Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MacBook Pro 15" Core Duo Model A1150 Speakers Replacement
Ce dont vous avez besoin
    1. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement, Battery: étape 1, image 1 de 1
      • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
      Demander à FixBot
      Ajouter un commentaire
    1. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement, Memory Door: étape 2, image 1 de 1
      • Remove the three identical Phillips screws from the memory door.
      • Make sure to record which sets of screws came from where. This will help when re-assembling.
      Demander à FixBot
    2. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 3, image 1 de 1
      • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
      Demander à FixBot
    1. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement, Upper Case: étape 4, image 1 de 1
      • Remove the two Phillips screws in the battery compartment near the latch.
      Demander à FixBot
    2. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 5, image 1 de 1
      • Remove the following 6 screws:
      • Two 10 mm T6 Torx screws on either side of the RAM slot.
      • Four 14.5 mm Phillips screws along the hinge.
      Demander à FixBot
    3. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 6, image 1 de 1
      • Remove the four Phillips screws on the port side of the computer.
      Demander à FixBot
    4. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 7, image 1 de 1
      • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
      Demander à FixBot
    5. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 8, image 1 de 1
      • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
      Demander à FixBot
    6. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 9, image 1 de 1
      • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
      • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
      • Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
      Demander à FixBot
    7. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 10, image 1 de 1
      • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
      • Remove the upper case.
      Demander à FixBot
    1. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement, Speakers: étape 11, image 1 de 1
      • Disconnect the display data cable from the logic board.
      Demander à FixBot
    2. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 12, image 1 de 1
      • Peel up and remove the orange foil shield near the right speaker.
      Demander à FixBot
    3. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 13, image 1 de 1
      • Remove the silver T6 Torx securing the ground loop in the display data cable to the casing.
      Demander à FixBot
    4. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 14, image 1 de 1
      • Rotate the speaker clockwise approximately 30 degrees until it comes free from the logic board.
      Demander à FixBot
    5. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 15, image 1 de 1
      • Peel up the gray and black speaker wires from the top of the logic board, removing tape as necessary.
      Demander à FixBot
    6. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 16, image 1 de 1
      • Use a spudger to flip up the brown plastic flap securing the left ambient light sensor cable to the logic board.
      • Slide the left ambient light sensor cable to the left and out of its connector.
      Demander à FixBot
    7. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 17, image 1 de 1
      • Peel up the left ambient light sensor cable from above the left fan.
      Demander à FixBot
    8. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 18, image 1 de 1
      • Disconnect the two antenna cables attached to the Airport Extreme card.
      • The white antenna cable connects to the left side of the Airport Extreme card.
      Demander à FixBot
    9. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 19, image 1 de 1
      • Remove the single silver Phillips screw located just above the Airport Extreme card.
      • Lift the small silver metal retaining bracket up and out of the computer.
      Demander à FixBot
    10. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 20, image 1 de 1
      • Peel back the orange tape on the right side of the Airport Extreme card.
      • Lift the Airport Extreme card up and slide it out of its connector.
      Demander à FixBot
    11. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 21, image 1 de 1
      • Disconnect the orange hard drive ribbon cable from the logic board.
      Demander à FixBot
    12. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 22, image 1 de 1
      • Peel up the orange hard drive ribbon from above the ExpressCard cage.
      Demander à FixBot
    13. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 23, image 1 de 1
      • Disconnect the speaker cable from the front right corner of the left I/O board.
      Demander à FixBot
    14. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 24, image 1 de 1
      • Remove the following 2 screws:
      • One 4.3 mm black T6 Torx screw on the left side of the speaker.
      • One 9.4 mm silver T6 Torx screw on the right side of the speaker.
      Demander à FixBot
    15. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 25, image 1 de 1
      • Lift the left and right speakers out of the computer.
      Demander à FixBot
    16. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 26, image 1 de 1
      • Remove the single silver Phillips screw securing the left ambient light sensor cover to the speaker.
      • Remove the clear plastic ambient light sensor cover.
      Demander à FixBot
    17. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: étape 27, image 1 de 1
      • Use a spudger to pry the left ambient light sensor board out of its housing on the left speaker.
      Demander à FixBot
4 autres ont terminé cette réparation.
iRobot
Membre depuis le 09/24/09
1 Réputation
636 tutoriels rédigés
1 commentaire de tutoriel
Step 14 was a bit tricky for me. Before you can rotate the speaker clockwise you need to lift up the transparent plastic cover so it's free from the speaker. Otherwise it was hard to turn it. If it has been there for a long time it can be jammed. Be careful.
Fredrik - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 52
Total : 16,501
