Aller au contenu principal
Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010
Ce dont vous avez besoin
  1. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010, Retirer les vis du boîtier inférieur: étape 1, image 1 de 1
    • Retirez les 10 vis suivantes par lesquelles est fixé le boîtier inférieur du MacBook Pro 13" Unibody :
    • Sept vis Phillips 3 mm.
    • Trois vis Phillips 13,5 mm.
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    David Kilbridge - Réponse
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - Réponse
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - Réponse
    I use a magnetic mat and place the screws in order on that :)
    Cary B - Réponse
  2. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010, Soulever le boîtier inférieur: étape 2, image 1 de 1
    • Soulevez légèrement le boîtier inférieur et poussez-le vers l'arrière de l'ordinateur afin de désengager les pattes de fixation.
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - Réponse
    Long story short: I drank the AppleKoolAid back in 1984 and have always left the guts of my machines up to Apple - until recently when I needed to swap the SATAs from my original MacDaddy (2009 13" MBPro that I killed in 2018 - coffee + blackout = OOOOPS) into a pristine 2009 MBPro from a Goodwill in North Carolina through eBay. I need the files from iCal and MacMail that can't be opened in my newer machines.
    Well . . . I ain't never done nuttin' like that, before!
    Enter Luke Miani on YouTube. He raves about you guys! So, I watched everything I could, read your site, bought the right tools and at the ripe old age of 72, I sat down, this morning and did the work. Now my original MacDaddy lives in MacDaddy2.0.
    Am I allowed to cry?
    Seriously, I can't thank you enough for your bitchen site and killer tools. I wish I'd'a been turned on to this shizzle 30+ years ago.
    IFIXIT - IDIGIT!
    kath myers - Réponse
    HAHAHAHAHAHAHAHAHAHA.
    That was a brilliant read.
    Yes, I came across ifixit a few years ago. Totally helped me out on several occasions.
    Glad your Mac repair journey worked out.
    Cary B -
  3. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010, Batterie: étape 3, image 1 de 1
    • À titre de précaution, nous vous conseillons de débrancher le connecteur de la batterie de la carte mère afin d'éviter les décharges électriques.
    • À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur de la batterie pour le débrancher de la prise sur la carte mère.
    Citation de gansodesoya :
    why is step 3 necessary?
    Just to disconnect any power source to avoid damages by short-circuits.
    MrKane - Réponse
    How do you get that battery connector back on? Do you just press it in back in place after you're done?
    Horace Chung - Réponse
    yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
    maccentric -
    This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
    Jeff Diamond - Réponse
  4. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010, Écran complet: étape 4, image 1 de 1
    • Avec l'extrémité plate d'une spatule (spudger), soulevez le connecteur de la nappe du caisson de basse/du haut-parleur droit pour le débrancher de sa prise sur la carte mère.
    • Faites levier sous les fils.
    Mine had a small piece of insulating material on top of the connector. By removing that first, I could then pry up the connector with less stress on the cable.
    istlota - Réponse
    Great tip! Thanks.
    juliet - Réponse
  5. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 5, image 1 de 1
    • Déconnectez la nappe de la caméra en tirant l'extrémité mâle tout droit hors de la prise.
    • Assurez-vous de tirer sur le connecteur parallèlement à la surface de la carte mère, en direction du lecteur optique et non vers le haut.
  6. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 6, image 1 de 1
    • Dégagez le câble de données de la caméra de la rainure dans le lecteur optique.
    for easy dismantle, just remove 2 screw of subwoofer
    Mohamad Faizal Sharudin - Réponse
  7. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 7, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 7, image 2 de 2
    • Dévissez les vis suivantes :
    • Deux vis cruciformes de 10 mm
    • Une vis cruciforme de 3,8 mm
    • Faites glisser la fixation du câble de la caméra hors de son emplacement sous le caisson de basse et ôtez-la de l'ordinateur.
  8. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 8, image 1 de 3 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 8, image 2 de 3 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 8, image 3 de 3
    • Saisissez la languette en plastique fixée au dispositif de verrouillage du câble de données de l'écran et pivotez-la vers le côté DC-In (prise d'alimentation) de l'ordinateur.
