Aller au contenu principal
Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009
Ce dont vous avez besoin
  1. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009, Retirer les vis du boîtier inférieur: étape 1, image 1 de 1
    • Retirez les 10 vis suivantes par lesquelles est fixé le boîtier inférieur du MacBook Pro 13" Unibody :
    • Sept vis Phillips 3 mm.
    • Trois vis Phillips 13,5 mm.
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    David Kilbridge - Réponse
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - Réponse
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - Réponse
    I use a magnetic mat and place the screws in order on that :)
    Cary B - Réponse
  2. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009, Soulever le boîtier inférieur: étape 2, image 1 de 1
    • Soulevez légèrement le boîtier inférieur et poussez-le vers l'arrière de l'ordinateur afin de désengager les pattes de fixation.
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - Réponse
    Long story short: I drank the AppleKoolAid back in 1984 and have always left the guts of my machines up to Apple - until recently when I needed to swap the SATAs from my original MacDaddy (2009 13" MBPro that I killed in 2018 - coffee + blackout = OOOOPS) into a pristine 2009 MBPro from a Goodwill in North Carolina through eBay. I need the files from iCal and MacMail that can't be opened in my newer machines.
    Well . . . I ain't never done nuttin' like that, before!
    Enter Luke Miani on YouTube. He raves about you guys! So, I watched everything I could, read your site, bought the right tools and at the ripe old age of 72, I sat down, this morning and did the work. Now my original MacDaddy lives in MacDaddy2.0.
    Am I allowed to cry?
    Seriously, I can't thank you enough for your bitchen site and killer tools. I wish I'd'a been turned on to this shizzle 30+ years ago.
    IFIXIT - IDIGIT!
    kath myers - Réponse
    HAHAHAHAHAHAHAHAHAHA.
    That was a brilliant read.
    Yes, I came across ifixit a few years ago. Totally helped me out on several occasions.
    Glad your Mac repair journey worked out.
    Cary B -
  3. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009, Batterie: étape 3, image 1 de 1
    • À titre de précaution, nous vous conseillons de débrancher le connecteur de la batterie de la carte mère afin d'éviter les décharges électriques.
    • À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur de la batterie pour le débrancher de la prise sur la carte mère.
    Citation de gansodesoya :
    why is step 3 necessary?
    Just to disconnect any power source to avoid damages by short-circuits.
    MrKane - Réponse
    How do you get that battery connector back on? Do you just press it in back in place after you're done?
    Horace Chung - Réponse
    yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
    maccentric -
    This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
    Jeff Diamond - Réponse
  4. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009, Ventilateur: étape 4, image 1 de 3 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009, Ventilateur: étape 4, image 2 de 3 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009, Ventilateur: étape 4, image 3 de 3
    • Avec une spatule (spudger), soulevez le connecteur du ventilateur de son emplacement pour le débrancher de sa prise sur la carte mère.
    • Il est utile de faire pivoter la spatule en dessous des câbles du ventilateur pour débrancher le connecteur.
    • La prise et le connecteur du ventilateur sont montrés sur la deuxième et troisième photo. Veillez à ne pas détacher la prise en plastique du ventilateur lors du retrait du connecteur du ventilateur de sa prise. La configuration de la carte mère de votre appareil peut différer de celle de la deuxième photo mais la prise du ventilateur est la même.
    I just soldered it back on. . . I tried to clean the pads with braid first, but it didn't do much so I don't think that's necessary. I first supper-glued it in place with the pins on the pads and then I put a tiny dab of solder on each pin/pad. Plugged in the fan and i works!
    Ron Hudson - Réponse
    Just the answer I was looking for Ron! Awesome work buddy!
    lucasjmenzie -
    i recommend not to use the spudger. you damage more than by unpluggin the plug by hand. just simply pull the cable close to the plug of the old fan softly upwards out. the plug than comes easily out. put the new fan in and push the new plug by hand in. it is much easier than using a spudger. i also started with a spudger but nearly broke the plug out, so i watched a youtube tutorial and learned about it…
    andre - Réponse
  5. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 5, image 1 de 1
    • Retirez les trois vis suivantes, fixant le ventilateur au boîtier supérieur :
    • Une vis cruciforme de 6,5 mm.
