Introduction
Revitalize a worn MacBook Pro with a new set of feet.
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Remove any broken or damaged feet.
Remove any pieces from the old foot that may have broken off in the foot hole.
Use tweezers to peel up and remove the old adhesive tape from the foot pad.
Align the new foot inside the foot pad.
Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
Lay the foot down while keeping it properly aligned.
Check for proper alignment from the inside of the lower case. Use tweezers to slide the alignment nub so it lines up with the hole.
18 autre(s) ont terminé cette réparation.
Un commentaire
Fine tutorial !
I have an ecological proposal: no need of adhesive remover, an alcohol prep on a dish towel is enough to remove any remaining adhesive or residue. Less wastes !