    • Tirez le connecteur du câble de données de l'écran tout droit hors de sa prise.
    • Veillez à tirer le connecteur hors de sa prise et non vers le haut.
  9. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 9, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 9, image 2 de 2
    • Dévissez les deux vis suivantes, attachant la fixation du câble de données de l'écran au boîtier supérieur :
    • Une vis cruciforme de 8,6 mm.
    • Une vis cruciforme de 5,6 mm.
    • Ôtez la fixation du câble de données de l'écran du boîtier supérieur.
  10. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 10, image 1 de 1
    • Si présent, ôtez le petit morceau de bande adhésive en mousse fixé sur les vis de l'écran à côté du câble de données de l'écran.
  11. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 11, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 11, image 2 de 2
    • Dévissez les deux vis extérieures Torx T8 de 6,5 mm fixant chacune des deux fixations de l'écran au boîtier supérieur (4 vis au total).
    You may have to lift/remove a foam tape on the left side as well
    Sebastien CHAPUIS - Réponse
  12. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 12, image 1 de 1
    • Ouvrez votre MacBook de sorte que l'écran est perpendiculaire au boîtier supérieur.
    • Posez votre MacBook ouvert sur une table comme sur la photo.
    • Pendant que vous maintenez l'écran et le boîtier supérieur d'une main, dévissez la vis Torx T8 de 6,5 mm de la fixation inférieure de l'écran.
  13. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 13, image 1 de 1
    • Veillez à maintenir l'écran et le boîtier supérieur avec votre main gauche. Si vous les lâchez, vous risquez de faire tomber l'écran ou le boîtier inférieur et donc de les abîmer.
    • Dévissez la dernière vis Torx T8 mm fixant l'écran au boîtier supérieur.
    When reassembling, Careful not to drop your screw, or it may get stuck to the (magnetic) power adapter port. Oops!
    Save yourself some time and don't drop it!
    rowdyferret - Réponse
  14. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 14, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 14, image 2 de 2
    • Saisissez le boîtier supérieur de votre main droite et faites-le légèrement pivoter vers le haut de l'écran de sorte que la fixation supérieure de l'écran s'éloigne du bord du boîtier supérieur.
    • Faites pivoter et éloignez légèrement l'écran du boîtier supérieur.
    Make sure you make a 90 degree angle between the keyboard and the display before taking out the screws. If you have less than a 90, you will never get it apart due to the upper display bracket shape. It has to be at the right angle or it won't come out.
    mastover - Réponse
    I place it over keyboard side down hanging over a table. This way I know it's at 90 degrees and it also makes it easier to take it off.
    Nick - Réponse
  15. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 15, image 1 de 1
    • Soulevez et éloignez l'écran du boîtier supérieur en veillant à ce que aucune fixation ni aucune nappe ne reste accrochée.
    As mentioned in the previous step, place it keyboard side down with the edge hanging over a table. This way it's at 90 degrees and it makes it easier to align and get the screws in.
    Josh - Réponse
  16. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010, Vitre avant de l'écran: étape 16, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010, Vitre avant de l'écran: étape 16, image 2 de 2
    • Au cours des étapes suivantes, vous aurez besoin d'une pistolet à air chaud pour ramollir la colle fixant la bordure extérieure noire à l'écran toute autour de la face intérieure de la vitre avant. La zone où la colle a été mise est marquée en rouge sur la seconde photo.
    • Réglez le pistolet à air chaud à température basse et commencez à chauffer la bordure extérieure noire, du côté du coin supérieur droit de l'écran.
    • Ne pointez jamais le pistolet sur la bande souple en caoutchouc autour de la vitre. Si vous chauffez le caoutchouc, vous risquez de le faire fondre légèrement et de rendre brillante sa surface matte. Si vous touchez le caoutchouc surchauffé, vous risquez de le déformer définitivement.
