Aller au contenu principal
Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014
Ce dont vous avez besoin
  1. Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014, Boîtier inférieur: étape 1, image 1 de 1
    • Dévissez les vis Pentalobe P5 suivantes fixant le boîtier inférieur au MacBook Pro :
    • Huit vis de 3,0 mm
    • Deux vis de 2,3 mm
    To remove the back panel there are two different pentalobe screws 2.3mm and 3mm however on the tools list there is only one screwdriver. Will I be able to remove both screws with the same screwdriver?
    lantzero - Réponse
    The 2.0 and 2.3 mm measurements are screw lengths, the screw heads are the same sized P5 pentalobe heads. We include the screw lengths so you don't put the wrong screws in the wrong places and end up with screw heads poking out of your device. Hope that clears up some confusion =)
    Sam Goldheart -
    Yes the same screwdriver will remove both screws, the difference in screws I believe is the length and width but the head is the same.
    Mike -
    Just be careful to store the 2 shorter screws in a seperate space then the other 3mm screws.
    The first time I opened up my Macbook, I put the screws in the wrong order.
    Shahzad Arif -
    Woohoo, much easier than I thought... Just got confused with the bottom case screw driver but after figure out it was P5 then everything went smooth.... One thing I wanted to upgrade was the wifi to ac and got one on ebay!
    didierma - Réponse
    If you have 54 Bit Driver kit, please use Star 5 driver to remove screw for rMBP 2012 Late
    iyeori - Réponse
    It took about 40 minutes due to an extreme measure of caution but I did it! The only real difficulty was reattaching the screen to the base (yes you have to pry the hinges open) and re-connecting the camera wires. After a few tries the camera wires finally came together. I'm hating Apple for all it's frailty and magical screws but I love ifixit!
    floyd - Réponse
    Simple guide, but it solved my problem. Was wondering why the top two screws weren't going all the way down. Hadn't realized they were 0.7mm shorter.
    Emilio Mejia - Réponse
    I have BootCamp running Win7 on my MBPwRetina15" 2013'Late. I run Visual Studio to build and run my Company's Application which is very CPU & NVidia (specific) intensive. So much so that during a build & run of app I was averaging about 85~95+Celcius!!! And every so often would reach 100Celcius!!! I could not take it anymore so I decided to delve into and re-apply Thermal Paste on the CPU/GPU. I ended up going with CooLaboratory Liquid Pro instead of the traditonal AS5. The original Thermal Paste was pure garbage,,, part of the CPU seemed like it was missing TP. I was scared to do this but it turned out easier than I had imagined. I am currently building the same application and can already observe that the temps average about 75~85 and once in a while will reach 90Celcius. So I am seeing about a 10~15 degree drop in Temps and that makes me very happy!
    Alvaro Suarez - Réponse
    Nice to hear that, i was looking for that kind of information. I have a MBPwRetina 15 Mid 2012 and looking to obtain the best performance!
    Jose David Valle -
    Woa! Thanks dude! And you follow some guides here for the thermal paste? My mac 15’’ early 2013 heats up a lot but I’m a bit worried about touching anything
    Bert0ld0 -
    Much easier than expected. Sounds like several people had trouble with the backlight. It is possible that they damaged something by not first making sure to power down the computer completely with the “Shut Down” command. This should be step 1 before removing the back cover screws. Also as noted all the back cover screws are Apple Pentelope #5 bit, but 2 of the screws are shorter than the others. This bit is is hard to find in most stores. Buy it on line along with the Tork #5 and #8. 11/21/2017
    Walt Goede - Réponse
    Not sure if this has been listed.
    PRO TIPS from a non-pro:
    1 - Keep screws separated and labeled by step # and size.
    2 - Be very careful to get screws in properly threaded, its VERY easy to strip the ccrew holes and screws. Especially the case. Not that it happened to me…
    3 - It was impossible for me to get all the adhesive off the case from under battery, it left a lot on w/o issue (yet).
    4 - Make sure you have Aluminium Foil before starting!
    5 - Upgrade the SSD or HDD while your in there!
    erin - Réponse
    Do we remove the logic board purely to get the speaker enclosures out and away from the acetone? Or does it physically block getting the batteries out? Ie. if I wanted to risk the damage to the speakers, could I jump straight to step 34?
    Obviously I don’t want to melt the speakers, but I’m kinda weighing that risk against losing a screw or breaking a connector…
    Michael Ferenduros - Réponse
    So I did take the risk and swapped out the battery without doing the logic-board + speaker removal.
    Before applying the acetone I put tape on the exposed sides of the speaker-enclosures as best I could - I wrapped the tape, sticky side out, around a card, slid it into the gap, and pressed it onto the speakers. And when applying the acetone, I squirted it as gently as possible onto the side of the battery and let it run down the side, which seemed to help avoid getting too much on the speakers.
    The speaker’s plastic turned white in the spots where the acetone touched it, but it looked like surface damage only. Otherwise it was a nice and smooth procedure.
    Your milage may vary, obviously.
    I changed the battery pack as well without removing the logic board etc. It helped, that the batteries already were swollen, thus access to the glue stripes was easier. It works, if you give a little tension, pulling a pack upwards, and then work with a small blade or knife, and cut the glue stripes. It may take a while, but much less time than dismantling the whole macbook. If you don’t hurry, and don’t apply too much force, you will not damage anything. Beside the 10 cover screws you only have to loose 2 screws for the battery connector. After removing the old pack I used Methanol to remove the glue. I prefer this solvent to Acetone, because it’s less or not harmful to plastic (however, no warranty, just my personal experience). I was able to finish the work in 40 minutes, although it was the first time I opened my Macbook. Well, I am an engineer, that helps, but with dismantling all boards it definitely would have taken double the time. And more risks to break a plug or make a mistake while reassembling.
    Heinrich Jung -
    Success. I needed to replace the right speaker. I thought I was ready at step 22 (you are able to replace the left speaker at this point… but but the right) To replace the right I continued thru step 29 but didn’t completely remove the motherboard. I just lifted it enough to remove and replace the right speaker cable.
    Read all of the comments and solved many problems. Thanks to I-fixit, Walter Galen and all who posted comments.
    Will Brecht - 03/02/2019
    Will Brecht - Réponse
    1/2
    If you're taking the shortcut (nylon, wire…and no adhesive for battery removal (you'll def need to remove the adhesive once the battery pack is removed) things to note:
    1 The adhesive may still be pretty strong. Mine was and I broke several wires trying to do the cheese cutter move down the back of the middle two batteries
    2 if you're cheese cutting through the adhesive, when you get to the base, don't go too far. I did and severed the battery cell connector… disconcerting puff of smoke.
    Ruairi Kennedy - Réponse
    If you get a puff of smoke removing a bad battery which is going to be replaced it really doesn’t matter, its being replaced.
    robert -
    2/2
    3 the you tube video dude was lucky not to have his two Central batteries adhered . Mine were stuck fast.
