Aller au contenu principal
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement
Ce dont vous avez besoin
  1. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement, Battery: étape 1, image 1 de 3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement, Battery: étape 1, image 2 de 3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement, Battery: étape 1, image 3 de 3
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement, RAM Shield: étape 2, image 1 de 2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement, RAM Shield: étape 2, image 2 de 2
    • Remove the three identical 2mm Phillips screws from the memory door.
    • Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
  3. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement, Upper Case: étape 3, image 1 de 1
    • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
  4. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 4, image 1 de 1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
  5. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 5, image 1 de 1
    • Remove the four 3.2 mm PH00 Phillips screws on the port side of the computer.
  6. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 6, image 1 de 1
    • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
  7. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 7, image 1 de 1
    • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
  8. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 8, image 1 de 3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 8, image 2 de 3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 8, image 3 de 3
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
    • There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor. These clips can be very difficult to disengage without prying. They can also be difficult to re-engage during reassembly.
    • Reassembly Tip: Press down firmly on the tip of the top case above the location of each clip until you hear a snap to reseat them in their slots.
    • Reassembly Tip: The two center DVD clips will rarely snap back into place properly without help, and downward pressure will instead simply deform the frame around the DVD slot. Support the frame by inserting a plastic spudger into the DVD slot directly under the clip location until it is snug, then press down until you hear the snap.
  9. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 9, image 1 de 2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 9, image 2 de 2
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Note: It is possible to replace the hard drive without disconnecting the keyboard from the chassis, but it will need to be held upright to keep it out of the way, while still allowing you both hands to work on the drive removal.
    • Be careful when removing the keyboard-trackpad ribbon cable to ensure that the rear of the upper case is disengaged from the area near the hinge. It is easy to accidentally bend the screw receivers on either side of the keyboard.
    • Remove the upper case.
  10. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement, Display Assembly: étape 10, image 1 de 1
    • Disconnect the two or three antenna cables attached to the Airport Extreme card. Depending on your model, one of the three cables may be unused and capped with a black shrink tube.
    • Apple was kind enough to include a label showing where each color antenna cable plugs in - just make sure to look at this when reconnecting the antenna cables.
  11. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 11, image 1 de 1
    • Deroute the Airport antenna cables from their channel in the left speaker.
  12. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 12, image 1 de 1
    • Disconnect the iSight cable from the logic board by sliding the cable to the left and out of its connector.
  13. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 13, image 1 de 1
    • Support the display with one hand while removing the following screws:
    • One 9.5 mm silver T6 Torx screw with threads on only 3 mm of the shaft on the inside of the display hinges.
    • One 9.5 mm silver T6 Torx screw with threads on the entire shaft on the outside of the left hinge.
    • One 9.2 mm full thread T6 Torx screw securing the iSight cable ground loop to the fan.
  14. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 14, image 1 de 1
    • Disconnect the inverter cable from the left I/O board by placing a spudger beneath the cable and lifting up.
  15. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 15, image 1 de 2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 15, image 2 de 2
    • Disconnect the display data cable from the logic board.
    • Remove the foam bumper from the top of the right hinge of the display.
  16. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 16, image 1 de 1
    • Remove the silver 9.2 mm T6 Torx securing the ground loop in the display data cable to the casing.
  17. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 17, image 1 de 1
    • Support the display with one hand while removing the following screw:
  18. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 18, image 1 de 1
    • Grasp the display assembly on both sides and lift it up and out of the computer.
  19. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement, Rear Display Bezel: étape 19, image 1 de 2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement, Rear Display Bezel: étape 19, image 2 de 2
    • Remove the 4.5 mm Phillips screws from the lower left and right corners of the display (two screws total). These screws have a .8 mm thick head.
  20. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 20, image 1 de 3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 20, image 2 de 3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 20, image 3 de 3
    • Insert the flat end of a spudger perpendicular to the face of the display between the plastic strip attached to the rear bezel and the front bezel.
    • Do not insert your spudger between the plastic strip and the rear bezel.
    • With the spudger still inserted, rotate it away from the display to separate the front and rear bezels.
    • Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
  21. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 21, image 1 de 2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 21, image 2 de 2
    • Insert your spudger between the front and rear display bezels at the lower right corner of the display.
    • Pry the rear bezel away from the front bezel to slightly separate the bottom edge of the rear display bezel.
  22. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 22, image 1 de 2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 22, image 2 de 2
    • Insert the flat end of a spudger into the gap between the rear display bezel and the clutch cover.
    • Twist the spudger to separate the lower edge of the rear display bezel from the clutch cover.
    • Work along the lower edge of the rear bezel until it is evenly separated from the clutch cover.
  23. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 23, image 1 de 3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 23, image 2 de 3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 23, image 3 de 3
    • Now that the right and bottom edges of the rear bezel are slightly separated from the front bezel, use a spudger to pop the rear bezel off the tabs near the lower right corner of the display.
