Introduction
Use this guide to replace a broken display assembly.
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
Remove two of the three 6 mm T8 Torx screws securing the right side of the display to the upper case.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
69 autre(s) ont terminé cette réparation.
9 commentaires
Thank you Phillip for providing this Guide. I used it to replace a bad LCD assembly after a water spill damaged it. The last Step 20 is very difficult. I had the worst time trying to separate the two parts after I removed the final Torex screw. It took a while, trying different angles, but I finally got it. Putting in the new one was a trivial exercise...
Hi
I messed up on Step 6 and have broken the cable.
I was wondering how I could fix this?
I went into apple and they said they need to replace the whole display and I don't want to do that since it cost more than I can afford.
Is there a way just to replace the camera cable itself?
If so where can I buy them and how do I replace them?
Phillip, thank you so much for this excellent guide. I have no technical background at all but I found it very easy to use - and it saved me hundreds of dollars on a professional repair job. Keep up the good work!
Hi my name is Daniel, I have a MacBook Pro i5 late 2011 ..... But my display is broken..... I searched in "mercado livre" in my country Brazil and found one display for MacBook Pro early 2010.... My question is ..... Is it possible to assemble it in my computer???
