Introduction
Utilisez ce tutoriel pour remplacer l'écran Retina, qui comprend la vitre et l'ensemble caméra iSight.
Ôtez les dix vis suivantes, fixant le boîtier inférieur au boîtier supérieur :
  • Ôtez les dix vis suivantes, fixant le boîtier inférieur au boîtier supérieur :
    • Deux vis Pentalobe de 2,3 mm
    • Huit vis Pentalobe de 3,0 mm
For all the screws you use the P5 pentalobe screwdriver?
Carlos - Réponse
Pentalobe is only for the screws on the bottom cover. The Torx screw driver is for the remainder.
Fredrik -
Is the Pentalobe screwdriver mentioned in the tools list? I did not have one so I used a filed down flat blade screwdriver. Not a fantastic idea, but it works.
Alex Birkett - Réponse
Yes, it's mentioned on the top of this page. P5 Pentalobe to be precise. I didn't have one either, so I bought one from iFixit and that works fantastic. An absolutely precise fit, which is important especially when you might open your MacBook a couple of times during the years you own it. Not using the correct tool might do more harm to the screws than you want! I once had this with a Lenovo Yoga 3 Pro, which has Torx screws (T4 I think) and I used cheap Chinese quality tools, with the result that both the tool and one of the screws are damaged.
addvariety -
the macbook in the picture is 2012. does it has the same structure as 2013?
Edison - Réponse
I never, ever, ever considered using anything but the correct tool on the Pentalobe screws. Too easy to strip and void your warranty (if still in effect), as well as make it almost impossible to get inside later for another upgrade or repair. The Wiha P5 Pentalobe screwdriver fits like a glove and costs only about $11 (a fraction of your drive's price)at Amazon.com. Get it!
marketing - Réponse
is P5 supposed to be for all 10 screws? it works on the 2x 2.3mm at the top, but not for the 8x others for me. what size screwdriver for the 3mm? thanks
monsieurescargot - Réponse
Yes, the p5 works for all 10 pentalobe screw heads for bottom cover. The the different size mm reference only refers to the difference in length of the screws, but again both heads are p5.
Antoine Thornton - Réponse
Mettez vos doigts entre le boîtier inférieur et le boîtier supérieur.
  • Mettez vos doigts entre le boîtier inférieur et le boîtier supérieur.
  • Séparez avec précaution les deux boîtiers et retirez le boîtier inférieur.
Ajouter un commentaire
  • Le boîtier inférieur est connecté au boîtier supérieur par deux attaches en plastique au milieu.
  • Lors du remontage, appuyez doucement sur le milieu du boîtier inférieur pour que les deux attaches s'enclenchent à nouveau.
There are two screws that are shorter-they go to the back near the vent.
wrbandllm - Réponse
This was already mentioned at the start, it says 2x 2.3mm screws and those are coloured red instead of orange for the other ones in iFixit's image.
addvariety - Réponse
What is the black vinyl-y sticker on the inside of the case (some sort of shield?). I was forced to slightly puncture it in order to replace the feet on my laptop. Thanks in advance.
Tommy Huang - Réponse
  • Si nécessaire, retirez le cache en plastique couvrant la carte de contact de la batterie.
Do you know where I can purchase this plastic cover? Mine is missing and no one will work on my computer without it.
jodieabc - Réponse
There is no point on going near the battery or logic board. I cut out these steps with no issue. It is precautionary but unnecessary.
Jaime Leonard - Réponse
  • Avec l'extrémité plate d'une spatule (spudger), tirez le connecteur de la batterie tout droit hors de sa prise sur la carte mère.
  • Assurez-vous de faire levier uniquement sur le connecteur et non pas sur sa prise, sinon vous risquez d'endommager irréversiblement la carte mère.
I have a friends MacBook Pro that has some water damage that caused the MacBook not to be able to use battery power, but still work when plugged into A/C. Upon further inspection I can see visible corrosion on a few of the 9 cables going from the battery connector to that small circuit board. Is it possible to just replace that circuit board?
jramsey21 - Réponse
I have the some problem. I was thinking to replace the whole battery but I am not it will solve the problem. Any suggestions?
salvatorebarbera -
Sometimes it can be enough to just clean the contacts without having to replace the entire board. Dosent work for complicated IC's like plcc type, where corrosion is underneath the chip. Here you will have to reheat and reapply the IC.
andrehedegaard -
Have either of you replaced the battery and/or circuit board to fix the MacBooks with the water damage ? I have the same problem with the MacBook working fine when connected to power but dying immediately when the power cord is removed.