    • Dû à la chaleur appliquée, il est normal qu'une couche de condensation se forme à l'intérieur de la vitre et/ou à l'extérieur de l'écran LCD. Vous pouvez l'enlevez avec du nettoyant pour vitres une fois que la vitre est séparée de l'écran.
    Heating rubber strip it becomes glossy You can turn it to matte using ultrafine sandpaper (very ultrafine!!!) P2500
    Silvio - Réponse
    Great piece of advice. Thank you!
    Brian -
    With a lot of heating, for me, it was very hard to get the glass to separate from the case. I had better luck starting from the bottom right as I could grip better onto the case. Three mistakes I made:
    1. Once I got the glass separated, I probably didn't heat sufficiently as I was going around and the glass broke. That made the rest of the procedure miserable. Lesson: pull very gently.
    2. I must have touched one of the tiny bits of glass that fell on the LCD and it scratched the actual screen. :-(. Lesson: vacuum the pieces as you go and be very careful when touching the LCD.
    3. I somehow overheated the LCD screen at the top left and right corners and now the display is all wonky and faded at the corners. Not sure what the lesson is here.
    Athanassios Diacakis - Réponse
    First, if using a hair dryer, what setting should that be operated at? It would be much cooler than the heat gun, right?
    Second, the iFixit basic set comes with a small, clear suction cup. Would that be sufficient for this project, or does it require the stronger pull of the other cups?
    Finally, must I reapply adhesive to the case when replacing the glass? Does the original remain tacky and re-bond on assembly?
    contact - Réponse
    It's been a while since you asked, but since no one answered and someone else may have the same questions:
    Hair dryers vary a lot, depending on wattage. I would start on low or med, and work my way up to high if necessary. I'd keep the fan on the lowest setting.
    The little suction cup is for removing screens like the iMac, which just uses magnets, and possibly an iPad or iPhone. I would not want to use that for this project, get something about 2" wide with a decent handle.
    The screen should have the double sided glue tape already applied, just remove the backing. I wouldn't get glass that doesn't have the tape on it, big waste of time with little savings in cost.
    Jeff Kamis
    maccentric -
    All I can say for this is don't be tempted to hold the heat gun too close. I ended up burning my LCD the first time I did it and having to replace that when all I was looking to do was replace the cable. I got the glass off holding it about 4/5 inches from the screen and being patient (it took about 5/10 minutes in the end).
    Nick - Réponse
    The tape is very sticky and the glass is very fragile but at the same time fairly flexible.....I ended up breaking the glass ans it turned out to be a mess picking up the shards....but in the end a new glass is not too costly. the implication is that heating melts the glue but it is really just double stick tape.....there are some "youtube" videos that are worth a look but I would suggest using guitar picks and not a putty knife which creates a point load that breaks the glass....wear safety glasses!!
    brian62 - Réponse
    Be ready to replace the glass (good thing mine was already broken, I ordered one). Wear surgery gloves and protective glasses. Trust your nose, if it smell melted plastic, it’s a good clue to stop the heat.
    It's more easy to do this step before removing the LCD. You have more control of the LCD and is more easy to remove the Glass.
    Felix - Réponse
    If you have a glass cover that is severely cracked then the heating gun and suction cup procedure really doesn’t work. Suction cups won’t hold and the already broken glass doesn’t lift. Here’s what I did that made the job easier. Using 2 inch wide transparent packing tape I laid it along the perimeter of the display but not covering the rubber edge. Then I used a 1/4 inch wood carving tool and very carefully removed the glass and 2 sided tape around the metal border. Use as your guide picture 2 in this step that shows where the camera and cable is located. Where the camera is located in the top center the 2 sided tape isn’t located so you can easily lift the glass. The camera cable runs up the right side in a trough in the metal border so when lifting the tape and glass in this area just keep the sharp end flat and it is wide enough it won’t dip into the trough and damage the cable. The tape was very helpful because it kept the glass from splintering and going everywhere.
    joe lochner - Réponse
  17. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 17, image 1 de 3 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 17, image 2 de 3 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 17, image 3 de 3
    Outil utilisé dans cette étape :
    Heavy-Duty Suction Cups (Pair)
    $14.95
    J'achète
    • Une fois que la vitre a été suffisamment chauffée, fixez une ventouse à levier à côté du coin supérieur droit de la vitre.