    4 don't forget about the two small T 5 screws to the left and right of the battery head board, just below the main battery connector.
    5 the Track Pad sits behind the two central batteries. The batteries are adhered to a flat plate that protects the Track Pad which is pretty resilient. You can do the cheese wire trick without cutting through anything you shouldn't. However be careful if you're using a spudger or other tool between the two centre batteries at the top of the T. This is where the Track Pad connector (its very flat and exposed) to the motherboard.
    6 seems obvious when it's written , but you will need the adhesive remover if you are interested in removing the adhesive. It's a work out.
    I just completed this successfully. The guide was great, and I recommend reading each of the steps’ comments, too. It is possible to cut out a majority of the steps outlined here if you’d rather not dismantle most of your laptop. As I’m a novice and this was the first difficult fix I’d ever tried, the idea of taking so many things apart — including removing the logic board — was a little scary. Everyone calculates risk and reward differently, but for me, the risk of removing the logic board for the reward of being able to remove the battery packs with adhesive remover was too great, so I opted to only do steps 1–4, 42–53 and removed the battery with one of the cards from iFixit’s kit. If you go this route, expect it to be a little frustrating & slow going — it took me around 20–30 minutes of slowly chipping away at the adhesive with only the card. There are other techniques out there (wire, fishing line, etc.) and I’d advise looking into them. Keep track of screws: tape, draw out diagrams, label them, etc.
    Jake Thornberry - Réponse
    I only removed the 10 screws and the back panel, the 5 speaker’s screws (without removing the speakers), and the two battery screws, and managed to remove the battery package without undoing anything else. I used a member card (credit card type) to loosen the adhesives under the batteries.
    To remove the rest of the glue, I soaked it with something called Label Off from Biltema (Nordic). Finally, I used methylated spirit (rødsprit) to clean it all up and let it dry for 5 minutes before assembling the new battery pack.
    Andreas H. Parlow - Réponse
    I have now replaced the battery and the dc-in board, and I still can’t get the battery to charge. I also bought a new magsafe power adapter. It appears all cables are connected, and the computer runs fine on the battery (until it runs out of juice, then I will be at a complete loss). No clue what to try next. Any suggestions? Thanks!
    matt rogers - Réponse
    Why do you need to remove the entire logic board??? Seems like if you detach the appropriate cables, remove the speakers, that that should be enough. Removing the entire board doesn’t seem necessary - what am I missing?
    Sandwah - Réponse
    What on earth are you talking about? This has nothing to do with the logic board.
    Trevor Picard -
    The speaker cables are routed under the logic board, or at least the right-side one is. I found that if you can undo the fastenings on one side of the logic board you MIGHT be able to lever it up and work the speaker wire out without taking the entire thing out.
    bobthrollop.redirect -
    MacBook Pro 15“ 2014:
    if the keyboard is connected nothing works. I disconnected the keyboard and the MacBook was starting automatically. An external usb keyboard is not working either. Is something on the logic board defective or is this failure (usb keyboard not working) because of the disconnected keyboard and the system is confused?
    any idea for this?
    ps: the battery is loading
    Pättes - Réponse
    MacBook Pro 15” Mid 2012
    I had the exact same symptom upon initial completion. The keyboard ribbon is actually 2 pieces on mine. There is a plastic cover sheet (that I tried to use as the ribbon the first time) and then there is the actual ribbon sheet. The keyboard works perfectly now that I have the actual ribbon sheet inserted into the the ZIF connector.
    It took entirely too long. I was being very careful. Recovery of the keyboard took me less than an hour. I don’t want to admit how long the original work took me.
    I hope you already have yours working. I was very careful due to not having an alternate device for my son to use if the work had failed. The other likely point of failure for the keyboard is damage to the ribbon as it goes under the battery pack. I caught myself almost poking too hard on that spot.
    EEM -
    You should more clear explain that it is possible to skip the steps 5-35 in the beginning explanation text.
    ( I lost many time to remove parts and there is also more risk to destroy some connectors ?‍♂️)
    Muescha - Réponse
    Like many others here, I completed the battery replacement by skipping steps 5-52 and instead removing the battery cells with the “cheese cutter” method. I made my cutter from 20# braided monofilament tied to two 4” wooden dowels (3/8” diameter). I carefully applied 97% isopropyl alcohol to the taut mono with a small artist’s brush. I took my sweet time cutting through the glue, but all in all not too difficult, just tedious. I was super careful and mindful of the fire and explosion hazard, and took necessary precautions. One thing to be careful of using the cheese cutter method is to be sure the mono is is really under the cell package and not just in front of it before sawing away. There are some tight spaces that make this tricky. Once the battery was out I used the iFixit acetone to clean up the glue leftover by carefully applying drops on the strips and letting capillary action take over. After waiting about five minutes, the glue strips could be picked up with the supplied tweezers.
    Acme Nerd Games - Réponse
    Hallo Leute, hab das Akku eben erfolgreich bei meinem MacBook getauscht ohne alles vorher auszubauen. WICHTIG: kein ACETON zum Kleber lösen verwenden! Sonst gehen die Lautsprecher kaputt! Auch kein Orangenpower oder ähnliches! Man nehme sich ein dünnes hochzugfestes Nylonband (oder Zahnseide geht auch) und schneide damit die alten Klebepads sägebandmäßig los.
    Also:
    In der Hoffnung mich so klar wie möglich auszudrücken war das Folgende meine Vorgehensweise:
    1. Deckel ab, Achtung die Schrauben mittig unterm Bildschirm sind kürzer!
    2. Akkustecker trennen und vorsichtig umbiegen
    3. die 2 Schrauben, die die Batterie in der Nähe des Steckers halten losschrauben
    4. nun mit zugfestem Band die Akkus rausschneiden
    die im Fix-Kit beigelegten Spatel können dabei unterstützen
    die übrigbleibenden Klebereste können einfach mit einem der Plastikwerkzeuge abgemacht werden: erst ein bisschen mit einem Spatel vorarbeiten, sodass man es mit seinen Fingen greifen kann, dann langsam und Richtung weg vom Logikboard vorsichtig abziehen.
    Jérôme Achilles - Réponse
    Was dann noch an Kleberesten übrigbleibt, kann wegen mir auch bleiben. Sonst mit 1-2 Tropfen Lösemittel auf ein Microfasertuch geduldig nach und nach wegwischen. Und Wirklich nur WENIGE TROPFEN verwenden! Sonst gehen die Lautsprecher wohlmöglich kaputt.
    5. Mithilfe von Druckluft (2-3 bar! nur) nun sämtlichen Staub vorsichtig rausblasen. VORSICHT: Die Lüfter dürfen sich dabei nicht drehen! Die erzeugen sonst Spannung und grillen wohlmöglich das Logikboard!
