Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MacBook Pro 13" Retina Display Mid 2014 Keyboard Replacement
Ce dont vous avez besoin
    1. MacBook Pro 13" Retina Display Mid 2014 Keyboard Replacement, Preperation: étape 1, image 1 de 1
      • Before we begin it is advised to carefully read through the whole guide to get the full idea on the processes involved.
      • We begin at the stage where the top case with all its components safely removed, except for the backlight and keyboard. We can now begin the process to remove them, install a new keyboard & if necessary a new backlight.
      Demander à FixBot
      Ajouter un commentaire
    2. MacBook Pro 13" Retina Display Mid 2014 Keyboard Replacement, Removing the backlight: étape 2, image 1 de 3 MacBook Pro 13" Retina Display Mid 2014 Keyboard Replacement, Removing the backlight: étape 2, image 2 de 3 MacBook Pro 13" Retina Display Mid 2014 Keyboard Replacement, Removing the backlight: étape 2, image 3 de 3
      • We have to remove the backlight carefully as not to damage it, if you are replacing this component then you can simply pull it off.
      • The backlight consists of 3 layers, the very fragile backlight covering, a clear plastic layer and a very fragile keyboard layout template. We DO NOT want to damage these in any way if we are to use them again, so ultimate care is needed. They are stuck together but with plenty of care they can be separated.
      • Using a sharp small craft knife or similar, very carefully lift up the surrounding edge of the backlight by running the blade underneath where the adhesive is located, as we do not want to tear this extremely fragile component.
      • Some may suggest to use a heat gun but this will more than likely deform the backlight from the heat, rendering it useless.
      • Once we have a fair sized area lifted we can very gently pull away the backlight using extra care not to tear it. We can use the strength of the middle plastic sheet to assist in lifting it away. Once removed put it to the side as it will be used again in a later stage.
      • We can gently brush or wipe off any stains or debris that may have built up over time using a soft brush or cloth with some alcohol making the part nice and clean ready for re-installation.
      Demander à FixBot
    3. MacBook Pro 13" Retina Display Mid 2014 Keyboard Replacement, Remove the 4 screws: étape 3, image 1 de 1
      • There are 4 small Phillips 00 screws, these need to be removed. Three are located by the track pad, and one more on the right side of the case.
      • * Some models do not have any screws and are solely riveted down.
      Demander à FixBot
    4. MacBook Pro 13" Retina Display Mid 2014 Keyboard Replacement, Covering the keyboard: étape 4, image 1 de 1
      • Once the backlight has been removed from the case we can now proceed to cover the back of the keyboard with some masking tape, this will help to catch all the rivets that will fly off when tearing out the keyboard.
      Demander à FixBot
    5. MacBook Pro 13" Retina Display Mid 2014 Keyboard Replacement, Removing the keyboard: étape 5, image 1 de 2 MacBook Pro 13" Retina Display Mid 2014 Keyboard Replacement, Removing the keyboard: étape 5, image 2 de 2
      • Once the 4 screws have been removed and we have covered the backside of the keyboard we are ready to pull or rip it out. It is firmly riveted in. We DO NOT want to bend the top case in any way shape or form, so extra care has the be taken here.
      • We can either slowly tear the keyboard away from the case or we can literally but carefully stand on the edges to prevent the case from getting deformed or bent in the process when we tear or rip it out.
      • It is STRONGLY advised to to put on a good pair of strong thick gloves so we can first lift up the edge of the keyboard and gently bend it back enough to get a good strong grip on it. The edges of the Keyboard are VERY SHARP and will easily slice through weak materials or skin, so EXTRA CAUTION is required.
      • You can alternatively just use an old rag or a thick strong cloth to protect yourself against what can be potentially severe cuts to your fingers and knuckles when removing the keyboard'.
      • It is a good idea also to remove as many key caps as possible including their fixtures beforehand as it is always good to have some spares of these, especially if you are into repairing apple laptops or just in case your new keyboard suffers a damaged key in the future, as they will fly off everywhere when removing the keyboard.
      • You can also put a sheet of paper or plastic under the laptop to help prevent any scratches that may occur if the case moves during the big pull, a cloth or rag will allow some flex during the violent pulling away of the keyboard which can potentially disfigure the case, something we definitely need to avoid from happening.
      • Once you are set, get a TIGHT FIRM GRIP and just count to three.... 1-2-3 & RIP IT OUT in one go as fast as you can. Keys and rivets will fly everywhere so be prepared! The slower you do it the more chance there is of bending the casing or injury. Again, the edge of the keyboard is VERY SHARP and shows no mercy to hands & fingers.
