Introduction
Utilisez ce guide pour remplacer la carte AirPort.
Ôtez les dix vis suivantes, fixant le boîtier inférieur au boîtier supérieur :
  • Ôtez les dix vis suivantes, fixant le boîtier inférieur au boîtier supérieur :
    • Deux vis Pentalobe de 2,3 mm
    • Huit vis Pentalobe de 3,0 mm
For all the screws you use the P5 pentalobe screwdriver?
Carlos - Réponse
Pentalobe is only for the screws on the bottom cover. The Torx screw driver is for the remainder.
Fredrik -
Is the Pentalobe screwdriver mentioned in the tools list? I did not have one so I used a filed down flat blade screwdriver. Not a fantastic idea, but it works.
Alex Birkett - Réponse
Yes, it's mentioned on the top of this page. P5 Pentalobe to be precise. I didn't have one either, so I bought one from iFixit and that works fantastic. An absolutely precise fit, which is important especially when you might open your MacBook a couple of times during the years you own it. Not using the correct tool might do more harm to the screws than you want! I once had this with a Lenovo Yoga 3 Pro, which has Torx screws (T4 I think) and I used cheap Chinese quality tools, with the result that both the tool and one of the screws are damaged.
addvariety -
the macbook in the picture is 2012. does it has the same structure as 2013?
Edison - Réponse
I never, ever, ever considered using anything but the correct tool on the Pentalobe screws. Too easy to strip and void your warranty (if still in effect), as well as make it almost impossible to get inside later for another upgrade or repair. The Wiha P5 Pentalobe screwdriver fits like a glove and costs only about $11 (a fraction of your drive's price)at Amazon.com. Get it!
marketing - Réponse
is P5 supposed to be for all 10 screws? it works on the 2x 2.3mm at the top, but not for the 8x others for me. what size screwdriver for the 3mm? thanks
monsieurescargot - Réponse
Yes, the p5 works for all 10 pentalobe screw heads for bottom cover. The the different size mm reference only refers to the difference in length of the screws, but again both heads are p5.
Antoine Thornton - Réponse
Mettez vos doigts entre le boîtier inférieur et le boîtier supérieur.
  • Mettez vos doigts entre le boîtier inférieur et le boîtier supérieur.
  • Séparez avec précaution les deux boîtiers et retirez le boîtier inférieur.
Ajouter un commentaire
  • Le boîtier inférieur est connecté au boîtier supérieur par deux attaches en plastique au milieu.
  • Lors du remontage, appuyez doucement sur le milieu du boîtier inférieur pour que les deux attaches s'enclenchent à nouveau.
There are two screws that are shorter-they go to the back near the vent.
wrbandllm - Réponse
This was already mentioned at the start, it says 2x 2.3mm screws and those are coloured red instead of orange for the other ones in iFixit's image.
addvariety - Réponse
What is the black vinyl-y sticker on the inside of the case (some sort of shield?). I was forced to slightly puncture it in order to replace the feet on my laptop. Thanks in advance.
Tommy Huang - Réponse
  • Si nécessaire, retirez le cache en plastique couvrant la carte de contact de la batterie.
Do you know where I can purchase this plastic cover? Mine is missing and no one will work on my computer without it.
jodieabc - Réponse
There is no point on going near the battery or logic board. I cut out these steps with no issue. It is precautionary but unnecessary.
Jaime Leonard - Réponse
  • Avec l'extrémité plate d'une spatule (spudger), tirez le connecteur de la batterie tout droit hors de sa prise sur la carte mère.
  • Assurez-vous de faire levier uniquement sur le connecteur et non pas sur sa prise, sinon vous risquez d'endommager irréversiblement la carte mère.
I have a friends MacBook Pro that has some water damage that caused the MacBook not to be able to use battery power, but still work when plugged into A/C. Upon further inspection I can see visible corrosion on a few of the 9 cables going from the battery connector to that small circuit board. Is it possible to just replace that circuit board?
jramsey21 - Réponse
I have the some problem. I was thinking to replace the whole battery but I am not it will solve the problem. Any suggestions?
salvatorebarbera -
Sometimes it can be enough to just clean the contacts without having to replace the entire board. Dosent work for complicated IC's like plcc type, where corrosion is underneath the chip. Here you will have to reheat and reapply the IC.
andrehedegaard -
Have either of you replaced the battery and/or circuit board to fix the MacBooks with the water damage ? I have the same problem with the MacBook working fine when connected to power but dying immediately when the power cord is removed.
Steve - Réponse
Hi, Steve. I had the same problem: Macbook Pro 15 retina with coffee damage. And it worked fine when connected to power. I made it working after replacing the whole battery. It seems that circuit connected to the battery becomes disabled to prevent short circuit.
Vadim Gribanov -
When placing the battery connector back into the socket on the logic board, check that every part of connector is pressed down. You should hear a soft click when it's back in place.
Ethan Tarquin - Réponse
Thanks for the comment. My MBP isn’t powering on after I walked through these steps, and I assume it is because the battery connector isn’t fully connected. (I can’t check yet since I borrowed the pentalobe screwdriver)
Caleb Steinborn -
+1
I thought I made sure it was connected but when running the computer it only detected the battery but couldn’t power it. I had to run with power adapter. Also it didn’t charge. I guess some pins were connected but not all. To verify that all were connected I removed the plastic cover, placed it carefully completely flat, and then reattached the plastic cover. After that it worked!
Jonas Ehrs -
If I only want to replace the trackpad cable, then which steps should I skip? This step seems unnecessary
Parth Gudhka - Réponse
  • Pliez le connecteur de la batterie vers le haut afin d'éviter tout contact accidentel avec la prise pendant la réparation.
If you miss or let this step for later like I did, the power left in the battery even though the computer is completely shut down, will screw up the I/O board cable like I did. I noticed this after I put all the pieces back, turn the computer on and surprise, no wifi hardware is detected. -.-
sebasgaes - Réponse
I put a small piece of blue painters tape on the battery connector contacts to prevent it from accidentally making a connection and shorting. This helped keep things a bit more protected.
LaymanLab - Réponse
That’s a great idea!
David Lilliebridge - Réponse
I used a small piece of paper to prevent the connector from connecting, no need to wrestle with even low-stick adhesive.
dbrick - Réponse
  • Passez le bout de la spatule (spduger) en dessous de chaque câble d'antennes afin de les déconnecter de la carte AirPort.
  • Ces trois câbles sont identifiables grâces aux manchons de longueur différentes. Durant le ré-assemblage :
    • Connectez le câble avec le long manchon au connecteur du milieu.
    • Connectez le câble avec le petit manchon à côté de la vis.
    • Le câble restant n'a pas de manchon et se connecte sur le connecteur restant, c'est à dire celui à côté du ventilateur.
  • Ôtez la seule vis Torx T5 de 2,7 mm fixant la carte Airport à la carte mère.
  • Soulevez un peu l'extrémité libre de la carte AirPort, ensuite tirez-la tout droit hors de sa prise sur la carte mère.
Pour remonter votre appareil, suivez les instructions dans le sens opposé.
9 autre(s) ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Sam Lionheart
Membre depuis le 18/10/2012
333 484 Réputation
534 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
107 membres
6 510 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 9
7 derniers jours : 53
30 derniers jours : 221
Total : 9,652
