Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MacBook Pro 15" Core Duo Model A1150 Airport Extreme Replacement
Ce dont vous avez besoin
  1. MacBook Pro 15" Core Duo Model A1150 Airport Extreme Replacement, Battery: étape 1, image 1 de 1
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
    Demander à FixBot
    Ajouter un commentaire
  2. MacBook Pro 15" Core Duo Model A1150 Airport Extreme Replacement, Memory Door: étape 2, image 1 de 1
    • Remove the three identical Phillips screws from the memory door.
    • Make sure to record which sets of screws came from where. This will help when re-assembling.
    Demander à FixBot
  3. MacBook Pro 15" Core Duo Model A1150 Airport Extreme Replacement: étape 3, image 1 de 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
    Demander à FixBot
  4. MacBook Pro 15" Core Duo Model A1150 Airport Extreme Replacement, Upper Case: étape 4, image 1 de 1
    • Remove the two Phillips screws in the battery compartment near the latch.
    Demander à FixBot
  5. MacBook Pro 15" Core Duo Model A1150 Airport Extreme Replacement: étape 5, image 1 de 1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
    Demander à FixBot
  6. MacBook Pro 15" Core Duo Model A1150 Airport Extreme Replacement: étape 6, image 1 de 1
    • Remove the four Phillips screws on the port side of the computer.
    Demander à FixBot
  7. MacBook Pro 15" Core Duo Model A1150 Airport Extreme Replacement: étape 7, image 1 de 1
    • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
    Demander à FixBot
  8. MacBook Pro 15" Core Duo Model A1150 Airport Extreme Replacement: étape 8, image 1 de 1
    • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
    Demander à FixBot
  9. MacBook Pro 15" Core Duo Model A1150 Airport Extreme Replacement: étape 9, image 1 de 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
    • Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
    Demander à FixBot
  10. MacBook Pro 15" Core Duo Model A1150 Airport Extreme Replacement: étape 10, image 1 de 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
    Demander à FixBot
  11. MacBook Pro 15" Core Duo Model A1150 Airport Extreme Replacement, Airport Extreme: étape 11, image 1 de 1
    • Disconnect the two antenna cables attached to the Airport Extreme card.
    • The white antenna cable connects to the left side of the Airport Extreme card.
    Demander à FixBot
  12. MacBook Pro 15" Core Duo Model A1150 Airport Extreme Replacement: étape 12, image 1 de 1
    • Remove the single silver Phillips screw located just above the Airport Extreme card.
    Demander à FixBot
  13. MacBook Pro 15" Core Duo Model A1150 Airport Extreme Replacement: étape 13, image 1 de 1
    • Lift the small silver metal retaining bracket up and out of the computer.
    • Peel back the orange tape on the right side of the Airport Extreme card.
    Demander à FixBot
  14. MacBook Pro 15" Core Duo Model A1150 Airport Extreme Replacement: étape 14, image 1 de 1
    • Lift the Airport Extreme card up and slide it out of its connector.
    Demander à FixBot
53 autres ont terminé cette réparation.
iRobot
Membre depuis le 09/24/09
1 Réputation
636 tutoriels rédigés
2 commentaires de tutoriel
Ice cube trays work impeccably for these kinds of jobs!
Bijouxself - Réponse Partager
Great guide!
Tucker Harmon - Réponse Partager
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 24
30 derniers jours : 109
Total : 61,509