Steve - Réponse
Hi, Steve. I had the same problem: Macbook Pro 15 retina with coffee damage. And it worked fine when connected to power. I made it working after replacing the whole battery. It seems that circuit connected to the battery becomes disabled to prevent short circuit.
Vadim Gribanov -
When placing the battery connector back into the socket on the logic board, check that every part of connector is pressed down. You should hear a soft click when it's back in place.
Ethan Tarquin - Réponse
Thanks for the comment. My MBP isn’t powering on after I walked through these steps, and I assume it is because the battery connector isn’t fully connected. (I can’t check yet since I borrowed the pentalobe screwdriver)
Caleb Steinborn -
+1
I thought I made sure it was connected but when running the computer it only detected the battery but couldn’t power it. I had to run with power adapter. Also it didn’t charge. I guess some pins were connected but not all. To verify that all were connected I removed the plastic cover, placed it carefully completely flat, and then reattached the plastic cover. After that it worked!
Jonas Ehrs -
If I only want to replace the trackpad cable, then which steps should I skip? This step seems unnecessary
Parth Gudhka - Réponse
  • Pliez le connecteur de la batterie vers le haut afin d'éviter tout contact accidentel avec la prise pendant la réparation.
If you miss or let this step for later like I did, the power left in the battery even though the computer is completely shut down, will screw up the I/O board cable like I did. I noticed this after I put all the pieces back, turn the computer on and surprise, no wifi hardware is detected. -.-
sebasgaes - Réponse
I put a small piece of blue painters tape on the battery connector contacts to prevent it from accidentally making a connection and shorting. This helped keep things a bit more protected.
LaymanLab - Réponse
That’s a great idea!
David Lilliebridge - Réponse
I used a small piece of paper to prevent the connector from connecting, no need to wrestle with even low-stick adhesive.
dbrick - Réponse
  • Retirez délicatement la protection en caoutchouc du bord du dissipateur de chaleur.
  • La protection s'enroulle autour du dissipateur thermique et s'insère dans les fentes du conduit de ventilateur. Lors du remontage, assurez-vous d'insérer les languettes dans les encoches du conduit.
  • Insérez la pointe d'un spudger sous chacun des câbles d'antenne près de leur connecteur et soulevez-les pour les débrancher de la carte AirPort.
  • Les trois câbles correspondent à des manchons noirs de différentes longueurs. Lors du remontage :
    • Connectez le câble au manchon long à la prise centrale.
    • Le câble au manchon court se connecte à côté de la vis.
    • Le câble restant n'a pas de manchon et se connecte à la dernière prise vide, à côté du ventilateur.
I struggled with reconnecting these, and in the process accidentally ripped the connector away from the wire. Is there anything I can do to reattached it?
Vanessa schroll - Réponse
This is most difficult and time consuming portion of this entire procedure. Make sure to lift the connectors straight up - not to damage them. The reconnection of the contacts may take several tries. USE CARE AND BE PATIENT! You will eventually get them to connect.
Darius - Réponse
does anyone have advice on what is the best tool to use for reconnecting? this is definitely the hardest step to reassembly
M N - Réponse
When reassembling, I used tweezers to line them up and the spudger to push them down.
Joshua Johnson - Réponse
thank you Joshua, this helped me get them. they do take a bit of patience but it’s worth taking your time.
Kevin Lynch -
everything else was easy... I still haven't managed to figure this step out... good luck in your repair
M N - Réponse
I got it! line the wire up; push the top part of the metal and give it firm pressure; they should snap in and connect
M N - Réponse
You'll get 'em in. Work gently. Make sure they're exactly over top the bottom pins. Press down with a flat smudger. It took me a lot of gentle work to get them in.
Kent - Réponse
I saw the sleeves on these.. and when looking at the replacement display saw they matched exactly and took the chance it was intentional. The only thing that got me.. was the bottom panel screws.. didn't know there were 3 types.. (should have known though, I mean right?! LOL Apple (rolls eyes) They could do like Samsung and use one screw for everything.. but oh no.. there is some OCD engineer that just likes SCREWING with people!