    6. Neues Akku (Folien dabei vom Akku entfernen) reinsetzen und gleich an die Schraubenlöcher ausrichten.
    7. Die 2 Schrauben für die Batterie reinschrauben und mit Gefühl anziehen.
    Die packs einzeln auf ihren richtigen Sitz hin prüfen
    8. Wenn alles sauber ist und alles richtig sitzt, dann den Batteriestecker wieder auf das Logikboard stecken
    9. Deckel drauf. Der Deckel muss von alleine, ohne Schrauben richtig in seiner Ausfräsung liegen. Steht irgendeine Ecke hoch, ist darunter was verkehrt.
    10. Deckel festschrauben. ACHTUNG: 2 Schrauben sind kürzer auf der Seite des Bildschirms!
    Missverständnisse kann ich nicht ausschließen. Darum folgt ihr dieser Anleitung bitte nur auf eigenes Risiko. Ich übernehme keine Haftung für Schäden! Viel Erfolg!
    Hi guys, just successfully replaced the battery on my MacBook without removing everything first. IMPORTANT: do not use ACETON to loosen the glue! Otherwise, the speakers will be broken! Also no orange power or similar! Take a thin high-tensile nylon tape (or dental floss also works) and cut the old adhesive pads loose. Similarly as with a saw tape.
    So:
    Hoping to express myself as clearly as possible, the following was my procedure:
    1. remove the lid, beware that the screws in the center under the screen are shorter!
    2. disconnect the battery connector and carefully bend it over
    3. unscrew the 2 screws that hold the battery near the plug
    4. now cut out the batteries with tension-proof tape
    the spatulas included in the fix-kit can help you to do this
    the remaining glue can be easily removed with one of the plastic tools: first work a little bit with a spatula so that you can grip it with your fingers, then slowly and carefully pull it off in a direction away from the logic board.
    Whatever glue remains can stay because of me. Otherwise, patiently wipe away little by little with 1-2 drops of solvent on a microfiber cloth. And really only use FEW DROPS! Otherwise, the speakers may break.
    Now carefully blow out all dust with compressed air (2-3 bar! only). CAUTION: The fans must not rotate! Otherwise, they will generate voltage and possibly fry the logic board!
    Insert the new battery ( thereby remove the foils from the battery) and align it to the screw holes. 7.
    Screw in the 2 screws for the battery and tighten them with feeling.
    Check the packs individually for proper fit
    8. if everything is clean and everything fits correctly, put the battery connector back on the logic board.
    9. put the lid on. The cover must lie correctly in its groove by itself, without screws. If any corner is sticking up, there is something wrong underneath.
    10. screw the cover. ATTENTION: 2 screws are shorter on the side of the screen!
    I cannot exclude misunderstandings. Therefore, please follow these instructions only at your own risk. I assume no liability for damages! Good luck!
    Another vote for skipping step 34 after step 4. When I tried to reinstall the new battery, I couldn't get the two step 34 screw holes lined up and still be able to connect the battery cable, so I just left them out. Also, one of the bottom cover screws went AWOL.
    I think that anyone with a badly swollen battery can skip to 34 because the battery has already done a lot of the work. I doubt that I used more than a dozen drops of remover, if that. A bit of patience and careful work with dental floss did the trick. Maybe 30-40 minutes to get the old battery out and another 10 to peel off the remaining adhesive.
    schendel - Réponse
    Like most have suggested here, definitely read through all of these comments! I learned valuable tips from other commenters above that made this repair easy. Also like many others here, I opted to skips the majority of steps, and instead focused on steps 1-4, 36-53. When removing the small screws from the back plate, make sure to keep them organized and away from the computer. Because they are slightly magnetic, one of the tiny top middle screws magnetized to the MagSafe charger port my my Mac and I spent 20 minutes thinking it fell on the floor.
    I had a nylon thread handy to get some of the packs started. Even with applying the adhesive remover, I found the plastic card iFixit provides was not always strong enough to get the pack started. Cheese cutter method was all it needed to get started!
    Make sure to elevate your Mac when applying the remover in whatever direction you want the remover to run. Make sure to test new battery before committing to the new adhesive in case it is faulty!
    Good luck!
    Patrick King - Réponse
    At step 9, when reinstalling the io board cable, make sure it is the correct way round as in the photo, it fits the wrong way round as well, which results in the MacBook not starting at all. It took me hours to find my mistake...
    Pierre Arnaud - Réponse
    This is just a suggestion or two to help those that might be doing this for the first time.
    1. Separate your screws by the component they came from, i.e. cover screws altogether, fan screws altogether etc. I used PostIt notes turned upside down and put the screws head down to hold them in place and then marked what they were and where they came from.
    2. If you have enough work space put the component next to the screws that were removed. Then you have everything located for an easy reinstall.
    Steve Rowe - Réponse
    The photographs in this guide show two slightly different MacBook Pro 15" Retina machines being disassembled, probably because the guide has multiple authors, and there is a subtle but very important difference between them. Look at the photo in Step 55. This shows the old battery being lifted out of the machine, it has six cells, and the battery connector is located in the centre of the top edge of the battery between cells 3 and 4. Now look at the photo in Step 3. This shows a battery connector which is offset by about 3cm and is above cell 4, not between cells 3 and 4. I believe the offset battery connector is from a mid 2012-early 2013 MacBook and the central battery connector is from a late 2013-mid 2014 MacBook. This is important because if you have the wrong battery, it won't work because the connector won't reach the socket. I found this out to my cost when I bought a battery which the seller told me was the right one, it turned out to be the wrong one, and then I couldn't return it.
    Peter Gray - Réponse
  2. Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014: étape 2, image 1 de 1
    • En commençant par le bord le plus proche de la charnière, ôtez le boîtier inférieur du MacBook Pro.
    • Mettez le boitier inférieur de côté.
    Does anyone noticed that the bottom cover and the bottom case is actually linked with the black plastic near the battery?! After the first time you open the cover, it will be impossible to put it back to the original place. Does the critical?! Thanks a lot for informing
    jamiegan835 - Réponse
    I was able to simply push and click those clips back into place before I did the screwing.
    Tim Peat -
    I truly believe this is placebo and the 10*C difference is because in the process the dust was removed from the fan/heat sink rather then the thermal "magic" paste.
    This is a "PC" habit.
    On the other hand, all the cases and protections out there have a bad effect on cooling (not sleeves or pouches) because the whole aluminum body helps dissipate heat.
    I've never had any problems with any mac regarding heat (they do get hot, but it is OK).
    Whenever you feel heat from electronic device means the heat radiates away from it.. which means the cooling is doing a good job :).
    crus - Réponse
    Hey,
    Writing about dust and dirt, do you know any cleaning products for the interior of the mac. i mean how do you clean your laptop, pc, etc..
    Regards
    Jose David Valle -
    This is untrue. Over time thermal paste will dry up and crack and not provide good coverage between the device and the cooler. The paste massively improves the thermal transfer between the chip and the heatsink. If you do not believe in the magic paste then you should wipe it all off and apply just a little bit or none at all and then compare temperatures. You will see the paste is responsible for a big reduction in temperature.