    • Une vis cruciforme de 5,5 mm.
    • Une vis cruciforme de 4,5 mm.
  6. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 6, image 1 de 1
    • Ôtez le ventilateur du boîtier supérieur.
  7. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009, Carte mère: étape 7, image 1 de 3 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009, Carte mère: étape 7, image 2 de 3 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009, Carte mère: étape 7, image 3 de 3
    • Saisissez la languette en plastique fixée au dispositif de verrouillage du câble de données de l'écran et pivotez-la vers le côté DC-In (prise d'alimentation) de l'ordinateur.
    • Tirez le câble de données de l'écran tout droit hors de sa prise sur la carte mère, vers le côté DC-In de l'ordinateur.
  8. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 8, image 1 de 2 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 8, image 2 de 2
    • Retirez les deux vis suivantes, attachant la fixation du câble de données de l'écran au boîtier supérieur :
    • Une vis cruciforme de 7 mm.
    • Une vis cruciforme de 5 mm.
    • Retirez la fixation du câble de données de l'écran du boîtier supérieur.
    Mine are Torx and got an extra clamp for the cable, just above the left screw
    Martin - Réponse
    If you only want to replace the DC-in board, stop here and GOTO 17 (and DO NOT 4 and 6).
    When the Logic board is loose, lift it up on the Harddrive end and shift slightly towards the HD, so that the USB connectors at the outside come free from under the case rim and the board can be lifted up a bit. Then there´s enough room to move the DC in board, pull the cable out with a pair of tweezers, wriggle it out from under the microphone cable and wriggle the new connector in. It can be pushed into the socket with tweezers or a small screwdriver. This worked perfect for me.
    Be careful not to bend the logic board, but otherwise I think there´s much less risk of messing anything up with all the connectors and bits and pieces that need to be loosened and fastened.
    Mike - Réponse
  9. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 9, image 1 de 1
    • Avec l'extrémité plate d'une spatule (spudger), soulevez le connecteur du subwoofer et du haut-parleur droite pour les débrancher de la carte mère.
  10. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 10, image 1 de 1
    • Dans cette étape, vous allez déconnecter la nappe de la caméra. La plupart des ordinateurs ont un petit dispositif d'attache autocollant en plastique, fixé à la carte mère pour maintenir le connecteur en place. Avant de déconnecter la nappe, assurez-vous que ce dispositif a été retiré et ne vous gêne pas.
    • Tirez la nappe de la caméra vers le lecteur optique pour la débrancher de la carte mère.
    • Cette prise métallique se tord facilement. Veillez à bien aligner le connecteur et sa prise sur la carte mère avant des réassembler.
    There is a small piece just below this connector which is just an adhesive block to keep the connector from coming out. It is easiest to peel it up first with a fingernail or spudger then remove the cable. Likewise reinsert the cable before reapplying the adhesive safety stop.
    Justin Jett - Réponse
    I couldn't reconnect this cable correctly, so my camera is not working anymore.
    It doesn't matter to me, I didn't used the camera that often...
    But the Ambient Light Sensor uses the camera to control keyboard lighting, so I wasn't able to see my keyboard in the dark anymore... :(
    If you have the same problem, after a couple of google hits I've found this app: https://www.macupdate.com/app/mac/22151/...
    Problem solved! YAY!
    PS: be careful because WIFI passes through this cable as well!!!!
    simbass - Réponse
    Look at the photo intently. The connector is inserting not in parallel, but at a slight angle. The bottom corner of the connector is slightly ahead. It is important! Singular metod to insert it.
    Vladimir -
  11. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 11, image 1 de 3 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 11, image 2 de 3 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 11, image 3 de 3
    • Avec l'extrémité plate d'une spatule (spudger), soulevez les connecteurs des nappes du lecteur optique, du disque dur et du pavé tactile pour les débrancher de la carte mère.
  12. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 12, image 1 de 3 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 12, image 2 de 3 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 12, image 3 de 3
    • Avec votre ongle ou la pointe d'une spatule, ouvrez le clapet de retenue de la prise ZIF de la nappe du clavier.
    • Avec votre spatule, faites glisser la nappe du clavier hors de sa prise.