    • Ne fixez pas la ventouse sur la bande en caoutchouc au bord de la vitre.
    • Si vous utilisez une de nos ventouses, posez-la, la poignée mobile parallèle à la surface de la vitre. Puis, tout en appuyant légèrement la ventouse sur la vitre, relevez la poignée mobile jusqu'à ce qu'elle soit parallèle à l'autre poignée.
    • Soulevez et éloignez doucement et délicatement le coin de la vitre de l'ensemble écran.
    • Si vous arrivez juste à soulever le bord supérieur de l'écran (comme sur la troisième photo), répétez les étapes un et deux jusqu'à ce que le coin de la vitre se soulève.
  18. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 18, image 1 de 3 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 18, image 2 de 3 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 18, image 3 de 3
    • Soulevez précautionneusement le coin de la vitre suffisamment pour pouvoir insérer une spatule (spudger) entre elle et l'ensemble écran.
    • Avec l'extrémité plate de la spatule, décollez soigneusement la bande adhésive fixant la vitre à l'écran.
    • Soulevez la vitre de quelques centimètres au-dessus du coin supérieur droit, tout au long du bord supérieur et du bord droit de l'écran.
  19. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 19, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 19, image 2 de 2
    • Avec un pistolet à air chaud, faites ramollir la colle sous la bordure noire le long du côté droit de la vitre avant.
    • Fixez une ventouse à levier du côté droit de la vitre avant.
    • Soulevez la vitre pendant que vous la séparez du reste de l'ensemble écran avec l'extrémité plate d'une spatule.
    • Progressez le long du bord droit de la vitre avant jusqu'à ce qu'elle soit séparée de l'écran.
    • Il peut être utile d'insérer un médiator de guitare ou un autre objet fin en plastique pour empêcher le coin supérieur droit de la vitre avant de se recoller sur l'ensemble écran.
    I ended up breaking my glass panel due to using the spudger. I think if you use something more like a small putty knife you will do better. The spudger puts a lot of pressure in a small spot while the putty knife would put a little pressure over a larger area. Also, if you do break the glass, be sure to get ALL of the broken bits off before putting the new one on. Also, watch out for those broken bits as they tend to penetrate skin quite easily, and stay there for days!
    mastover - Réponse
  20. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 20, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 20, image 2 de 2
    • Avec votre pistolet à air chaud, ramollissez la colle sous la bordure noire le long du bord supérieur de la vitre.
    • Fixez une ventouse à levier sur le bord supérieur de la vitre avant et tirez-la pour séparer la vitre de l'écran.
    • Progressez le long du bord supérieur de la vitre, en enlevant précautionneusement la colle avec l'extrémité plate d'une spatule si nécessaire.
  21. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 21, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 21, image 2 de 2
    • Avec le pistolet à air chaud, ramollissez la colle sous la bordure noire du côté du coin supérieur gauche de la vitre.
    • Fixez une ventouse à levier dans le coin supérieur gauche de la vitre avant.
    • Tirez sur la ventouse pendant que vous séparez précautionneusement la vitre de l'ensemble écran avec l'extrémité plate d'une spatule.
    • Après avoir séparé le coin supérieur gauche de l'écran, il peut être utile d'insérer un médiator de guitare ou un autre objet fin en plastique pour empêcher la vitre de se recoller sur l'ensemble écran.
  22. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 22, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 22, image 2 de 2
    • Avec un pistolet à air chaud ou un sèche-cheveux, faites ramollir la colle sous la bordure noire le long du bord gauche de la vitre avant.
    • Fixez une ventouse à levier du côté gauche de la vitre avant.
    • Progressez le long du bord gauche de la vitre avant jusqu'à ce qu'il soit séparé de l'écran.
  23. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 23, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 23, image 2 de 2
    • Maintenant que les bords supérieur, gauche et droit de la vitre sont séparés de l'écran, soulevez doucement le bord supérieur de la vitre et faites-le délicatement pivoter pour le retirer de l'écran.
