Introduction
Regain sound output from the left side of your MacBook Pro by replacing a blown-out left speaker.
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Use a spudger to pry up the fan connector out of its socket on the logic board.
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
Gently pull the display data cable connector away parallel to the board.
12 other people completed this guide.
