Introduction
Use this guide to replace a broken or noisy left fan in your MacBook Pro 15" Retina Display Late 2013. This fan is located on the left side of the computer, as seen when it is open and in use.
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.0 mm
Two 2.3 mm
Use the flat end of a spudger to lift the rubber heat sink cover up off the left fan.
17 autre(s) ont terminé cette réparation.
Un commentaire
Very handy and easy guide. No difficulties at all. The only problem i had was the replacement fan (bought on iFixit 2th hand). The screw openings where not exact as original (4mm of the left side bottom side of right fan), but i managed to first soft place the screws in and then all make them tighter. This was the only way it fits. Tested and approved. (you can even feel the broken fan as u hold it and turn it with your vacuum cleaner). Thanks to the author for his work. Happy client..