Tim - Réponse
Pro Tip: When reassembling, do not screw on the metal tab attached to these connectors (part of step 15) until after you have all 3 connected. This gives you uninhibited range of motion for the 3 wires. Go slow as other commenters have said. Start with the shortest wire first. Once all 3 are connected, screw on the metal tab with those 2 screws. Finally double check that all 3 are still connected.
D B - Réponse
  • Utilisez la pointe d'un spudger pour appuyer de chaque côté du connecteur de la nappe de la caméra iSight, pour la faire sortir de sa prise sur la carte mère.
  • Décollez la nappe de la caméra iSight du boîtier du ventilateur.
  • Prenez la languette en plastique noir pour ouvrir le connecteur de la nappe de l'écran et tirez-le tout droit hors de sa prise sur la carte mère.
  • Pendant la réinstallation, assurez-vous de remettre correctement la languette du connecteur de la nappe de l'écran.
This is pulled straight out to the side of the Macbook, not up.
nmackaron - Réponse
Thanks for adding this comment !
jrbhome - Réponse
Please use a nylon black stick to lift the lock bar up and push the connection apart reason being is the lock bar should not be pulled on and by pulling on it like shown may cause damage to the MLB/DISPLAY connection and then you’re into not just a display repair but a MLB on top of it!!!
Dutchie - Réponse
hello, im trying to do this because im experiencing a blackscreen problem. Id like to do this but my macbook looks so different than this one. Could anyone help me?
Karla Díaz - Réponse
If it doesn’t look like this, you’re looking at the wrong guide.
maccentric -
  • Retirez les caches de charnière en caoutchouc des charnières à droite et à gauche de l'écran.
  • Retirez les deux vis Torx T5 de 4,2 mm fixant les supports de charnière en aluminium de chaque côté du Macbook.
I found these to be very tight and wasnt able to move them with the ifixt screwdriver kit, i had to get a t-handle torx 9 bit to move them
harveyhalfpint - Réponse
Yes they were tight but I managed to shift them with the iFixit screwdriver set
Steven Fillingham - Réponse
This is 1 screw on each side (not 2 on each side). They are circled in red.
nmackaron - Réponse
The T5 in the set I bought from LaptopScreen.com was too big and started to strip these screws. Got an Ace Hardware brand one instead and it worked great.
Brian Hultin - Réponse
  • Utilisez une paire de pincette pour retirer les supports de charnière en aluminium des charnières à droite et à gauche de l'écran.
  • Lors du remontage, la partie verticale du support et le rail en aluminium au centre du Macbook doivent être alignés.
  • Retirez les quatre vis Torx extérieures T8 de 5,3 mm (deux de chaque côté) fixant l'écran au boîtier supérieur.
    • Certains modèles peuvent avoir des vis Torx T9 au lieu de T8.
Does these three screws are the same size? Can i mix use these screws during the installing process?
Michael Kwok - Réponse
On my model, there was a thin piece of translucent plastic covering the left-side outer screws. It peeled off easily. It must be replaced upon reassembly. When removing these two (left-side) screws, a metal assembly securing the antenna wires was released below the screws. It must be replaced before reassembling these two screws.
Ralph Begleiter - Réponse
  • Ouvrez le MacBook Pro d'un peu plus de 90 degrés et posez-le debout sur la table, comme illustré.
  • Tout en maintenant l'écran de votre main gauche, retirez la vis T8 Torx restante du support supérieur de l'écran.
  • Assurez-vous que l'écran et le boîtier supérieur sont stables et ne risquent pas de tomber, ce qui pourrait endommager chaque composant.
  • Retirez la dernière vis Torx T8 restante fixant l'écran au boîtier supérieur.
  • Saisissez le boîtier supérieur de votre main droite et tournez-le légèrement dans le sens des aiguilles d'une montre, vers le haut de l'écran de façon à séparer les supports de l'écran du bord du boîtier supérieur.
  • Faites pivoter légèrement l'écran pour l'écarter du boîtier supérieur.
  • Éloignez l'écran du boîtier supérieur, en faisant attention aux dispositifs de fixation et aux nappes, qui pourraient rester accrochés.
When replacing the display assembly with a new one, the new hinges may be very hard to move into the 90 degree position. We found it helpful to loop a paperclip into the screw hole of the hinge to facilitate pulling open the hinge.