    Andrew Fox -
    I was able to remove all screws but lower case is not comming off easly. Is it glued to somthing?
    Thanks for help.
    c4rlosv8 - Réponse
    There are two clips in the centre which simply unclip with a little force.
    Tim Peat -
    If you are following this how-to because liquid/coffee splashed in through the back vents, WAIT UNTIL THE END to clean any liquid spills on the bottom panel. Use them as your map for cleaning and QA guide for checking until you are finished with your cleanup of logic board and other items.
    auntialias - Réponse
    There are a couple of small rectangular magnets (~ 1/2” long) that are sitting in pockets near the battery warning label. (One is visible in the Step 3 pic.) One of these left its pocket and was stuck to the bottom cover when I lifted it.
    Jon Scott - Réponse
    i had no idea my battery was swollen until i opened the back case to replace it. the back popped up right away on its own as soon as i took the screws out.
    elyze - Réponse
  3. Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014, Connecteur de batterie: étape 3, image 1 de 1
    • Tirez vers l'arrière l'autocollant d'avertissement qui recouvre le connecteur de batterie.
    For rMBP 2012 Late, you don't need to remove this sticker.
    iyeori - Réponse
    Have laptop charging issues after this. When fully charged and i plug in magsafe it starts with green, then turns red and stays red (like if it was charging). Status bar says NOT charging. If i use battery a little bit (down to 69%) magsafe does the same (green then stay red). Status bar says battery 69% NOT charging. and it seems to be true. Any suggestions?
    g000phy - Réponse
    Double check the connection from the battery to the logic board and the logic board socket itself... Might have damaged by disconnect/reconnect.
    max damage -
    This step is necessary to prevent any discharging, arcing, friction/static charges from damaging any of the extremely delicate and intricate parts of this (or most any) electrical system. In practice, you should even be wearing an anti-static band or be working on an anti-static bench even with the battery disconnected so your body doesn't create any unintentional charges.
    One of the first things you should learn in electronics repair and and electrical in general is to cut the power source whenever possible before performing any work. Some systems have schedulers/triggers set that will wake the system up (even when closed) to perform updates and other maintenance tasks as to not eat up CPU and RAM during 'peak hours'. The last thing you need is to have your $2,000 laptop turn on while pulling an SSD (which, correct me if wrong, isn't a plug-and-play based device) which could do some serious corruption and/or damage; when all you had to do was peel a sticker and plug.
    Hope that helps!!
    ~the more you know~
    Colin Devenney - Réponse
    I did not peel back the sticker. It is probably there to help unplug the battery. You can apply a gentle constant pull while you use spudger to lift the battery connector out of the socket as per the next step. It made this very easy.
    Achilles - Réponse
    I've found that it's actually better to NOT remove the sticker. I wish I had skipped that 'peel off the sticker part' ugh
    Miles Raymond -
    There is another connector here on mine, just to the left and up above the text on the battery sticker. It is an empty ZIPF socket on all these photos.
    Richard C - Réponse
    Let me stop you guys here. You can skip steps 5-35.
    That’s what I did without a problem.
    Go directly to step 35 after the next step. 5-35 is only so you have more room to pry the old battery off.
    If you are not keeping the old battery, then just pry it off with a flathead screwdriver.
    This is not a difficult fix.
    Chris - Réponse
    Chris,
    Thank you for providing the advise to skip several steps. I agree that you will have ample space to remove the old battery without removing everything else. I would like to provide a small correction in your directions. You will need to go to step 34 to remove the two screws holding the battery cable versus directly to step 35. You will not be able to completely remove the battery without this step.
    Laurence Rooks -
    I successfully followed all the instructions and all the steps in this guide. I installed the new battery successfully. However, looking back at the process now, I have no idea why I had to take out the memory, air card, speakers, fans, and motherboard to change the battery. None of that was necessary. I did it, and it worked out for me, but honestly, if you just want the battery out, do what Chris and Laurence said above me. Go straight to step 34.
    matthew.toledo - Réponse
    Again, that label will loose its stickyness... order B09WMWH3LM from Amazon so you can reglue - a little smear on both parts, let it dry a few seconds and join them. Done. ... a little will go a long way.
    Alex De Lara - Réponse
    I agree that this entire procedure is unnecessarily complex, unless you’d like to disassemble your entire laptop for the sheer fun of it. The point of all the disassembly is to avoid damage to other components from the adhesive remover. So what I did was not to pry at all, no leverage whatsoever, no strain on the battery cells. Instead, I simply slid the provided plastic scraper cards underneath the batteries from every side possible to begin removing the adhesive. Then I put one drop of the remover on each side of the card at the front edge so it was barely wet, slid it in and worked it deeper bit by bit…. When I got near the speakers, I pulled the screws, lifted them slightly, and wedged one of the picks under the long arm coming off each speaker to give it a few mm clearance from the case, so no remover/alcohol could wick underneath. That worked well for me; the hardest part was getting all the old adhesive off the case, which just took some careful soaking. Good luck! .
    Tor Matson - Réponse
  4. Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014: étape 4, image 1 de 2 Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014: étape 4, image 2 de 2
    • Avec l'extrémité plate d'une spatule (spudger), soulevez délicatement le connecteur de batterie vers le haut hors de sa prise sur la carte mère.
    • Repliez les câbles de la batterie vers l'arrière et de côté afin que le connecteur de batterie ne touche pas accidentellement la carte mère.
    I ordered the whole kit, but seeing how much tedious effort it was to take out so many parts so they wouldn't be damaged by the solvent, I skipped from here to step 34 and only used the supplied cards (credit-card sized) with patience and persistence to free the battery sections from the backing. Success! Then I used a q-tip to apply the solvent to remove the remnants of the adhesive from the aluminum case. My battery was very swollen, so it was like removing little pillows. I think the swelling may have helped to give me additional access with the cards to free it. Success! My MBP is back up and running, and now the trackpad clicks again and it sits flat on a table!
    Joel Replogle - Réponse
    So no need basically to unscrew all the mac
    Bert0ld0 -
    The best tool for battery removal for any glued in Apple batteries is a 6" PLASTIC puddy knife 1.5" or 1" in width. It is strong. It has a bit of a sharp edge to cut the glue. It is long enough to slide all the way from top to bottom on the middle cells and from the side to get the 2nd from the right and 2nd from the left out. Wear gloves doing this and eye protection. I've use the Nylon twine method also without removing the logic board, but that is a pain to get started. I just take the screws of of the speaker, lift them up, don't remove and go to work with the puddy knife.
    Chapman Gleason -
    Joel - the purpose of all of the trouble in removing the logic board is to make sure that you don’t damage anything when you start pull out the battery. After this step - it’s true, you have about 12 connectors and dozens of screws to unplug, but I didn’t have any major problems.
    REASSEMBLY - I had to use alot of force to get the official IFIXIT battery connect to push into place to actually connect. I was worried that one of the wires would stress and break. It worked, but it was not super easy this part.
