Introduction
Replacing a defective fan is pretty easy and will keep your laptop running cool.
Ce dont vous avez besoin
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the two Phillips screws in the battery compartment near the latch.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
Disconnect the iSight, inverter, and left fan cables from the logic board.
105 autres ont terminé cette réparation.
4 commentaires de tutoriel
Thanks for the great instructions on replacing the left fan. Everything worked to perfection and I even put my MacBook Pro back together again without any trouble or missing parts. :) The excessive heat on the machine is gone and I am smiling again.
Also, excellent service on the order and delivery time which was much appreciated.
Cheers, Lowell
Very useful instructions.
I had a very noisy fan and so pulled my macbook apart and cleaned dust out. However, when I put back together, the fan didn’t work at all!!
Started looking at buying a replacement, then had an idea. Took it apart again, and this time I put a small amount of HAIR CLIPPER OIL on the fan’s axel!!
Put it all back together and now have a perfectly functioning, quiet fan again!