    • Si nécessaire, séparez le bord inférieur de la vitre de l'ensemble écran avec l'extrémité plate d'une spatule.
    • Avant le remontage, veillez à nettoyer l'intérieur de la vitre ainsi que l'écran LCD, car toute poussière ou empreinte digitale à l'intérieur se verra et gênera dès que l'ordinateur sera allumé.
  24. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 24, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 24, image 2 de 2
    • Sautez cette étape si vous réutilisez la vitre d'origine.
    • Insérez la pointe d'un outil en plastique entre la vitre de l'écran et la fixation de la caméra et progressez autour de la fixation de la camera pour le séparer de la vitre.
    • N'oubliez pas de monter la fixation de la caméra sur la nouvelle vitre avant avant le remontage.
  25. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 25, image 1 de 3 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 25, image 2 de 3 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 25, image 3 de 3
    • Il est possible que la nappe de la caméra se prenne dans la colle sur la vitre, puis se déconnecte de la carte caméra au moment où vous soulevez la vitre. Si la nappe est toujours connectée à la carte caméra, sautez cette étape.
    • Pour reconnecter la nappe de la caméra, enlevez d'abord le morceau de mousse autocollante sur la prise ZIF de la nappe avec la pointe d'une spatule.
    • Toujours avec la pointe de la spatule, ouvrez le clapet de retenue ZIF de la prise de la nappe de la caméra.
    • Insérez la nappe de la caméra dans sa prise sur la carte caméra et refermez le clapet de retenue ZIF avec la pointe de la spatule pour maintenir la nappe en place.
    • Refixez le morceau de mousse autocollante couvrant la prise de la nappe de la caméra.
  26. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010, Cache charnière: étape 26, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010, Cache charnière: étape 26, image 2 de 2
    • Faites glisser le cache charnière vers la droite de l'écran.
    • Le cache charnière se déplacera d'environ 0,6 cm. N'essayez pas de forcer pour aller plus à droite.
    • Au moment de remonter le cache charnière, veillez à y glisser les composants qui dépassent du bord inférieur de l'écran, en les décalant d'environ 0,6 cm vers la droite par rapport à la position finale de l'écran.
    The plastic tabs of the clutch fit into slots that end up holding the clutch in place. The idea is that you need to slide the clutch to the right to free the plastic tabs from the metal slots in the LCD frame.....then you can separate the clutch from the frame.
    brian62 - Réponse
  27. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 27, image 1 de 3 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 27, image 2 de 3 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 27, image 3 de 3
    • En commençant tout à droite, faites jouer le cache charnière tout le long de son axe pendant que vous l'ôtez de la charnière.
    • En progressant de droite à gauche, soulevez et dégagez soigneusement le cache charnière du bord inférieur de l'ensemble écran.
    • Ôtez le cache charnière du joint avant et mettez-le de côté.
    • Au moment de réinstaller le cache charnière, veillez à élargir l'ouverture quand vous faites glisser dessus le petit cache en plastique noir esthétique, qui recouvre l'extrémité ouverte du cache charnière quand celui-ci est en place. Le cache esthétique est maintenu à la charnière droite par des attaches en plastique très fines et fragiles.
    Highly recommended to remove clutch cover BEFORE heating up glass, because cover is made of very thin plastic and it'll be deformed!
    Basically, I'm removing everything from screen - clutch cover, wifi card, antenna, all plastic bits, and only then proceed with heating and glass removal.
    DigiHead - Réponse
    Starting at it's far LEFT end
    Job - Réponse
    just slide the plastic cover to the right and it comes right off.
    William - Réponse
  28. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010, Écran LCD: étape 28, image 1 de 1
    • Dégagez le câble de données de l'écran de son support de fixation à côté du coin inférieur gauche de l'écran.
  29. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 29, image 1 de 1
    • Dévissez les six vis suivantes fixant le panneau LCD au joint avant :
    • Quatre vis cruciformes de 3,25 mm à large tête.
    • Deux vis cruciformes de 3,2 mm à petite tête.