Eric - Réponse
Yes also found the hinges to be extremely tight, could not move them with from their initial position with fingers, ended up using a pair of pliers to rotate them enough to get fingers under them
Are there any cheaper replacement screens? If so I need to know. My parents still haven't found out and I don't make a ton of money...
Haley Hildreth - Réponse
The paper clip is a great tip. I also used the spudger flat end under the hinge and the metal side of the case as leverage to push it up.
D B - Réponse
Pour réassembler votre appareil, suivez ces instructions dans l'ordre inverse.
96 autre(s) ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Sam Lionheart
Membre depuis le 18/10/2012
333 301 Réputation
534 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
107 membres
6 510 tutoriels rédigés
29 commentaires
Dear Ifixit. I just order a display from a mid2014 macbook 13 inch retina, for a friend of mine. Guys congrats. nice support and custumer services. hassle free. Thanks. These is why companies grow huge. Keep it up. I will try to put another other during the week. Thank for everything. I will post my experience with the product as soon is here.!!!!!! Go Ifixit!!!!
Carlos De Bernard - Réponse
Shipping to Sweden was super fast. The display assembly was in perfect condition and I am typing this on my repaired MacBook Pro! Whoohoo, thanks ifixit!
conradchristensen - Réponse
Thanks for the easy to follow guide! Worked perfectly on my Early 2015 MacBook Pro! Saved me so much money.
strauchler - Réponse
sorry your macbook pro is ealy 2015? I run the screen of 2014?
teofilodavid -
Great service, great list of tools required, great advice.
I completed this repair in an hour with the step by step guide. I'm a fairly mechanical guy who usually fixes his own appliances and automobiles, so this seemed simple enough up front. The guide made the entire repair straightforward and without any gaps or questions along the way.
bcarlb7 - Réponse
For an unknown reason, a small crack appeared in the bottom right corner on my macbook screen. At first colorful lines started showing up but eventually turned into a black band two inches high across the bottom and on the left side a vertical band cutting off an inch reducing my screen from a 13" to a 10.5". I chose to replace the lid assembly after research because it was the simplest, least risky, and most cost effective, even including purchasing the ifixit toolkit. And now I have the tools to fix more stuff.
This guide was very easy to follow forward through disassembly and back through the assembly. Thank you for additional notes for assembly. The pictures and directions made this very easy to execute and prevent causing more damage.
Thank you,
Bryan McIntyre - Réponse
Ordered a screen and tools, received them in the Netherlands in only 2 days. Excellent!
Completed this repair, within 50 mins. Guide was very clear. Battery did not need removal. Two minor issues... despite buying the more expensive A quality screen, there is visible and drop damage on the corner of the outside cover.
Secondly, one of the WiFi antenna wires had been removed slightly uncarefully, meaning that it required some finessing before it could be fitted to the WiFi board antenna connector.
Peter van Es - Réponse
Thanks for the comment Peter! We have passed your comment along to the iFixit Customer Support Team. An iFixit representative will be reaching out to you shortly regarding the issue. If you need to contact our support team in the future, you may reach them here: help.ifixit.com
Christopher Fernandes -
Hi, I just bought a used MacBook Pro on eBay, which is in perfect condition apart from 3 small chips in the display, which considering that the machines main use is photography, they can make pixel level image adjustments difficult.
I was looking into getting the used part from iFixit and am a bit confused. With the cable in the iSight camera which is glued to the fan, would there be replacement adhesive on the 'A grade' used part?
Thanks!
Henry Alekna - Réponse
With my "A-stock" display there was no adhesive on the camera cable. It wasn't a problem though, because there was some slight adhesive left on the fan shroud from the original cable I pulled off. Doesn't seem to get in the way of anything either way, just lets Apple keep things tidy.
Brandon Goranson -
Thanks Brandon, I will keep that in mind when I do the repair. Thanks for mentioning that you had scratches on an A stock part, from what I have read recently, it further supports my decision to look elsewhere for the part as the postage from America to Australia isn't cheap.
Henry Alekna -
Hi Henry,
I've read your comments and I'd like to ask you if you are considering selling the screen you'll take out of the computer?
Kalman Benics -
Hi Kalman,
Probably best not to, my one actually got knocked against the seat in front of me on a flight a few days back, and it now occasionally gets parallel lines running down the screen, which is one of the first warning signs of failure. I probably won't have the time to replace it until next month anyway, so hopefully it holds out until then.
