Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MacBook Pro 13" Retina Display Mid 2014 Lower Case Replacement
Ce dont vous avez besoin
    1. MacBook Pro 13" Retina Display Mid 2014 Lower Case Replacement, Lower Case: étape 1, image 1 de 1
      Outil utilisé dans cette étape :
      Magnetic Project Mat
      $19.95
      • Two 2.3 mm P5 Pentalobe screws
      • Eight 3.0 mm P5 Pentalobe screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Demander à FixBot
      Ajouter un commentaire
    2. MacBook Pro 13" Retina Display Mid 2014 Lower Case Replacement: étape 2, image 1 de 1
      • Wedge your fingers between the upper case and the lower case.
      • Gently pull the lower case away from the upper case to remove it.
      Demander à FixBot
    3. MacBook Pro 13" Retina Display Mid 2014 Lower Case Replacement: étape 3, image 1 de 2 MacBook Pro 13" Retina Display Mid 2014 Lower Case Replacement: étape 3, image 2 de 2
      • The lower case is connected to the upper case with two plastic clips near its center.
      • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
      Demander à FixBot
18 autres ont terminé cette réparation.
Sam Goldheart
Membre depuis le 10/18/12
477 923 Réputation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
63 755 tutoriels rédigés
1 commentaire de tutoriel
Do i have to hear some "click" noise when reconnecting the plastic clips? I did gently push the middle of the lower case, but the clips did not reconnected (it was still easy to remove the lower case). Hence i just put screws back, and then little bit strongly push the lower case again, but there was no "click" noise eithe ... However, the bottom case is completely flat, so i suppose it is ok...
K4stan - Réponse Partager
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 19
30 derniers jours : 89
Total : 32,970
