Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MacBook Pro 15" Retina Display Early 2013 I/O Board Cable Replacement
Ce dont vous avez besoin
    1. MacBook Pro 15" Retina Display Early 2013 I/O Board Cable Replacement, Lower Case: étape 1, image 1 de 1
      • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
      • Eight 3.0 mm
      • Two 2.3 mm
      Demander à FixBot
      Ajouter un commentaire
    2. MacBook Pro 15" Retina Display Early 2013 I/O Board Cable Replacement: étape 2, image 1 de 1
      • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
      • Set the lower case aside.
      Demander à FixBot
    1. MacBook Pro 15" Retina Display Early 2013 I/O Board Cable Replacement, Battery Connector: étape 3, image 1 de 1
      • Peel back the warning label covering the battery connector.
      Demander à FixBot
    2. MacBook Pro 15" Retina Display Early 2013 I/O Board Cable Replacement: étape 4, image 1 de 2 MacBook Pro 15" Retina Display Early 2013 I/O Board Cable Replacement: étape 4, image 2 de 2
      • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
      • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
      Demander à FixBot
    1. MacBook Pro 15" Retina Display Early 2013 I/O Board Cable Replacement, I/O Board Cable: étape 5, image 1 de 3 MacBook Pro 15" Retina Display Early 2013 I/O Board Cable Replacement, I/O Board Cable: étape 5, image 2 de 3 MacBook Pro 15" Retina Display Early 2013 I/O Board Cable Replacement, I/O Board Cable: étape 5, image 3 de 3
      • Using the flat end of a spudger, pry the I/O board cable straight up out of its socket on the I/O board.
      • In a similar fashion, remove the I/O board cable from its socket on the I/O board.
      Demander à FixBot
    2. MacBook Pro 15" Retina Display Early 2013 I/O Board Cable Replacement: étape 6, image 1 de 1
      • Remove the I/O board cable from the MacBook Pro.
      Demander à FixBot
Sam Goldheart
Membre depuis le 10/18/12
478 233 Réputation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
122 membres
86 241 tutoriels rédigés
1 commentaire de tutoriel
Will this work with a mid-2012 15” MacBook Pro Retina as well?
Andy - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 34
30 derniers jours : 68
Total : 6,205
