Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement
Ce dont vous avez besoin
  1. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement, Battery: étape 1, image 1 de 1
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
    Demander à FixBot
    Ajouter un commentaire
  2. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement, Memory Door: étape 2, image 1 de 1
    • Remove the three identical Phillips screws from the memory door.
    • Make sure to record which sets of screws came from where. This will help when re-assembling.
    Demander à FixBot
  3. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 3, image 1 de 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
    Demander à FixBot
  4. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement, Upper Case: étape 4, image 1 de 1
    • Remove the two Phillips screws in the battery compartment near the latch.
    Demander à FixBot
  5. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 5, image 1 de 1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
    Demander à FixBot
  6. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 6, image 1 de 1
    • Remove the four Phillips screws on the port side of the computer.
    Demander à FixBot
  7. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 7, image 1 de 1
    • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
    Demander à FixBot
  8. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 8, image 1 de 1
    • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
    Demander à FixBot
  9. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 9, image 1 de 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
    • Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
    Demander à FixBot
  10. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 10, image 1 de 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
    Demander à FixBot
  11. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement, Left Fan: étape 11, image 1 de 1
    • Disconnect the iSight, inverter, and left fan cables from the logic board.
    Demander à FixBot
  12. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 12, image 1 de 1
    • Use a spudger to flip up the brown plastic flap securing the left ambient light sensor cable to the logic board.
    • Slide the left ambient light sensor cable to the left and out of its connector.
    Demander à FixBot
  13. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 13, image 1 de 1
    • Peel up the left ambient light sensor cable from above the left fan.
    Demander à FixBot
  14. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 14, image 1 de 1
    • Peel up the iSight and inverter cables from above the left fan, removing tape as necessary.
    Demander à FixBot
  15. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 15, image 1 de 1
    • Remove the following 3 screws:
    • One 6.2 mm black T6 Torx screw from the right side of the fan.
    • Two 9.4 mm silver T6 Torx screws from the left side of the fan.
    Demander à FixBot
  16. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 16, image 1 de 1
    • Lift the lift fan up and carefully peel up the tape securing the fan to the heat sink as you go.
    Demander à FixBot
  17. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement, Left I/O Board: étape 17, image 1 de 1
    • Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
    Demander à FixBot
  18. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 18, image 1 de 1
    • Disconnect the two antenna cables attached to the Airport Extreme card.
    • The white antenna cable connects to the left side of the Airport Extreme card.
    Demander à FixBot
  19. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 19, image 1 de 1
    • Remove the single silver Phillips screw located just above the Airport Extreme card.
    • Lift the small silver metal retaining bracket up and out of the computer.
    Demander à FixBot
  20. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 20, image 1 de 1
    • Peel back the orange tape on the right side of the Airport Extreme card.
    • Lift the Airport Extreme card up and slide it out of its connector.
    Demander à FixBot
  21. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 21, image 1 de 1
    • Peel up the orange hard drive cable from above the ExpressCard cage.
    Demander à FixBot
  22. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 22, image 1 de 1
    • Disconnect the speaker cable from the corner of the left I/O board.
    Demander à FixBot
  23. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 23, image 1 de 1
    • Remove the single black T6 Torx screw securing the left speaker.
    Demander à FixBot
  24. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 24, image 1 de 1
    • Lift the left speaker assembly out of its housing and place it in the area previously occupied by the left fan.
    Demander à FixBot
  25. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 25, image 1 de 1
    • Disconnect the large multi-colored power cable from the left I/O board.
    Demander à FixBot
  26. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 26, image 1 de 1
    • Remove the following 5 screws/standoffs:
    • Four black T6 Torx screws securing the left I/O board to the lower case.
    • One 4 mm standoff located between the audio jacks.
    Demander à FixBot
  27. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 27, image 1 de 1
    • Lift up the right side of the left I/O board and slide it out of the computer.
    Demander à FixBot
  28. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 28, image 1 de 1
    • Remove the following 4 screws:
    • Three 1.2 mm silver Phillips with large heads.
    • One 3.2 mm black Phillips on the left side.
    Demander à FixBot
  29. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 29, image 1 de 1
    • Lift the left I/O board off the ExpressCard cage.
    Demander à FixBot
  30. MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement: étape 30, image 1 de 1
    • Disconnect the short left I/O board cable.
    • Left I/O board remains.
    Demander à FixBot
19 autres ont terminé cette réparation.
iRobot
Membre depuis le 09/24/09
1 Réputation
636 tutoriels rédigés
2 commentaires de tutoriel
Just curious what the short cable's purpose is? I have a Macbook this model and the battery is not charging. Before I go down the path of changing out the whole board is it worth replacing just this cable?
adamstafford - Réponse Partager
What are the symptoms of needing to replace this board?
jeff7 - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 68
Total : 36,710
