Introduction
Utilisez ce tutoriel pour enlever ou remplacer le SSD.
Ôtez les dix vis suivantes, fixant le boîtier inférieur au boîtier supérieur :
  • Ôtez les dix vis suivantes, fixant le boîtier inférieur au boîtier supérieur :
    • Deux vis Pentalobe de 2,3 mm
    • Huit vis Pentalobe de 3,0 mm
For all the screws you use the P5 pentalobe screwdriver?
Carlos - Réponse
Pentalobe is only for the screws on the bottom cover. The Torx screw driver is for the remainder.
Fredrik -
Is the Pentalobe screwdriver mentioned in the tools list? I did not have one so I used a filed down flat blade screwdriver. Not a fantastic idea, but it works.
Alex Birkett - Réponse
Yes, it's mentioned on the top of this page. P5 Pentalobe to be precise. I didn't have one either, so I bought one from iFixit and that works fantastic. An absolutely precise fit, which is important especially when you might open your MacBook a couple of times during the years you own it. Not using the correct tool might do more harm to the screws than you want! I once had this with a Lenovo Yoga 3 Pro, which has Torx screws (T4 I think) and I used cheap Chinese quality tools, with the result that both the tool and one of the screws are damaged.
addvariety -
the macbook in the picture is 2012. does it has the same structure as 2013?
Edison - Réponse
I never, ever, ever considered using anything but the correct tool on the Pentalobe screws. Too easy to strip and void your warranty (if still in effect), as well as make it almost impossible to get inside later for another upgrade or repair. The Wiha P5 Pentalobe screwdriver fits like a glove and costs only about $11 (a fraction of your drive's price)at Amazon.com. Get it!
marketing - Réponse
is P5 supposed to be for all 10 screws? it works on the 2x 2.3mm at the top, but not for the 8x others for me. what size screwdriver for the 3mm? thanks
monsieurescargot - Réponse
Yes, the p5 works for all 10 pentalobe screw heads for bottom cover. The the different size mm reference only refers to the difference in length of the screws, but again both heads are p5.
Antoine Thornton - Réponse
Mettez vos doigts entre le boîtier inférieur et le boîtier supérieur.
  • Mettez vos doigts entre le boîtier inférieur et le boîtier supérieur.
  • Séparez avec précaution les deux boîtiers et retirez le boîtier inférieur.
Ajouter un commentaire
  • Le boîtier inférieur est connecté au boîtier supérieur par deux attaches en plastique au milieu.
  • Lors du remontage, appuyez doucement sur le milieu du boîtier inférieur pour que les deux attaches s'enclenchent à nouveau.
There are two screws that are shorter-they go to the back near the vent.
wrbandllm - Réponse
This was already mentioned at the start, it says 2x 2.3mm screws and those are coloured red instead of orange for the other ones in iFixit's image.
addvariety - Réponse
What is the black vinyl-y sticker on the inside of the case (some sort of shield?). I was forced to slightly puncture it in order to replace the feet on my laptop. Thanks in advance.
Tommy Huang - Réponse
  • Si nécessaire, retirez le cache en plastique couvrant la carte de contact de la batterie.
Do you know where I can purchase this plastic cover? Mine is missing and no one will work on my computer without it.
jodieabc - Réponse
There is no point on going near the battery or logic board. I cut out these steps with no issue. It is precautionary but unnecessary.
Jaime Leonard - Réponse
  • Avec l'extrémité plate d'une spatule (spudger), tirez le connecteur de la batterie tout droit hors de sa prise sur la carte mère.
  • Assurez-vous de faire levier uniquement sur le connecteur et non pas sur sa prise, sinon vous risquez d'endommager irréversiblement la carte mère.
I have a friends MacBook Pro that has some water damage that caused the MacBook not to be able to use battery power, but still work when plugged into A/C. Upon further inspection I can see visible corrosion on a few of the 9 cables going from the battery connector to that small circuit board. Is it possible to just replace that circuit board?
jramsey21 - Réponse
I have the some problem. I was thinking to replace the whole battery but I am not it will solve the problem. Any suggestions?
salvatorebarbera -
Sometimes it can be enough to just clean the contacts without having to replace the entire board. Dosent work for complicated IC's like plcc type, where corrosion is underneath the chip. Here you will have to reheat and reapply the IC.
andrehedegaard -
Have either of you replaced the battery and/or circuit board to fix the MacBooks with the water damage ? I have the same problem with the MacBook working fine when connected to power but dying immediately when the power cord is removed.