    Jer - Réponse
    I also skipped down to step 50. I stuck a piece of 1/2 inch weather stripping across the middle of the top cover of the laptop to maintain a pitch on the unit so the adhesive remover stayed away from the other components. I applied the remover and used a piece of string to cut through the adhesive strips. I owed the plastic tool from the kit to position the string behind the top of each cell and cut through one ata a time. The battery came out in about 15 minutes. The directions were very informative and useful but I thought the risks associated with dismantling the laptop and reassembling it again were greater. I could not have done it without the details presented. Thank you.
    Thomas Horan - Réponse
    Couldn't agree more: use a wire to cut the glue. No need to remove anything else (I did remove the SSD for peace of mind). I used a thin metal wire, without the help of adhesive remover, wrapping it around two sticks to hold it (as pulling with your fingers is painful!). Took longer to clean the residue than to cut the glue!
    I'm not so mad with Apple's repairability considering that this method is viable.
    Eric Rannaud -
    Having broken a connector on a logic board in the past, I worried about all the steps. But I understand the disaster that can occur if cleaning fluid contacts the logic board. Weighing costs and benefits, I also did not remove the logic board. I loosened up the speakers (since only two screws could be removed) to give me space to slide the cards under the battery cells. Using the two cards, sometimes sliding one over the other, I was able to remove the battery in 15- 20 minutes. Removing the remaining adhesive was VERY tedious. Eventually I settled on CAREFULLY applying small amounts of remover with the syringe and using the spudger (both pointy and broad ends) to scrape the remainders off. I cleaned the residual with Q-tips dipped in remover (buy a big box of Q-tips), refastened the speakers, installed the new battery, closed the case and voila.
    James Suojanen - Réponse
    I too found the need to completely teardown the laptop onerous and risky. I’m not certified in anything hardware but I’ve been doing my own repairs for a while. I watched the video referenced above and read the comments there. With some changes, here is what I did, which worked perfectly and minimized the risk, for a whole additional $3 in parts, just myself and in under an hour:
    1. Go to hardware store and get 2 4” bolts ($1 each) and a coil of 20 gauage galvanized wire.
    2. Wrap one end of the wire a few times around one bolt, then tie it off with a knot. Do the same with the other bolt, leaving about 10” of wire between the two.
    3. Follow steps 1-4 in this guide
    4. Slip the wire under one of the outer batteries (use a card or spudger to help get the wire underneath
    5. Grip both bolts with one hand and rock them back and forth, pulling the wire under the battery, using your other hand to hold the case. This should take about 2 seconds (seriously). Repeat for other outer batteries
    (continued)
    steve - Réponse
    6. Pull the plastic frames away from the left and right sides of the center batteries.
    7. Repeat steps 4 and 5 for the two center batteries.
    8. Jump to step 55, then reassemble.
    Note: when installing the new battery, ensure the part closest to you is UNDER the two plastic tabs.
    Worked perfectly.
    Link to video: https://www.youtube.com/watch?v=fupkPz55...
    Note: using the nylon thread with that much effort is crazy. Use the wire or fishing line.
    steve - Réponse
    cool.
    removed everything and have now 88% after 2 times calibrating and smc reset
    wouldn’t have liked to do everything again, but this seems like a possible solution :)
    Dennis Britsch -
    i just got my Kit and started the procedure, i decided to try if i can get the bulged batteries out with a fishing line, which worked fine. No need to use any solvent and even not too much force was needed to get the line under the batteries. I was able to remove the batteries in about 5min, used another 10min to clean the case from the residue, and put in the new battery. All togehter about 20min of work. I´m very happy with the result, Macbook stays now back on its feet, closes correctly and trackpad works as expected.
    manu - Réponse
    Also departed from procedure immediately after STEP # 4 as per JOEL’s recommendation …used a small chunk of fishing line and it worked sans solvent…easily ! Spudger worked quite well to initially position the string /line & the ifixit ( ‘credit’ ) cards were nice for final dislodging of each battery segment from the last bits of residual gooey adhesive , AFTER working the fishing line back & forth down the length of the battery as much as possible. With the old battery out of the way, I used a razor blade to clean out the remaining bits of adhesive gunk. ( Decided NOT to use solvent here, either.) Took me every bit of 1-hour.
    One thing that helped ,too, was a cheap pair of cotton gloves coated on the palm side w/ latex. This kept my fingers comfortable from the pressure of the fishing line & allowed more of a range of force …since I wasn’t wincing from saw-cutting myself !
    John Joslin - Réponse
    I skipped steps 5-33. These steps are completely unnecessary. I used the back of a flat tweezers to separate the battery from the case.
    support64 - Réponse
    so the only reason they are taking all the stuff off before the battery is because of the solvent?
    I used cards and dental floss and just took the battery out … It was a pain in the butt but i got it out with out using the solvent remover solution.
    GR Verner - Réponse
    I skipped steps from 5 to 33 and directlychanged the battery (before disassembling all). Worked fine.
    derdietrich - Réponse
    I also skipped all the additional disassembly. I used cards and wire to cut through the adhesive quite easily. I also did not apply any tape on the new battery. The Mid-2014 laptop seems slim and tight enough to keep the cells from moving and the two screws at the power connector area seem to stabilize the connection and battery as a whole. Such STRONG tape seems unwarranted for the amount of squirm room in such a tight compartment.
    P.S. Remember, while you have it open, clean, clean, clean!!!
    jyee - Réponse
    Speaking of the power connector screws, I accidentally screwed down the R speaker flat cable on reassembly, which caused the speaker to malfunction. On finding that, I re-routed slightly and the speaker worked fine, this time, but I recommend being extra careful with that cable when putting things back together. You really do have to remove most everything to replace speakers!
    WillUseSpudger -
    Thanks guys for all the tips. I followed the pragmatic way of cutting short and really taking battery out only. Thanks to the cards it worked well and none of the liquid made it to any other part of the computer. Put some efforts in to properly clean the remaining glue after battery was out - but looked good and this message comes from the old mid 2012 15” Retina modell - but with the new battery in - and all is fine. I am happy - thanks to the short cut encouragement.
    Jochen Färber - Réponse
    Also skipped steps from 5 to 32. I used the supplied cards and a piece of string, i.e. braided nylon twine, (thickness 24). and used supplied acetone sparingly, mostly to the middle section. It took one and a half hours and another half hour or so for removing the leftover goo. It was demanding but not challenging, just take it slow and steady.
    jkobli - Réponse
    Learnt a lot from former comments. Also skipped steps from 5 to 54. Used fishing line to cut through adjective by myself easily, but needed to put on glove to protect hands. I didnt order full package, so used nail polish remover and eraser to clean the base. Looks good and all is fine! Thanks to the short cut method!