  30. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 30, image 1 de 1
    • N'essayez pas encore de retirer l'écran LCD. Le système de circuits en bas de l'écran est logé dans un interstice le long du bord inférieur du renfoncement dans l'écran complet en aluminium.
    • Maintenez l'écran à la verticale et inclinez-le suffisamment pour saisir le bord supérieur de l'écran LCD et faites-le pivoter en l'éloignant légèrement de l'ensemble écran. Faites bien attention à ne pas détacher le système de circuits du bord inférieur.
  31. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 31, image 1 de 1
    • Tirez le panneau LCD vers le bord supérieur de l'écran pour faire glisser le système de circuits le long de son bord inférieur hors de l'emplacement dans le support de l'écran en aluminium.
    • Il peut être utile de faire passer d'une main le câble de données de l'écran à travers son canal dans le support en aluminium de l'écran pendant que de l'autre, vous tirez le panneau LCD vers le bord supérieur de l'écran.
  32. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 32, image 1 de 1
    • Décollez le morceau d'adhésif recouvrant le connecteur du câble de données de l'écran sur le bord le plus proche de l'écran LCD.
  33. Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 33, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 13" Unibody mi-2010: étape 33, image 2 de 2
    • Avec la pointe d'une spatule, ouvrez le fin clapet de retenue en acier fixant le câble de données de l'écran à sa prise sur l'écran LCD.
    • Tirez le câble de données de l'écran tout droit hors de sa prise sur l'écran.
    • Ôtez l'écran LCD de l'ensemble écran et mettez-le de côté.
Pour remonter votre ordinateur, suivez les instructions en sens inverse.
77 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
5 commentaires
All I can say is THANKS! I was able to replace my daughters display, the bottom aluminum panel and to remove the dents from the top aluminum panel. Without your guide, I doubt I ever could have done this. You saved me hundreds! Your spudger tool was worth its weight in gold....till I used it to break the glass front panel...sigh. Still, I'll use that hundreds of times from now on.
mastover - Réponse
==Step 17==
It is extremely critical that when attaching the suction cup to FIRST LIFT THE LEVER ABOUT HALF WAY before attaching to the glass in order to only apply about half the suction the tool is capable of applying!! Lift the lever half way. Set into position on glass. Lift the rest of the way to apply about half of the suction cup's potential suction. Failure to do this WILL result in circular break around the suction cup!
jnserr - Réponse
This was extremely helpful. I am a junior in high school who was issued a Mac for class. I am one of those anti-Apple people, so I get easily frustrated with them and tend to beat them up a bit. Consequently, I broke it. Being low on funds, I couldn't afford the repair costs, let alone had the nerve to own up to my actions and tell the teacher about it. SO....after staying up an extra couple hours researching the problem, I discovered this and decided to give it a try. Despite already being somewhat tech savvy, I found this resource very helpful, even more so after re-reading it and watching a couple how-to videos. The problem was fixed in no time.
Lets just say, thanks to this site, the school never found out that I broke the laptop. :)
Alexander - Réponse
GREAT GUIDE! Thanks!
I had a laser targeted infrared thermometer for another project ($25 at local hardware store) and found the screen cover adhesive softened nicely at top and sides at 140-145F. I used a hairdryer on high setting.
I found with the top edge and both side edges lifted free of the adhesive in earlier stages, the bottom edge lifted easily at 100-105F. (I had package taped the screen as it had cracks, being sure the tape laid flat so sunction would form in the early steps.
NOTE THE MAXIMUM SPECiIFIED NONOPERATING TEMPERATURE IS LISTED BY APPLE AT 113F for the 2010 MBP 13”. Separating the bottom and top cases allows the keyboard and all the other goodies in the lower case to rest comfortably away from the heat.
One or two very thin flexible pry tools like iSesame (inexpensive online) worked well once the upper corner was lifted with a suction cup
Stan Wingate - Réponse
This guide is the same of MacBook Pro 13 unibody 2012?
Ruben Costa - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 52
30 derniers jours : 198
Total : 160,213
