Introduction
你可以安装厚度最大为9.5mm的硬盘。
Ce dont vous avez besoin
要重新组装您的设备,请按照本指南的相反顺序进行操作。
580 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Leon赵国鑫 nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
20 commentaires
If your button to open mac is hard to use after you re-assembled the computer, check to see if the proper length screws were reinstalled. I had that problem and I switched the 2 screws. One was a tad longer. The longer one when screwed in, interferred with the button function.
Definitely NOT true for MY Mac. Both screws are absolutely identical. Still I had this issue. :-(
Turned out that if I screw them in real tight the issue will occur. If I turn back the screws about 180 degrees (i. e. if I loosen them) the problem disappears.