Steve - Réponse
Hi, Steve. I had the same problem: Macbook Pro 15 retina with coffee damage. And it worked fine when connected to power. I made it working after replacing the whole battery. It seems that circuit connected to the battery becomes disabled to prevent short circuit.
Vadim Gribanov -
When placing the battery connector back into the socket on the logic board, check that every part of connector is pressed down. You should hear a soft click when it's back in place.
Ethan Tarquin - Réponse
Thanks for the comment. My MBP isn’t powering on after I walked through these steps, and I assume it is because the battery connector isn’t fully connected. (I can’t check yet since I borrowed the pentalobe screwdriver)
Caleb Steinborn -
+1
I thought I made sure it was connected but when running the computer it only detected the battery but couldn’t power it. I had to run with power adapter. Also it didn’t charge. I guess some pins were connected but not all. To verify that all were connected I removed the plastic cover, placed it carefully completely flat, and then reattached the plastic cover. After that it worked!
Jonas Ehrs -
If I only want to replace the trackpad cable, then which steps should I skip? This step seems unnecessary
Parth Gudhka - Réponse
  • Pliez le connecteur de la batterie vers le haut afin d'éviter tout contact accidentel avec la prise pendant la réparation.
If you miss or let this step for later like I did, the power left in the battery even though the computer is completely shut down, will screw up the I/O board cable like I did. I noticed this after I put all the pieces back, turn the computer on and surprise, no wifi hardware is detected. -.-
sebasgaes - Réponse
I put a small piece of blue painters tape on the battery connector contacts to prevent it from accidentally making a connection and shorting. This helped keep things a bit more protected.
LaymanLab - Réponse
That’s a great idea!
David Lilliebridge - Réponse
I used a small piece of paper to prevent the connector from connecting, no need to wrestle with even low-stick adhesive.
dbrick - Réponse
  • Retirez la seule vis Torx T5 de 2,9mm sécurisant le SSD sur la carte mère.
In case you need it, the underside of the SSD board will indicate the size of the drive, e.g., 128GB.
Aldo Cugnini - Réponse
  • Soulevez légèrement l'extrémité libre du SSD et retirez-le de son connecteur sur la carte mère.
  • Soulevez l'extrémité du SSD juste assez pour vous permettre de le retirer - environ 1/4 ".
Transcend 960GB JetDrive 720 SATAIII 6Gb/s Solid State Drive Upgrade Kit for MacBook Pro 13" with Retina Display, Late 2012 - Early 2013 (TS960GJDM720) - Is this compatible with the Macbook Pro 13" Retina - Mid 2014?
Jess - Réponse
Según el fabricante no, me puse en contacto con ellos y dicen que estan en desarrollo. Yo ya pregunte en este foro por que otro unidad de ssd cambio la original y nadie responde...
According to the manufacturer no, I got in touch with them and say they are developing . I already ask at this forum by another unit ssd change the original and nobody answers ..
Antonio -
Manufacturers that don't say it's compatible, just haven't tested it. You just have to pay special attention to the notch(es) on the connector. I had a 512 GB SSD lying around, but it had two notches at 1/3 and 2/3 (M.2 B & M notches) instead of the MacBook's notch that's somewhat in the middle and is NOT a standard of the M.2 format.
addvariety -
No. But OWC now sells a higher capacity SSD for the 2015 MBP's
robert Seith - Réponse
Great guide!
Daniel - Réponse
Why do I need to disconnect the battery?
David DelMonte - Réponse
To prevent damage on motherboard while connecting/disconnecting SSD.
Fedor Zhuromsky -
What are your recommendations for transferring the data to the replacement flash drive?
ari - Réponse
Before changing hard drive, back up data via Time Machine. After hard drive replacement, restore Time Machine backup onto new hard drive.
William -
no other brand sad, for MacBook RD mid 2014?
iCalfixit - Réponse
Can i swap my macbook pro 13" (late 2013) 128gb ssd with macbook air 13" 512gb ssd...? Would it work like that or they don't work with this combination...?
VVK - Réponse
Yes, you can.
