Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement
Ce dont vous avez besoin
    1. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement, Battery: étape 1, image 1 de 1
      • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
      Demander à FixBot
      Ajouter un commentaire
    1. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement, RAM Shield: étape 2, image 1 de 1
      • Remove the three identical Phillips screws from the memory door.
      Demander à FixBot
    2. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 3, image 1 de 1
      • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
      Demander à FixBot
    1. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement, Upper Case: étape 4, image 1 de 1
      • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
      Demander à FixBot
    2. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 5, image 1 de 1
      • Remove the following 6 screws:
      • Two 10 mm T6 Torx screws on either side of the RAM slot.
      • Four 14.5 mm Phillips screws along the hinge.
      Demander à FixBot
    3. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 6, image 1 de 1
      • Remove the four 3.2 mm Phillips screws on the port side of the computer.
      Demander à FixBot
    4. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 7, image 1 de 1
      • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
      Demander à FixBot
    5. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 8, image 1 de 1
      • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
      Demander à FixBot
    6. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 9, image 1 de 1
      • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
      • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
      Demander à FixBot
    7. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 10, image 1 de 1
      • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
      • Remove the upper case.
      Demander à FixBot
    1. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement, Upper Case: étape 11, image 1 de 1
      • Use a spudger to pry up the translucent plastic sheath covering the keyboard connector.
      Demander à FixBot
    2. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 12, image 1 de 1
      • Use the tip of a spudger to flip up the black plastic flaps locking down the keyboard and keyboard backlight ribbon cables.
      Demander à FixBot
    3. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 13, image 1 de 1
      • Slide the orange keyboard backlight ribbon out of its connector.
      Demander à FixBot
    4. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 14, image 1 de 1
      • Peel up the orange tape covering the keyboard backlight connector.
      Demander à FixBot
    5. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 15, image 1 de 1
      • Use the tip of a spudger to flip up the brown plastic flap locking down the keyboard backlight ribbon cable.
      Demander à FixBot
    6. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 16, image 1 de 1
      • Use a spudger or your finger to slide the keyboard backlight ribbon out of its connector.
      Demander à FixBot
    7. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 17, image 1 de 1
      • Carefully peel up the orange ribbon cable which carries the power and sleep signals, removing tape as necessary.
      Demander à FixBot
    8. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 18, image 1 de 1
      • Peel back the black protective sheath on the right side of the upper case. It is not necessary to fully remove this shield. Simply peel it back enough to access the screws beneath.
      Demander à FixBot
    9. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 19, image 1 de 1
      • Peel back the black protective sheath on the left side of the upper case. It is not necessary to fully remove this shield. Simply peel it back enough to access the screws beneath.
      Demander à FixBot
    10. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 20, image 1 de 1
      • Remove the ten identical Phillips screws attaching the keyboard to the casing.
      Demander à FixBot
    11. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 21, image 1 de 1
      • There are four locking tabs along the back edge of the keyboard holding it in place. These tabs must be straightened before you can remove the keyboard.
      Demander à FixBot
    12. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 22, image 1 de 1
      • The first frame shows a tab in the "locked" position and the second frame shows the same tab in the "unlocked" position.
      • Use needlenose pliers or a spudger to bend each of the four tabs so that they are all in the "unlocked" position.
      Demander à FixBot
    13. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 23, image 1 de 1
      • Slide the keyboard ribbon out of its connector.
      • If the keyboard ribbon won't slide out, make sure that the black plastic flap holding the ribbon in place is vertical.
      Demander à FixBot
    14. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 24, image 1 de 1
      • Place the upper casing on its edge and use a spudger to push the keyboard away from the casing, poking the spudger through the central keyboard screw hole. Grasp the keyboard as it separates from the casing.
      Demander à FixBot
    15. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 25, image 1 de 1
      • Maintaining your hold on the keyboard, lay the casing flat and gently bow the keyboard until the two tabs on either side of the keyboard come free.
      • Slide the keyboard away from the trackpad and out of the upper case.
      Demander à FixBot
    16. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 26, image 1 de 1
      • Remove the two Phillips screws securing the black antenna holder to the upper case.
      • Lift the black Bluetooth antenna holder off of the upper case.
      Demander à FixBot
    17. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 27, image 1 de 1
      • Disconnect the Bluetooth antenna cable from the Bluetooth board.
      Demander à FixBot
    18. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 28, image 1 de 1
      • Lift the Bluetooth antenna out of its housing in the upper case. The Bluetooth antenna is secured to the upper case with an adhesive, so rocking the antenna board from side to side may help it come free easier.
      Demander à FixBot
    19. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 29, image 1 de 1
      • Remove the single Phillips screw securing the Bluetooth board to the lower case.
      Demander à FixBot
    20. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 30, image 1 de 1
      • Peel up the Bluetooth data cable from the adhesive on the upper case.
      Demander à FixBot
    21. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: étape 31, image 1 de 1
      • Disconnect the Bluetooth data cable from the upper case.
      • Lift the Bluetooth board and attached cable off the upper case.
      • Upper case remains.
      • To install your replacement upper case, install your current Bluetooth board, antenna, and keyboard into the replacement case and reassemble your computer.
      Demander à FixBot
7 autres ont terminé cette réparation.
iRobot
Membre depuis le 09/24/09
1 Réputation
635 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 30
Total : 24,838
