Aller au contenu principal
Remplacement du boîtier inférieur du MacBook Pro 13" Unibody mi-2009
Ce dont vous avez besoin
  1. Remplacement du boîtier inférieur du MacBook Pro 13" Unibody mi-2009, Retirer les vis du boîtier inférieur: étape 1, image 1 de 1
    • Retirez les 10 vis suivantes par lesquelles est fixé le boîtier inférieur du MacBook Pro 13" Unibody :
    • Sept vis Phillips 3 mm.
    • Trois vis Phillips 13,5 mm.
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    David Kilbridge - Réponse
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - Réponse
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - Réponse
    I use a magnetic mat and place the screws in order on that :)
    Cary B - Réponse
  2. Remplacement du boîtier inférieur du MacBook Pro 13" Unibody mi-2009, Soulever le boîtier inférieur: étape 2, image 1 de 1
    • Soulevez légèrement le boîtier inférieur et poussez-le vers l'arrière de l'ordinateur afin de désengager les pattes de fixation.
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - Réponse
    Long story short: I drank the AppleKoolAid back in 1984 and have always left the guts of my machines up to Apple - until recently when I needed to swap the SATAs from my original MacDaddy (2009 13" MBPro that I killed in 2018 - coffee + blackout = OOOOPS) into a pristine 2009 MBPro from a Goodwill in North Carolina through eBay. I need the files from iCal and MacMail that can't be opened in my newer machines.
    Well . . . I ain't never done nuttin' like that, before!
    Enter Luke Miani on YouTube. He raves about you guys! So, I watched everything I could, read your site, bought the right tools and at the ripe old age of 72, I sat down, this morning and did the work. Now my original MacDaddy lives in MacDaddy2.0.
    Am I allowed to cry?
    Seriously, I can't thank you enough for your bitchen site and killer tools. I wish I'd'a been turned on to this shizzle 30+ years ago.
    IFIXIT - IDIGIT!
    kath myers - Réponse
    HAHAHAHAHAHAHAHAHAHA.
    That was a brilliant read.
    Yes, I came across ifixit a few years ago. Totally helped me out on several occasions.
    Glad your Mac repair journey worked out.
    Cary B -
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
53 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Un commentaire
2 tornillos se da&aron, los q estan al lado de las lenguetas de montaje -lado de la bateria- pues la bateria se inflo y presiona la carcasa
q haces p resolver ??
enrique lopez vega - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 51
Total : 44,749
