  5. Gently wedge the tip of a spudger underneath the second microphone and push inwards to loosen the adhesive. At this point the second microphone should be completely detached from the upper case.
    • Gently wedge the tip of a spudger underneath the second microphone and push inwards to loosen the adhesive.
    • At this point the second microphone should be completely detached from the upper case.
  6. Carefully pry the first microphone up off the upper case. Carefully pry the first microphone up off the upper case.
    • Carefully pry the first microphone up off the upper case.
  7. Lift and remove the microphone assembly out of the upper case.
    • Lift and remove the microphone assembly out of the upper case.
Andrew Optimus Goldheart
Membre depuis le 17/10/2009
458 440 Réputation
410 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
129 membres
12 958 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 84