    Gerry GU - Réponse
    If you decide to skip to Step 34 or 52 or whatever, at least take note of Step 50. This is the only place I saw reference to the thin metal plate protecting the trackpad. I also skipped to just pulling out the batteries, but this plate came out with the them. I had to carefully pry it off the old batteries, reinstall it, and clean the adhesive residue off it.
    Also, YMMV, but I did not bother with delicately removing the old batteries with fishing line, loosening with solvent, or whatever. They’re going in the trash (ahem, recycling) anyway, so I pried them out with a screwdriver, using the neighboring cell as a fulcrum. 98% of the adhesive remained with the batteries, leaving very little residue in the case.
    Jon Scott - Réponse
    I also forwent the many steps to protect components from the isopropyl alcohol. Blocking the back of the computer up an inch or so meant that any spill would run down and away from the logic board, which actually helped loosen the adhesive. I felt that disconnecting so many parts was a greater risk with no real benefit so long as care was employed in the use of the alcohol. Using some twine in a sawing motion behind each battery got through the adhesive without trauma. The entire repair was actually very simple and fast. The toolkit is excellent and well worth buying from iFixit. The machine is now working really well again. Worth fitting a new SSD now.
    Simon Morice - Réponse
    Info for assembly: you have place it from top into to connector - watch out for the guidegroove/pimple .
    Not horizontal from battery side (as it seems my first try)
    Muescha - Réponse
    Success! I ordered the whole kit and thought I would do all these steps below. But instead I just unplugged the battery and skipped all the steps up to step 36. For getting loose the old glued in battery I used waxed dental floss, it is strong and easily available. I strung it around two wood pieces and wired it around the underside of the batteries, then slowly pulled it downwards till the end. This worked quite well and after 10 minutes all the 6 batteries were free. Now the ‘fun’ part, cleaning up the old adhesive strips. I used the little bottle of alcohol from the kit but found this not the best cleaning solution. Be warned, dont forget that in this position, directly under your downpressing fingers there is the glass trackpad and the display!! I really was scared to break them during this cleaning process. Because of this I switched to LIGHTER FLUID , which is stronger and the process quickly proceeded. Thanks ifixit for your great support.
    Jamba - Réponse
    I had to replace my replacement battery ... luckily the ifixit adhesive isnt that overpowered ... ehem ... I just pulled the old one out softly ... used the plastic card, some force ... and build the hopefully-this-time-lasting-longer-than-4-month-new-battery in ... it saved my evening.
    Arne Fischer - Réponse
    I just finished doing my second battery replacement on one of these. If you're replacing a battery that came from iFixit you can skip straight to step 34 and use cards/spudgers/guitar picks to remove the batteries. The adhesive on the iFixit batteries isn't nearly as tenacious as the original Apple adhesive (though it's plenty to keep the battery stable) and it was easy to pop the battery segments out with a spudger and peel up most of the excess adhesive strips. What little was left came off easily by putting small amounts of the solvent on paper towel and rubbing - no need to pour any amount of solvent into the case.
    lindensmith - Réponse
    When it's time to install the new battery, bend the wires a little more to make a "U" shaped down curve...
    The acetone bottle shown runs the risk of dispensing a lot of solvent - which may well damage the speaker plastic. I used a 5 ml plastic pipette to deliver small controlled amounts and had no problems removing the battery without having to take everything else out :-) I also used propanol (isopropyl alcohol) on some kitchen towel to remove the adhesive residue from the case - slightly less effective than acetone, but doesn't dissolve the plastic :-)
    Jon Harris - Réponse
    I took the good advice of all you previous commenters and skipped to step 34.
    I did not have any solvent but it just took some careful patience prying up the battery with a couple plastic cards.
    elyze - Réponse
    I used a guitar string ( high e 9 gauge) and a pair of thin leather gloves (to protect hands ) and after using tweezers to get it behind the batteries I was able to pull thru/ cut thru the adhesive with relative ease .
    brian stoller - Réponse
  5. Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014, Nappe AirPort/caméra: étape 5, image 1 de 1
    • Utilisez une spatule ou une pincette pour retirer les trois tables d'antenne AirPort de leurs prises sur la carte AirPort.
    • Les points de connexion sont fragiles. Veillez à ne soulever qu'au niveau du connecteur et non pas de la prise ou du câble.
    • Pour rebrancher les câbles, alignez les connecteurs au dessus de leurs prises et appuyez fermement avec le côté plat de votre spatule.
    will this procedure remove my warranty? I have applecare for another 2 years, Laptop was dropped on the side, there is a very small dent on the side of I/O.
    Oleg Babko - Réponse
    Yes, this voids your warranty.
    max damage -
    These are notoriously difficult to remove. I actually damaged 2/3 of the connector pins during the process. Thankfully i was still able to fit them in place. This step should not be underestimated.
    Alvin Chua - Réponse
    If you are not replacing the display case assembly, you can opt to leave all 3 connectors attached and remove the Airport card with them connected. You will need to carefully manage the card and attached cables so as not to damage them(masking tape) as you proceed with disassembly/reassembly. Step 6 will need to be done carefully (camera cable connector). I did it after step 8. I took a picture of routed cables as well before I removed them from channel.
    Macrepair SF -
    unless you have really tiny fingers, a tweezer helps, just be careful not to damage the wires or the board as your holding each cable in place. Oh and take your time - this is like the most frustrating step in the process, imo.
    Arn Custodio - Réponse
    The order of the cables doesn't seem to matter when re-attaching. It also might be helpful to unscrew and eject the airport card. Having it free can give you a better angle.
    joey - Réponse
    Definitely the hardest step (when putting it back together). The three pins were on progressively longer plugs, so I put the shortest one on the left and so on. This helps with getting the right angle. I used my fingers and the spudger to guide them back in. It took me easily 10-15 minutes to do this. The pattern that worked eventually was to first adjust the angle of the pin head so that it's x/y/z axes would line up perfectly with the connection if you are able to bring it together just so. If you're off on any of these while you try to bring it together, you won't be able to just click it down at the end. Good luck!
    Thomas Kunjappu - Réponse
    Agreed, for some reason, the middle one was stubborn — and I was worried the amount of force I applied to push it back on was going to break something - but it did pop back on.
    Jer -
    I would never remove those tiny plugs unless I absolutely have to. And we do not have to remove them, just the card itself…
    Jurgen -
    I looked at these plugs under a 8X lupe, since my 56-year-old eyes are not what they used to be. They are circular, so it’s more a question of just aligning the bottom with the top of the plug rather than angle. If I can do it, someone with better eyes can definitely do it.
    Sam Bortnick -
    After reading so many reviews on ifixit and other sites regarding the difficulty of replacing my MacBook Pro retina screen assembly, I was a bit nervous. Using this walk through made it super easy. Thank you so much for taking the time to create it!
    cabcpa - Réponse
    Removing these 3 tiny cables is completely unnecessary. I removed my fan last week to clean and it slips by these cables. For some dumb reason i wanted to follow this "correct" procedure and now one of the gold connections detached from the wire like it was nothing. Seriously, dont do this. I used a spunger and was very delicate putting it back on... And look what happened. SKIP!
    travismlive - Réponse
    Yeah, I agree, just leave the airport card attached to the pins and remove the card itself. Then you won’t have to fuss with these connectors.
