Introduction
Change out the entire display assembly, including the inverter, Airport antennas, hinges and casing.
Ce dont vous avez besoin
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
Disconnect the three antenna cables attached to the Airport Extreme card.
26 autres ont terminé cette réparation.
1 commentaire de tutoriel
Real easy to follow. Great and simple instructions.