    When reinserting the keyboard ribbon cable, make sure you push it in all the way (two plastic tools are helpful - one to push it down flat, the other to coax it all the way in). For 3 days after replacing a top case, my MacBook Pro 13" wouldn't start up. I thought the main logic board was fried too. However, reinserting the keyboard ribbon cable again, this time perhaps 1mm farther in, and it started up again! I did the same for the "keyboard backlight ribbon cable" (i.e. reinserted it just to make sure). Really not sure which completed the circuit so is would start, but I suspect the keyboard ribbon cable.
    amiller770 - Réponse
    Citation de amiller770 :
    I usually use a piece of sticky transparent office tape and stick it over the flat cable a bit further away from the mating part then pull on it. There is no better way to force the flat cable into a stiff connector without damaging the fragile cable.
    Leo Bodnar - Réponse
    As others have stated, if the keyboard ribbon cable isn't fully inserted the MBP will not power on. Leo Bodnar's recommendation to use a piece of transparent office tape did the trick for me. Many thanks Leo!
    Matthew Rankin - Réponse
    Inserting the ribbon cable for the keyboard was really difficult, but i was able to get it in using a piece of tape and pulling it up, just like the tape on the keyboard backlight.
    Kelly Legner - Réponse
    Using a piece of tape is sheer genius Kelly. My mom once said her definition of genius was an idea that, when you hear it, you say to yourself, “now why didn’t I think of that?” But you never would have thought of it. Brava (or bravo) Kelly!
    JonnyLine -
  13. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 13, image 1 de 1
    • Décollez le petit morceau de bande adhésive noire recouvrant la prise de la nappe du rétro-élairage du clavier.
  14. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 14, image 1 de 3 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 14, image 2 de 3 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 14, image 3 de 3
    • Avec la pointe d'une spatule, ouvrez le clapet de retenue de la prise ZIF de la nappe du rétro-éclairage du clavier.
    • Avec votre spatule, faites glisser la nappe du rétro-éclairage du clavier hors de sa prise.
  15. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 15, image 1 de 1
    • Avec l'extrémité plate d'une spatule, soulevez le connecteur de la nappe du voyant de la batterie pour le débrancher de la carte mère.
  16. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 16, image 1 de 1
    • Avec la pointe d'une spatule, décollez soigneusement le microphone de la bande adhésive le fixant au boîtier supérieur.
  17. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 17, image 1 de 1
    • Dévissez les vis suivantes :
    • Cinq vis cruciformes de 3,1 mm.
    • Deux vis cruciformes de 3,9 mm.
    • Deux vis cruciformes de 7 mm sur la carte de raccordement MagSafe (DC-In).
  18. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 18, image 1 de 2 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 18, image 2 de 2
    • Dévissez les vis tri-wing suivantes, fixant la batterie au boîtier supérieur :
    • Une vis tri-wing de 5,5 mm.
    • Une vis tri-wing de 13,5 mm.
    • Ôtez la batterie du boîtier supérieur.
  19. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 19, image 1 de 2 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 19, image 2 de 2
    • Saisissez le côté gauche de la carte mère et soulevez-la jusqu'à ce que les ports s'écartent du côté du boîtier supérieur.
    • Éloignez la carte mère du côté du boîtier supérieur et retirez-la en évitant que la carte de raccordement MagSafe (DC-In) ne reste accrochée.
    • Faites attention à ne pas arracher la prise fragile du connecteur de l'ensemble microphone.
    When putting the logic board back in place, it's easier to angle the mic down in it's place as you are placing the board in, rather than after the board is seated.
  20. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009, Boîtier supérieur: étape 20, image 1 de 2 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009, Boîtier supérieur: étape 20, image 2 de 2
    • Retirez deux vis cruciformes fixant le support du disque dur du boîtier.
    • Les vis restent prises dans le support.
    • Soulevez le support de retenue hors du boîtier.
  21. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 21, image 1 de 1
    • Soulevez le disque dur par son bord libre et retirez-le du châssis, en tenant compte de la nappe qui l'attache à l'ordinateur.
  22. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 22, image 1 de 1
    • Débranchez le disque dur en tirant sur le connecteur de la nappe du disque dur pour l'éloigner du lecteur.