Henry Alekna -
Guide was great, fixing my display was easy.
That said, the screws in steps 15 and 16 were T9 for me, not T8. Not great if someone buys just the tools they need, and not a kit like I did. (Kit's fantastically amazing, by the way!)
Main bummer: bought an "A-stock" display from iFixit and it has a 5 inch scratch on the back. Still works but I would have expected that to be B-stock.
Brandon Goranson - Réponse
Hi Brandon - would you please share what exactly the model of your MBP was? I'm preparing to open mine, and wondering if I should prepare a T9 instead of T8.
kwaya -
MacBook Pro (Retina, 13-inch, Mid 2014)
I don't know if yours would be the same but one thing to consider is if you don't plan on keeping the screwdriver/bit then maybe go with the T8 to be safe. It will turn the T9 screw, just not a perfect fit. I don't think it would strip it so long as you're careful. It's a pretty solid screw and torx aren't prone to stripping.
Brandon Goranson -
I followed all the steps to replace my MacBook display, but after installing the new display, when I turn on my mac the screen is all black and won't show anything. The MacBook makes the turning on sound but nothing shows. I connected an hdmi from my tv to the Mac to make sure it wasn't anything that got messed up in the process. Every came up on the tv perfectly but nothing on the screen. Could it be a cable that I didn't connect properly or is it the display that came with problem?
I purchased the screen on eBay and followed the instructions written here.
Algenis Feliz - Réponse
I would definitely crack it back open and check the connectors. Could be the display unit but it's worth checking for sure. Good luck.
Brandon Goranson -
I did, it ended up being the display that came damaged. I already returned it and ordered a new one from ifixit, just waiting for it to get in the mail.
Thanks
Algenis Feliz -
Is this P/N: 661-8153? Came from the Apple Service Center with a humongous quoted repair price. I'm looking at replacing it myself. Thanks.
goodspeed1 - Réponse
I don't know the Apple part number unfortunately, but you'll find the correct part linked at the top of the guide.
Jeff Suovanen -
I dropped and damaged the lower right corner of the display of my mid 2014 iBook pro 13 inch.The damage resulted in a malfunctioning display. I ordered the A-stock replacement and used overnight shipping. The display was packed well and arrived on time and as described, in perfect condition. I found the repair guide to be comprehensive and easy to follow. I appreciate the wonderful guides you provide and the excellent part service. Besides saving some money, I was able to get up and running within 24hrs and have the fun and satisfaction of repairing it myself!
kskinner - Réponse
Great guide had it done in 16 minutes.
John Pastor Jr - Réponse
Thank you ifixit. Just replaced the screen on my 14 year old granddaughters MacBook Pro Retina. She is going to be so happy since the screen has been cracked since November of 2016. Your instructions were very easy to follow and makes me look like a genius. (:
James Brichta - Réponse
Sam, congrats to these instructions ! You could not have done any better. Feels like magic - its so easy. And its really fun to repair things
following your excellent steps!! Thank you very much !
Oberschrauber - Réponse
Absolutely good and informative instructions.
One add-on: screws in Step 15 and 16 may be very tight to remove, need a T8 Torx screw with a large handle, or some gripping treatment to avoid slippery.
Xun - Réponse
My display was cracked but still worked. I followed these instructions to replace it and it was very simple, however the screen did not turn on. I double checked the connections and it still would not display. I thought maybe I just purchased a bad display. I reattached my old display and it will no longer turn on. Any ideas?
Gonzo Neko (KitiClub) - Réponse
I did hesitate quite longtime before I decide to give this a try because I am a complete novice and never opened a computer not even to remove dust. I finally decided because little by little I have lost too much of my screen. Well, I was afraid I wouldn’t understand some passages and I’d make some bad mistake. But the guide is so perfectly detailed, little step by little step, that it was finally even fun to do it. I was able to have my mac on the run again in about 35 minutes. So cool. Thanks a lot guys!
alemari - Réponse
Fantastic instructions. Very well done. One suggestion: a compressed air canister for dust removal.
David Carlson - Réponse
Voir les statistiques:
Dernières 24 heures : 48
7 derniers jours : 394
30 derniers jours : 1,791
Total : 71,413