Oleg -
Can i use 1T ssd in macbook Retina Mf840 ??? change 256 to 512 or 1T :/
Pedram BehzadiFar - Réponse
Hey, do you know if Transcend Jetdrive 725 is compatible with a 2015 MBP 13 retina ? Thanks for your help
Leo Merazian - Réponse
Pour réassembler votre appareil, suivez ces instructions dans l'ordre inverse.
82 autre(s) ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Sam Lionheart
Membre depuis le 18/10/2012
333 116 Réputation
534 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
107 membres
6 502 tutoriels rédigés
44 commentaires
Hello
Can you confirm that the ssd for the macbook pro mid 2014 really is replaceable?
I hear rumours that the ssd is stuck to the motherbord.
Pieter Baeyens - Réponse
I changed the MacBook Pro 13' Mid 2014 SSD successfully from 120GB to 1000GB. Follow all the steps provided and everything will be fine.
Syafiq Sufi -
I spoke with an apple expert at the genius bar and they said that the SSD is Soldered into the motherboard itself. Which is why I bought another MacBook pro for $1500 after mine had corrupted. Once I was informed you could change it out, I filed a complaint with Apple's Tech Support, which they did nothing about and said that their employees were uninformed.
Joe Wilkie -
Why is it necessary to disconnect the battery for the SSD replacement?
Robert Kelly - Réponse
You always want to remove the battery and/or unplug your laptop/desktop before doing any repairs or upgrades to reduce electrical shock.
ncrimmel -
Nonsense, turn the laptop off, make sure hand/wrist are grounded, and you do not have to disconnect the battery. There is more chance of battery surge damage or connector damage then there is damage to the hard disk in a complete shut down mode. 28 years of electronic repair in all industries has taught me this.
Nic Wilson -
Of course! Disconnect any power from any device you repair!!! I just burned up a logic board of my iPhone case-battery because of accidentally shortcuts circuit with metal tweezers =( Battery was connected to board
firuz1844 - Réponse
how do you reinstall the os since there is no more the recovery partition?
Jonathan Obino - Réponse
You can make a bootable USB drive before you upgrade your SSD. I would do this with an older version of OS X (e.g. Lion), which you can afterwards upgrade to Yosemite for free. I'm sure there is also a possibility to make a Yosemite bootable, I just haven't done it before myself.
Jan -
Is it only 512 and 1TB SSD avalible in the market? No 750, 712GBs?
Bob - Réponse
May you confirm, is this model can be upgradeable i heard it cannot regards.
raymondg1992 - Réponse
Could anyone confirm whether it can be done or not?
gratain - Réponse
Is anyone else having any issue with taking the battery connector off? I just don't want to damage the connectors because it feels much more difficult to pull up then previous model Macs I've dealt with. If so, what did you do to make it easier?
isaacfinger - Réponse
NOTE! If you bought a brand new SSD you will have to initialize it. When you turn your computer on hold down option+command+R. Then, on the window that gives you the options to install OSX or use TimeMachine, or use Disk Utility. Pick Disk utility because you need to initialize the drive. Select your drive on the left side bar then select "partition" and give it a name, make sure it is "journaled" and select the number of partitions that you want. You can then click continue, or next or whatever is at the bottom. It'll take a few seconds for the partition to be completed. Lastly, go back to the window with the main options as (stated above) and select "download OSX". Then let that baby download and your home free!
Can someone confirm that this is working on the Mid 2014 rMBP 11,1
Clive Shum - Réponse
yes this worked on my 11,1. I upgraded to a 480gb I have also upgraded another to a 256gb
Ray Dunham -
Can you tell us what was the make and model of the SSD that you installed. OWC and Crucial do not have ssd upgrades for 2014 MBP.
TF - Réponse
@Syafiq Sufi just echoing TF's question — can you share where you sourced your 1TB ssd?
kev - Réponse
Would I be able to use Samsung brand SSD(MZ-V5P512BW) ???
William Cho - Réponse
Did you get an answer to this question? I also have a Mid 2014 Macbook Pro and want to put a Samsung 950 pro 512gb in it.
John Roger Bell -
I'd be glas to find a reference for a 1To SSD compatible with MID 2014 MacBook Pro 13''... any help ?
GEii Mulhouse -
¿Hola, que modelo de disco ssd de 1Tb has usado?, no lo encuentro
Hey, that model 1TB SSD used ?, you can not find it
Antonio Jesus Martin - Réponse
I understand that the SSD is user replaceable but who carries the SSDs that are compatible?