  23. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 23, image 1 de 2 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 23, image 2 de 2
    • Retirez les quatre vis suivantes fixant la nappe du disque dur et du capteur IR au boîtier :
    • Deux vis cruciformes de 1,5 mm
    • Deux vis cruciformes de 4 mm
    • Éloignez le support du disque dur et du capteur IR du bord du boîtier.
    • Décollez soigneusement la nappe du disque dur et du capteur IR du boîtier.
  24. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 24, image 1 de 2 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 24, image 2 de 2
    • Retirez les deux vis cruciformes fixant le subwoofer au boîtier.
    • La plus longue (8,2 mm) des deux vis est sur la droite. La plus courte (5 mm) est sur la gauche.
    • Le subwoofer est toujours connecté au haut-parleur droit, ne l'enlevez donc pas complètement.
    • Retirez le subwoofer du lecteur optique et posez-le juste à côté de l'ordinateur.
  25. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 25, image 1 de 2 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 25, image 2 de 2
    • Retirez les deux vis cruciformes de 9,2 mm fixant le support de la nappe de la caméra au boîtier supérieur.
    • Il se peut que la vis la plus à l'intérieur reste prise dans la nappe de la caméra.
    • Si vous avez la version mi-2010, le support de votre nappe de caméra peut être légèrement différent, mais la procédure reste la même.
    • Soulevez le support de la nappe de la caméra hors du boîtier supérieur.
  26. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 26, image 1 de 2 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 26, image 2 de 2
    • Retirez les trois vis cruciformes de 2,5 mm fixant le lecteur optique au boîtier supérieur.
    • Soulevez le lecteur optique par son bord droit et retirez-le de l'ordinateur.
  27. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 27, image 1 de 1
    • Décollez le petit morceau de ruban adhésif noir recouvrant la nappe du haut-parleur droit.
    • Faites attention, car la nappe du bouton de marche se trouve juste en dessous de ce ruban adhésif.
  28. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 28, image 1 de 1
    • Utilisez la pointe d'un spudger pour décoller le haut-parleur droit de l'adhésif le fixant au boîtier.
  29. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 29, image 1 de 1
    • Soulevez l'ensemble subwoofer et haut-parleur droit hors du boîtier supérieur.
  30. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 30, image 1 de 2 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 30, image 2 de 2
    • Retirez les deux vis extérieures Torx de 6 mm fixant de chaque côté le support de l'écran au boîtier supérieur (4 vis au total).
    • Lors du remontage, desserrez les vis intérieures Torx de 6 mm d'environ un quart de tour et alignez délicatement l'écran et le boîtier avant d'insérer les vis extérieures Torx de 6 mm. Une fois l'écran et le boîtier alignés, serrez les vis intérieures Torx de 6 mm, puis insérez et serrez les vis extérieures Torx de 6 mm.
    When re-assembling everything, you'll need to back out the inner screws a bit and align the upper case and display. After aligning them, tighten the inner screws again, then insert and tighten the outer screws.
    bradeyh - Réponse
  31. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 31, image 1 de 1
    • Ouvrez votre MacBook Pro à angle droit entre l'écran et le boîtier supérieur.
    • Placez votre MacBook Pro ouvert sur une table comme sur la photo.
    • Tout en tenant l'écran et le boîtier avec votre main gauche, retirez la dernière vis Torx de 6 mm de la fixation en bas de l'écran.
  32. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 32, image 1 de 1
    • Veillez à maintenir l'écran et le boîtier supérieur avec votre main gauche. Si vous les lâchez, vous risquez de faire tomber l'écran ou le boîtier supérieur et donc de les abîmer.
    • Retirez la dernière vis Torx T8 fixant l'écran au boîtier supérieur.
  33. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 33, image 1 de 3 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 33, image 2 de 3 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 33, image 3 de 3
    • Saisissez le boîtier avec votre main droite et faites-le pivoter légèrement vers le haut de l'écran, de sorte que le support supérieur de l'écran s'écarte du bord du boîtier supérieur.
    • Faites légèrement pivoter l'écran pour l'écarter du boîtier.