  24. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 24, image 1 de 2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 24, image 2 de 2
    • Insert the flat end of a spudger between the front bezel and the plastic strip attached to the rear bezel near the screw holes at the bottom corners of the display.
    • Rotate your spudger toward the rear bezel to separate it from the front bezel.
    • If necessary, continue separating the left edge of the rear bezel off the tabs on the front display bezel.
  25. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 25, image 1 de 1
  26. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement, LCD Panel: étape 26, image 1 de 1
    • Peel the large piece of black tape off the LCD near the latches at the top edge of the display.
    • It is not necessary to completely remove this piece of tape.
  27. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 27, image 1 de 1
    • Remove the two pieces of tape covering the iSight and camera ribbon cables near the top of the display.
    • Hold the iSight cable down as you remove the tape.
  28. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 28, image 1 de 3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 28, image 2 de 3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 28, image 3 de 3
    • Be careful not to damage the ZIF cable retainer as you use the edge of a plastic opening tool to flip it up.
    • Pull the iSight cable out of its socket on the camera board.
  29. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 29, image 1 de 2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 29, image 2 de 2
    • First remove the strip of tape covering the iSight cable.
    • Next, peel the three orange antenna straps off the lower edge of the LCD.
    • Remove the two pieces of tape securing the display data cable to the LCD.
  30. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 30, image 1 de 1
    • Disconnect the display data cable by pulling its connector toward the bottom edge of the display, away from the socket on the LCD.
  31. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 31, image 1 de 2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 31, image 2 de 2
    • Remove the four 3 mm Phillips screws from each side of the display (eight screws total).
  32. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 32, image 1 de 1
    • The next few steps will require you to separate the LCD from the adhesive applied to the upper and lower edges of the front bezel.
    • The adhesive is applied such that it sticks to a thin steel strip around the perimeter of the LCD. When prying your LCD away from the front panel, be sure you are separating the front panel from the steel strip on the LCD.
    • Do not simply pry on the edge of the frame as it is made of aluminum and can very easily bend!
    • Use the flat end of a spudger to gently lift one of the top corners of the LCD out of the front bezel.
  33. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 33, image 1 de 1
    • Work your way along the top edge of the LCD, slowly prying the attached steel strip away from the front bezel.
  34. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 34, image 1 de 2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 34, image 2 de 2
    • Now that the top edge is free, slightly lift the LCD out of the front bezel for enough room to pry the steel strip along the lower edge of the LCD away from the front bezel.
    • Pry along the lower edge of the LCD until it is freed from the adhesive on the front bezel.
    • Avoid pulling the edge of the LCD unit from the screen. Be sure to insert the tool between the metal of the bezel and the metal of the LCD. If the adhesive is very strong, make a couple trips across the bottom edge to avoid applying too much pressure.
  35. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 35, image 1 de 2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement: étape 35, image 2 de 2
    • Lift the LCD out of the front bezel, minding any cables that may get caught.
    • Replacement Note: there are clear plastic shims attached via adhesive to the sides and bottom of the lcd panel. Be sure to transfer these shims to the replacement panel for optimum fit.
    • Don't forget to transfer the small magnet attached to the right side of the LCD to your new LCD. The absence of this magnet will prevent your MacBook Pro from entering sleep mode.
    • Depending on the model of your laptop, the magnet may be located inside a hole in the front bezel, not the LCD itself. See second picture.
139 autres ont terminé cette réparation.
7 commentaires
I didn't have any trouble getting this apart - I used a small screwdriver from a jewelry repair kit (the set of six super small screwdrivers). I slide it in on the left front where it was open and slid it towards the IR thing. After that clip opened up I just slid it over towards the DVD drive... presto. Will update when I put this back together in a couple days. This guide should warn in the beginning to keep the screws identified in some way or you'll have a %*^! of time putting it back together.
Isaac - Réponse
I didn't have a spudger handy, but I got by just fine using an old credit card. Don't use a current one, as I dented up the edges pretty good in the process.
I've disassembled many a pc laptop without instructions, but macs are special ;) it was very helpful to have all the details spelled out for me. Thanks!
Seth - Réponse
Confirming Success #44.
While I would advocate for good lighting, non-geriatric eyes, or a vision headset, and serious patience, I do not thing this was extremely difficult. I'm 66. Took my time, and it came up ok.
jimjarvis - Réponse
By the way, a heavy guitar pick works well as an alternative to a spudger. Keep one rounded and file another one to a point for removing the cable connections/ zif connections etc. I have been using these now for a few repairs and they work really well.
Steve - Réponse
Be very carefull and bee patience. It´s very helpfull to have something like the ifixit magnetic project mat to keep the screws in order, otherwise you will have a hard time to put the parts together.
Guenther Roppele - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 15
30 derniers jours : 67
Total : 121,790