Want to change my 128-1tb.
Kevin Fung - Réponse
Lo que quiero es cambiar el ssd de 128 por uno de un 1Tb pero no encuentro modelo compatibles y estoy preguntando si conoceis la marca y modelo de alguno que si lo sea para el MacBook Pro Retina Mid 2014
What I want is to change the SSD 128 by one of a 1Tb but can not find compatible model and I'm wondering if you know the make and model of any if it is for the Mid 2014 MacBook Pro Retina
Antonio -
Does anyone know what SSDs are compatible or if there is any?
Rory Plunkett Boyle - Réponse
Can anyone please tell me the compatible 1TB SSD options available? I was considering the Mac Pro SSD since its x4 PCIe but the part is nearly $1000.
shayaansiddiqui - Réponse
Mid 2014 MBPR 2.6ghz could use this ssd
"SAMSUNG 950 PRO M.2 512GB PCI-Express 3.0 x4 Internal Solid State Drive (SSD) MZ-V5P512BW" ?
Miguel Fria - Réponse
Miguel, is that a statement or a question?!
nstjh -
Hello, I would like to change my ssd but what type of ssd you have used. Because I would like to buy one but first of all I need the type of the ssd wich one u have used?
florianoros93 - Réponse
Antonio . has conseguido la referencia de alguna otra tarjeta ssd para el macbook pro 13" mid 2014. graciaS!!!
Antonio, have you got the reference of some other sd card for macbook pro 13 "mid 2014. Thanks
Ivan - Réponse
Hi, There are plenty of different SSDs available in the Market. Can anybody tell me that which type of SSD will be suitable for my MacBookPro mid 2014. Please mention m.2 or any other, also mention some SSD models and amazon links. It will be good if I get Pro SSD models in the list. Thank you.
Raghavendra Temkar - Réponse
Does the plastic cover have to be put back when you're putting everything back together?
Ryan Ragland - Réponse
I update OWC Aura SSD on a MacBook Pro late 2013. But the SSD shows as an External disk. I wonder if there is a way we could fix this.
longstcn - Réponse
Did you figure this out? I am looking at the same drive for my Mid 2014 MBP
Bryan -
Excelente¡ todo salió bien.
Ruben Morales - Réponse
Disculpa que marca y que modelo de SDD utilizaste para hacer el cambio?
Sebastian Bonilla -
So can you install a Samsung 950 PRO NVMe drive instead ? Or not ?!
opensolr - Réponse
this is a solid question and I'd like to know too. MacOS supports NVME and there are converters to make the Samsung NVME modules physically fit/connect so now, do they work?
patrick.bos -
Hi
Sorry if this is a repeat question anyhow but can anyone tell me if the RAM for Macbook Pro 13 Retina (Mid 2014) can be upgraded from 8GB to 16GB?
Thanks
Mas Berman - Réponse
no - RAM is soldiered and not replacable
rangerek -
Hi,
looking for an adapter to replace the existing SSD with a mSATA SSD on my Macbook pro 13" retina (mid 2014). Anybody can provide details if this is possible and how to buy adapter for the A1502 model?
many thanks.
Tobi - Réponse
Yes this works people..MANY have answered this so ease quit asking. You cannot update the ram however it is definitely soldered in. If you're willing seeing simply remove the back and look at the SSD drive. If you see a simple gle screw then it's removable. Common sense…
Lane Jasper - Réponse
I have a 13” MacBookPro Retina Dual i5 2.7 Ghz computer with a 128 GB SSD drive and 8GB of RAM. Someone spilled a beer over the keyboard and it will no longer start up. Apple says the logic board needs replacing. Only then can the other parts be tested for potential damage. It’s no longer under warranty and it’s not insured. For the cost of the repairs, I can get a comparable used MBP. I need to get my data off the hard drive first. Can I remove it per the instructions above, hook it up by cable to my other Mac, and copy the files that way? My last Time Machine backup was unfortunately four weeks previous to the beer spill, and I need to access the newer files as well as the old ones. Any suggestions?
Rickfilms - Réponse
You need a (special) case for the old HD.
dmarckp -
Voir les statistiques:
Dernières 24 heures : 134
7 derniers jours : 909
30 derniers jours : 4,053
Total : 378,513