    Jer -
    @tmm Your right on! Just finished replacing my right fan and your tip saved me from messing with these tiny cables. I totally understand your frustration as I was too just about to stick to the procedure, but if it’s any comfort your tip helped someone… so don’t be surprised being rewarded by some good karma :)
    IT’S UNNECESSARY TO DETACH THE 3 TINY CABLES FROM THE CARD, JUST DETACH THE AIRPORT CARD WITH IT’S CABLES ATTACHED BY GRABING IT FROM BOTH SIDES USING TWO FINGERS AND GENTLY SHAKE IT UNTIL IT DETACHES. THEN MOVE THE WHOLE THING A BIT ASIDE.
    THIS STEP IS ONLY NECESSARY TO MAKE WAY TO THE FAN CONNECTOR UNDERNEATH.
    There is one thing though I find missing which concerns:
    1)The rubber heat sink cover
    2 The AirPort/Camera cables
    3)The IO board cable
    All these are “glued” to the fan and you need to peel them off gently using the spudger, now while I noticed that some glue remains on each cable so they will kinda stick again, I wonder what kind of glue is this and where one can buy it?
    Itai -
    These individual instructions are re-used across multiple tutorials. If you are replacing the battery, you probably won’t need to remove the three connections from the Airport card; if you are replacing the display, you definitely need to replace them, because they are connected to the display. I just replaced the battery and the display in a single activity, so I pretty much had to remove everything. Also agree with a previous commentor that it’s easier to reconnect the cables before the card is reconnected to the system board.
    ChrisMBP -
    travismlive is right, you do not need to remove these cables or the airport card. Just remove the I/O board cable, undo the screws, and detach the antenna cables from the fan where they are glued with a spudger. Unlock the ZIF-socket and the you can wriggle the fan out. Probably saved my airport card, thanks travismlive!
    Jasper - Réponse
    I only successfully reattached 1 of the 3 AirPort cables, I just taped the other two. But the AirPort seems to work fine. Do these also have anything to do with Bluetooth though? I do seem to have trouble with Bluetooth after this operation. In any case, it was worth it... I replaced the screen with a new Apple screen for less than 1/2 the Apple Store wanted! Thanks!
    Douglas Johnston - Réponse
    Would soldering them back in place be better than taping? I certainly don't want spare solder on my motherboard, so I figure that'd be a last resort only if I lose AirPort connectivity.
    Assembly is a nightmare. If rightmost cable is not connected, BT will not work.
    Radoslaw Przybyl - Réponse
    the hardest step is reconnecting the airport antenna cables. just have patience< and use tweezers, spluger and a q-tip.
    Frederick Rae - Réponse
    The three cables have different lengths. The longest should to the farthest pin, medium to middle, short to nearest.
    Sam Jomaa - Réponse
    Also, having the right tools will make the job really easy. I used a spudger similar to the one recommended on this web site. But i had ordered a complete kit from amazon.com. I did not have any problem removing or re-attaching the pins.
    Sam Jomaa - Réponse
    tweezers to hold the cable and the flat part of the spudger to push down on the connectors is the easiest way to re-assemble
    Jon Ocampo - Réponse
    Replacing these were the most difficult step I encountered. I finally determined that it took slight back and forth twisting of the cable (from left to right as viewed from above) to cause the connector on the cable to twist into position so it could be pressed down.
    chuck60 - Réponse
    I read your step and you are 100% correct. This helped me tremendously. Thanks!
    Achilles -
    Use leverage with tip of a spudger, it’s not that difficult to pry the cables.
    When you reassemble, use a tweezers to put the connector on the right position and push it down with a finger on the other hand.
    Grab the neck of the cable when using a tweezers.
    eskoo - Réponse
    Several of the people above mentioned not disconnecting these three wires. You must remove and replace these if you are replacing the entire display which is what these instructions are about. This is the most difficult step as others have noted. Just be careful and make sure you have the cable level before you start pushing down.
    Macrepair SF - Réponse
    Reassembling: What makes this so hard? From all appearances I’m just pressing a squat sleeve-and-pin connector down onto the female counterpart. It appears to be circular and therefore not needing to be oriented radially in any particular angle. It doesn’t look hard at all! Does anyone understand what the subtlety is that causes everyone so much grief?
    Chapman Harrison - Réponse
    Reassembling: as so many as commented, this is incredibly hard - and inexplicably so. From all appearances I’m just pressing a squat sleeve-and-pin connector down onto the female counterpart. It doesn’t look hard at all! But I couldn’t do it.
    Here’s what seems to have worked for me: with my left fingertip on the cable holding the connector directly above the female, I used the spudger to press down the flat back of the connector, initially at the top and then sliding along toward the neck. I used normal pressure, and voila, when I lifted the spudger away the wretched wire didn’t spring up again. It was like it wanted to be rocked, or stroked, once, from top to neck, rather than pressed straight down.
    I skipped to step 34. Just pushed up the speakers so that they don’t touch the body.
    Sascha Gl Richy - Réponse
    Can anyone help me? I would like to replace my speakers. Which steps can i skip?
    Manzil Monabber - Réponse
    I have completed replacing my speakers and this step was not needed at all.
    I just completed the full screen assembly replacement with 90% success I guess. Like many others noted, this was the hardest step, and one them (leftmost) was extra hard, but I eventually got them all back in. However, I don’t have 5G wifi anymore. 2.4 g works fine, bluetooth works fine, and the screen, camera, and mic are all perfectly functioning. I just can’t connect to 5G wifi. Is there a fix for this?
    Aaron C - Réponse
    Absolutely no need to take apart the whole thing, get some strong fishing line and slowly saw the adhesive away. Once the battery is out, (if you are prone to be clumsy just cover/ shield the rest of the computer, than use GOO GONE or the like waiting a couple minutes to scrape out the old adhesive. The only reason they make your take everything out is that they assume you are lazy and will be using the adhesive remover which could damage the rest of the computer if allowed to splatter etc. Just save your self some time and stress, get strong braided fishing line ( works way better than floss or string as it is of a smaller diameter and isn’t smooth and helps the sawing action), and work your way around each cell. This is still way shorter than removing the entire computer and much less likely hood of damaging sensitive connectors.
    Pia Paeh - Réponse
    Agreed! Especially if you replace the batttery a second time with a less Apple-like adhesive.
    To prepare for a third time I actually covered parts of the adhesive pads with plastic film on the new battery. I figured that gluing it to the base where it is actually hooked behind the frame makes little sense.
    Cheers to everyone repairing good old things and keeping them alive!
