Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MacBook Pro 15" Core Duo Model A1150 Display Assembly Replacement
Ce dont vous avez besoin
    1. MacBook Pro 15" Core Duo Model A1150 Display Assembly Replacement, Battery: étape 1, image 1 de 1
      • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
      Demander à FixBot
      Ajouter un commentaire
    1. MacBook Pro 15" Core Duo Model A1150 Display Assembly Replacement, Memory Door: étape 2, image 1 de 1
      • Remove the three identical Phillips screws from the memory door.
      • Make sure to record which sets of screws came from where. This will help when re-assembling.
      Demander à FixBot
    2. MacBook Pro 15" Core Duo Model A1150 Display Assembly Replacement: étape 3, image 1 de 1
      • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
      Demander à FixBot
    1. MacBook Pro 15" Core Duo Model A1150 Display Assembly Replacement, Upper Case: étape 4, image 1 de 1
      • Remove the two Phillips screws in the battery compartment near the latch.
      Demander à FixBot
    2. MacBook Pro 15" Core Duo Model A1150 Display Assembly Replacement: étape 5, image 1 de 1
      • Remove the following 6 screws:
      • Two 10 mm T6 Torx screws on either side of the RAM slot.
      • Four 14.5 mm Phillips screws along the hinge.
      Demander à FixBot
    3. MacBook Pro 15" Core Duo Model A1150 Display Assembly Replacement: étape 6, image 1 de 1
      • Remove the four Phillips screws on the port side of the computer.
      Demander à FixBot
    4. MacBook Pro 15" Core Duo Model A1150 Display Assembly Replacement: étape 7, image 1 de 1
      • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
      Demander à FixBot
    5. MacBook Pro 15" Core Duo Model A1150 Display Assembly Replacement: étape 8, image 1 de 1
      • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
      Demander à FixBot
    6. MacBook Pro 15" Core Duo Model A1150 Display Assembly Replacement: étape 9, image 1 de 1
      • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
      • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
      • Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
      Demander à FixBot
    7. MacBook Pro 15" Core Duo Model A1150 Display Assembly Replacement: étape 10, image 1 de 1
      • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
      • Remove the upper case.
      Demander à FixBot
    1. MacBook Pro 15" Core Duo Model A1150 Display Assembly Replacement, Display Assembly: étape 11, image 1 de 1
      • Disconnect the two antenna cables attached to the Airport Extreme card.
      • The white antenna cable connects to the left side of the Airport Extreme card.
      Demander à FixBot
    2. MacBook Pro 15" Core Duo Model A1150 Display Assembly Replacement: étape 12, image 1 de 1
      • Deroute the Airport antenna cables from their channel in the left speaker.
      Demander à FixBot
    3. MacBook Pro 15" Core Duo Model A1150 Display Assembly Replacement: étape 13, image 1 de 1
      • Disconnect the iSight, inverter, and left fan cables from the logic board by gently pulling in the direction of each cable.
      Demander à FixBot
    4. MacBook Pro 15" Core Duo Model A1150 Display Assembly Replacement: étape 14, image 1 de 1
      • Disconnect the display data cable from the logic board.
      Demander à FixBot
    5. MacBook Pro 15" Core Duo Model A1150 Display Assembly Replacement: étape 15, image 1 de 1
      • Remove the silver T6 Torx screw securing the ground loop on the display data cable to the casing.
      Demander à FixBot
    6. MacBook Pro 15" Core Duo Model A1150 Display Assembly Replacement: étape 16, image 1 de 1
      • Support the display with one hand while removing the following 3 screws:
      • Two 9.5 mm silver T6 Torx screws with threads on only part of the shaft on the inside of the display hinges.
      • One 9.5 mm silver T6 Torx screw with threads on the entire shaft on the outside of the left hinge.
      Demander à FixBot
    7. MacBook Pro 15" Core Duo Model A1150 Display Assembly Replacement: étape 17, image 1 de 1
      • Grasp the display assembly on both sides and lift it up and out of the computer.
      Demander à FixBot
26 autres ont terminé cette réparation.
iRobot
Membre depuis le 09/24/09
1 Réputation
635 tutoriels rédigés
1 commentaire de tutoriel
Worked well. Does the fan connector need to be disconnected? Step 13.
drknapp - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 52
Total : 65,213