    • Soulevez l'écran et éloignez-le du boîtier, en tenant compte des supports ou des nappes susceptibles de rester accrochés.
  34. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009, Boîtier supérieur: étape 34, image 1 de 1
    • Retirez les quatre vis cruciformes de 1,2 mm entourées en rouge.
  35. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 35, image 1 de 1
    • Délogez soigneusement le bord du trackpad le plus proche du clavier de son orifice dans le boîtier supérieur en l'écartant des supports attachés au boîtier.
    • Faites passer la nappe du trackpad à travers sa fente découpée dans le boîtier supérieur.
    I concur with Anonymous 596. There is a support wall that runs front to back, under keyboard, held down by 2 Phillips screws that will need to be removed & transferred to new upper case. You can see it being touched by index finger in this pic.
    Macrepair SF - Réponse
  36. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 36, image 1 de 1
    • Éloignez le trackpad du bord extérieur du boîtier supérieur.
    • Retirez le trackpad et mettez-le de côté.
    There's a missing step here. In addition to the trackpad, there's an aluminum structural piece that sits under the center of the keyboard, that has to be migrated from old to new case. It's clearly shown to the left of the repair-person's right hand in step 44.
    anonymous 596 - Réponse
  37. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 37, image 1 de 1
    • Dans les étapes suivantes, vous allez préparer votre nouveau boîtier supérieur.
    • Utilisez un tournevis Torx T6 pour visser lâchement la vis de blocage de 1,1 mm incluse avec votre nouveau boîtier dans son trou moulé près du milieu de l'orifice du trackpad sur votre nouveau boitier.
    • Il suffit de serrer d'environ un tour pour le moment.
    I bought a used replacement case and had to move a few parts from the old case to the replacement. This included the battery indicator cable, the clips for the trackpad and the bracket in the center of the top case. So worth it at this point to compare your old and replacement case to be sure everything you need is there.
    Ron - Réponse
    my new case came with the set screw already installed, and i couldn’t loosen it. i didn’t want to strip it and cause a bigger problem, so i left it alone. the trackpad seems to work fine so far regardless, although i may take the bottom case off and play with it a little if i get a chance.
    i also (just like Ron) had to move the trackpad clips, battery indicator and center bracket to the new case. they were not included.
    Matt - Réponse
  38. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 38, image 1 de 2 Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 38, image 2 de 2
    • Insérez soigneusement la nappe de votre ancien trackpad à travers la fente découpée dans votre nouveau boîtier.
    • Utilisez une main pour maintenir la nappe du trackpad en place lorsque vous insérez les deux pattes de retenue du bord extérieur du trackpad sous le rebord du boîtier supérieur.
    • Tirez sur la nappe du trackpad lorsque vous placez le trackpad dans son emplacement dans votre nouveau boîtier.
  39. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 39, image 1 de 1
    • Insérez une vis cruciforme de 1,2 mm dans chacun des trous extérieurs forés dans le trackpad (deux vis au total).
    • Vous installerez le reste plus tard.
    • Serrez les vis, puis desserrez-les d'environ un quart de tour pour faciliter l'alignement de votre trackpad au cours des prochaines étapes.
  40. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 40, image 1 de 1
    • En essayant continuellement de cliquer sur votre trackpad, serrez doucement la vis de blocage Torx T6 jusqu'à ce que les clics "semblent" fonctionner comme quand le MacBook était neuf.
    • Pour estimer le serrage de la vis, le bruit qu'elle fait lorsque le trackpad clique suffit. Si la vis de blocage est trop lâche, le trackpad aura trop de jeu avant le clic. Si elle est trop serrée, le trackpad cliquera trop facilement et ne produira pas le bruit sonore caractéristique de la souris.
  41. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 41, image 1 de 1
    • Ensuite, retournez votre boîtier pour que le côté clavier soit orienté vers le haut.
    • Alignez le trackpad de façon qu'il soit centré dans son trou découpé dans le boîtier.
    Pour l’alignement du Tradpad mettez sur les 4 cotés des morceaux de feuille A4😜.