      • Try not to pull upwards to much, instead pull at a level to the keyboard, as this will reduce upward stress on the case.
      Demander à FixBot
    6. MacBook Pro 13" Retina Display Mid 2014 Keyboard Replacement, Remove any remaining rivets and dirt: étape 6, image 1 de 3 MacBook Pro 13" Retina Display Mid 2014 Keyboard Replacement, Remove any remaining rivets and dirt: étape 6, image 2 de 3 MacBook Pro 13" Retina Display Mid 2014 Keyboard Replacement, Remove any remaining rivets and dirt: étape 6, image 3 de 3
      • Once we have successfully ripped out the keyboard we will have to remove all the remains from the rivets from the casing. This is not as daunting as it seems, and can take just a few minutes to complete.
      • Using a flat edged tool such as a scraper, we lay the tool as flat as we can as not to cut into the casing itself and put it to the rivets and just punch them out. It is possible to get 2 or 3 out with each hit and sometimes more. You can also use a small pliers or cutter and do them 1 by 1 but this is very time consuming.
      • You will notice that when the rivets fly out they will leave a perfectly sized hole for all the tiny screws that we must use to firmly secure the keyboard to the case.
      • Double check that ALL of the rivets have been successfully removed. A good idea is to run your finger where all the rivets once were to check everything is nice and smooth and that the holes are clean and ready to house a screw.
      • f in the worst case scenario some of the rivets have remained and have not fully popped out of their hole or have been sheered off, we may need to use a tiny thin drill bit to drill a hole, but take care to go no deeper than 1mm, otherwise we may risk drilling right through to the other side of the case.
      • It is also a good time to get a cloth and give a good clean out of the key holes on the casing as they are prone to collect dirt or debris from sticky fingers in the past.
      Demander à FixBot
    7. MacBook Pro 13" Retina Display Mid 2014 Keyboard Replacement, Installing the keyboard: étape 7, image 1 de 1
      • It is recommended to place the case on something that will raise it a little (I use the speakers to do this) that will allow the keyboard to fully drop into the slots before screwing anything down. This will make the keyboard sit comfortably and flat to the case at all times.
      • Place the new keyboard into the casing and start by screwing the screws into where the rivets once were, working from the center outward to get an even fit.
      • The screws are very small and can easily get lodged inside the keyboard, so a tip is to loosely cover the back of the keyboard with some tape or the like, gently pulling it back when you need to access the hole that is next to be screwed to into.
      • It is important to occasionally check that no keys are getting stuck when pressed. If this happens then we need to loosen all of the screws so that the keyboard can move a fraction preventing any rub on the case. This is rare as the keyboards are a precise fit. It is a good idea to check on this before too many screws have been secured.
      • Continue screwing into every position where a rivet once were to make a perfect tightly fitted keyboard that will have zero flex when you are typing on.
      Demander à FixBot
    8. MacBook Pro 13" Retina Display Mid 2014 Keyboard Replacement, Installing the backlight: étape 8, image 1 de 3 MacBook Pro 13" Retina Display Mid 2014 Keyboard Replacement, Installing the backlight: étape 8, image 2 de 3 MacBook Pro 13" Retina Display Mid 2014 Keyboard Replacement, Installing the backlight: étape 8, image 3 de 3
      • Once we are satisfied with the keyboards fit and there are no sticky keys, especially the top rows smaller function keys, as they are the ones that are most common to do so if ever, we can now prepare to install the old or a new backlight to the casing.
      • ''It is actually possible to change the color of your backlight at this stage by inserting a thin plastic covering layer between the backlight and the middle clear plastic. Any thin plastic will work well as long as they are thin enough not to absorb to much light.
      • Using the 3M tape carefully go around the edges where the old tape was leaving as less space as possible, this will help in case of any dirt, dust or worst case scenario of a water spill getting inside and onto the logic board, or at least it will help to minimize that risk.
      • A new backlight usually comes with adhesive tape preinstalled, if so there will be no need to use the 3M tape,
      • Gently put the backlight in its correct alignment and position, making sure that it is laying nicely flat and even, and then gently run your finger around the edges of the backlight pushing it down to firmly secure it to the case.
      • Once you are satisfied that everything is nice and secure, we are now ready to re-assemble the laptop. Job done.
      Demander à FixBot
Ligne d'arrivée
2 autres ont terminé cette réparation.
livfe
Membre depuis le 02/21/24
7 825 Réputation
21 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 27
30 derniers jours : 92
Total : 1,121