    Caruso - Réponse
  42. Remplacement du boîtier supérieur du MacBook Pro 13" Unibody mi-2009: étape 42, image 1 de 1
    • Serrez les deux vis extérieures le long du bord intérieur du trackpad et vérifiez l'alignement de celui-ci sur le côté extérieur du boîtier supérieur.
    • Si l'alignement semble bon, vissez le reste des vis cruciformes le long du bord intérieur du trackpad.
    • Avant de réassembler votre machine, vérifiez que la vis de blocage permet toujours à la souris de cliquer correctement.
    You can actually replace the keyboard alone fairly easily! I don't know why everyone says you have to replace the whole top case, because if you've got the guts to go this far, you might as well just peel back the illuminator cover and get to work pulling all those tiny screws in the keyboard... Just be careful when peeling up the black adhesive keyboard cover, because you will need to replace it. I used the edge of the ifixit Sesame tool (very thin flat metal opening tool) to carefully slip under any bits of adhesive, and had the keyboard exposed in no time. Also be careful because the clear plastic sheet is actually the keyboard illuminator. Once under all that, it's a mere 50 or so tiny screws, 2 screws in the power button backing, and you've got the keyboard out. Use a magnetized #000 phillips, it will make life much easier than anything else.
    Logan Bean - Réponse
    Absolutely right. I just replaced a keyboard the same way without much problem but i just want to add that those tiny screws need extra care as the heads can get damaged very easily. If damaged, they become very difficult to remove.
    Masood -
    I did just that on my mid-2010 MacBook Pro about a month ago and sadly will have to do it to my wife's Early-2011 one next week. I was cleaning all the crap off her keyboard and apparently nuked the K and 0 keys on her keyboard. Probably my ply challenge was aligning the keyboard illuminator. It's still not aligned properly on mine so some keys are better lit than others, but otherwise it was a relatively easy fix and far cheaper than replacing the entire upper case.
    John Adam Wickliffe -
    I replaced my keyboard less than an hour ago. The biggest pain/most time consuming was reattaching the ZIF connector for the keyboard and backlight. No matter what I did I could not get the %#*@ thing to reattach. What sadist designs these things? I had to walk away from the project for an hour and finally success.
    All those screws will make you go crosseyed!
    Gordon - Réponse
    It helps to put some tape along the cable going lengthwise to the cable, and then fold the end of the tape onto itself to give yourself something to hold onto. This will give you some leverage to get that puppy into the socket.
    maccentric -
    I’m glad you managed !!!
    I’m suffering :( take a part about 5 times…… ordered new (used) keyboard, the same results. I tested logic board in my daughter MAC, board works 100% no trouble ……. what could be wrong? there a secret how to reassemble keyboard parts together? I ripped a little bit black plastic thing, not top one with tiny connectors……
    In the end I have two keyboards, cleaned and taken a part, both of them acting identical when installed. Some keys respond by giving absolutely not relevant symbols, beeping noise come with almost every key i pressed…..
    Recovering after massive cappuccino spell after surprising hug :(((((
    Aleksandra Perry -
    I swear to post photo step by step, if I will achieve this one……….. assemble back to 100% working condition after total reassembling, ultrasonic cleaning and drying………. just keyboard panel.
    Give me nightmares :) will be first time I have so much trouble to fix………
    Aleksandra Perry -
    I'm wondering about putting it back together. Different wires and small parts etc were glued or adhered in some way to the case or sides or whatever, as it is put together in the beginning. Is that just to make it easier to put it back together? Should I try to stick them back the way they were with something? Can you use tape or glue if it's just a wire? I wouldn't want to use something that would melt...or is this not something to worry apout?
    ingwis - Réponse
    I just used 1/4 polymide tape, and iFixit double sided tape. Works like a champ.
    Brent Hillyer -
Pour réassembler votre appareil, suivez ces instructions dans l'ordre inverse.
47 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
2 commentaires
Very good tutorial. Guide was 100% accurate. As mentioned, make sure you have good quality tools, and follow the guide to be certain the right get tool is used for certain screws, I did strip one screw head, in my opinion not bad considering all the tiny screws! But now my MacBook works, and save me having to spend on a new MacBook!
Gabriel - Réponse
Outstanding level of detail!!! Spot on directions.
Dan Coy - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 35
Total : 92,036