    Jörg -
    Putting these 3 cables back was a lot of work. I bent the outer side of the middle cable, but was able to fix it with fine tweezers from the repair kit.
    olegpsh - Réponse
    I did a screen replacement recently using this guide and the disassembly/assembly was fine - very good instructions. But when I turned on the machine there was a very fine flickering, snow-like interference, especially noticeable on black backgrounds. I assumed it was a faulty replacement screen and continued to use it. Recently, I had to change out the battery so I dissasembled the screen again to see if reconnecting it would fix the problem. Now it is perfect. I think the problem was that the left-most (shortest) airport cable connector was touching the black screw next to it on the board and shorting out. Be careful to position this connector well away from that screw.
    rumblefish - Réponse
    I found placing the spunger under the part of the connectors AWAY FROM THE WIRE (top and/or side depending on which of the three you’re finessing), and then rocking them gently from side to side pops them out gently.
    MFMauceri - Réponse
    I read the note above and managed to fold the card out of the way. I’d put it in a paper envelope to stop it touching anything as it flaps around. The bag also stops static build up and reminds you it’s there ! The wires on mine were held down with two strips of tape, the pointed spudger? pushed along the length of the wires widened the tape loop when I pushed firmly but carefully. Once widened, tweezers can open it fully .
    Simon Anthony - Réponse
    I skipped the step of removing the airport antenna cables and removed the airport card with the cables since so many users said it was extremely hard to get the airport cables back on properly. By skipping the airport cable removal I save a lot of potential headaches and performing this task was not any more difficult to do.
    Timothy McDaniel - Réponse
    I skipped steps 5 - 40 and removed the old battery with the plastic card and a palette-knife after heating the adhesive strips cautiously with a hair dryer. After that removing the adhesive strips with the solvent was by far the most time consuming part.
    Martin Zeilinger - Réponse
    so what happens if you damage 1 of the 3 connectors because you didn’t read all the comments first? Does it work at all or just diminished wifi reception?
    Can someone at ifixit update the main instruction page to advise removing the airport card instead of the super fragile cables?
    Brandyn McKibben - Réponse
    YOU DONT NEED ANY OF THIS!
    it is SO stupidly risky to remove all this. Who the HECK wrote this guide?!? Thank God I checked on youtube and found guys who did NOTHING of these steps and simply removed the battery in under 1 h.
    Silly Billy - Réponse
    Steps 5-33 are not really needed if you are careful with the speakers, not to spill the fluid onto them. It saves a lot of time and potential dangerous operations. I did it without any problem.
    Cristian Caprar - Réponse
    Please be extremely careful, I just ripped out one of the sockets for the cables. I fixed it with Tesa until I can buy a new Airport-Card.
    Josiah Lauer - Réponse
    BE EXTREMELY CAREFUL WITH THIS STEP both when disconnecting the cable connection points and while doing the reconnection. I damaged the J2 connector (Wi-Fi and Bluetooth are working just fine, though) while trying to reconnect it to the AirPort card. I’ll suggest, as others have here as well, to not disconnect the cables and just have them connected to the card the entire time as this is, IMHO, a completely unnecessary step to take while doing this whole procedure.
    Rafael Pérez - Réponse
    Well, this is the step that (just through reading these comments) I decided NOT to fix my right speaker. Anytime I have to remove these delicate Airport and Camera wires and connections, I get very nervous. (I've done it before, successfully, on a MacMini [ugh; never again!] - just to replace the two slow HD with SSDs! What a hassle!
    I'll just my headphones or computer speakers through the headphone jack.
    Jonathan Paul Saltzman - Réponse
    I'm an amateur, so what do I know - but to replace a battery I skipped this step, and all other steps until step 36, I've no idea why they include all these other steps for battery replacement. Literally all steps from 5 - 35 aren't needed.
    Andy M - Réponse
    I broke the J0 connector when this reconnecting step. But Wi-Fi and Bluetooth functionality are still alive I don't know the reason why.
    ppop popy - Réponse
    Pretty sure it is fine, but if you want stronger and further WiFi range, that 3rd connector is what gives you that.
    Cary B -
    Why do I have to remove the airport antennas?
    Cary B - Réponse
    Surtout ne pas démonter les 3 connecteurs. Extraire la nappe camera/wifi sans enlever le 3 connecteurs. Les 3 connecteurs sont fragiles et très difficile à remettre. Dans mon cas, 2/3 des connexions sur la nappe sont HS.
    bruno Villers - Réponse
    This is the point where you should say "No freaking way" and go watch this youtube video and save yourself a nightmare: https://www.youtube.com/watch?v=rfHHIERH...
    There is absolutely no need for this repair to be this insanely convoluted.
    Donovan Rittenbach - Réponse
  6. Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014: étape 6, image 1 de 1
    • Avec la pointe d'une spatule (spudger), poussez le connecteur de la nappe de la caméra vers le ventilateur et hors de sa prise sur la carte mère.
    • Veillez à pousser parallèlement à la carte, d'abord d'un côté, puis de l'autre pour faire "sortir" le connecteur lentement de sa prise. Ne faites pas levier, sinon vous allez endommager la prise.
    I've broken camera connection socket, is it repairable?
    Sergey - Réponse
    Same for me too just take the socket from your broken screen and cut it off and solder it onto the new screen. It was really hard because it's so small but I did it.
    bhayes9614 -
    This is much easier if you do step 7 first so you can pull lightly on the cable and take the tension off the connection caused by the stiff cable.
    mayer - Réponse
    This tip worked for me.
    eskoo -
    If you are removing the right fan it is not necessary to unplug the camera cable. You can slip the fan out underneath the cable.
    noahtfu - Réponse
    Hi! Camera flex cable is from MBP Retina Mid 2012 & Early 2013. Not Late 2013 :) Edit it please.
    kramerigor - Réponse
    the tip of the middle 3 wire was broken on the replacement screen. I didn't connect it and everything seems to work fine, mac hardware test says everything is fine... Is it possible?
    micheleroger - Réponse
    Yes. They are wifi antenna cables. Missing one antenna won't affect much, and won't show up in any hardware test.
    Jason Amri -
    Push on the little wings, from right to left.
    Julian Wood - Réponse
    This is the hardest part of disassembly! Arguable hardest part of re-assembly too, other than the airport cables
    The instruction is not clear to me at all. Frankly the comments mentioning things make me uneasy about proceeding further.
    Ben Moore - Réponse
    This came off for me - now my computer’s fan is running high constantly, and “Kernel_task” is using 500% of the CPU even though nothing else is running - what can I do?
    Ryan Brown - Réponse
    Did you ever get the fan to stop? how?
    Cyd Trice -
    It is very important to note here that you are NOT pushing up. You are pulling the cable back toward the fan. Doing step 7 first makes that easier. I misunderstood the instruction here (as others seem to have as well) and broke this part. I’m fine with not having a camera on this computer so I’ll leave it or ask my son to help me solder it later.
    Jen Wells - Réponse
    can you give guidance on the soldering? Im new to it and dont want to burn anything / especially the wrong thing!
    Cyd Trice -
    The wing closed to the edge of the chassis is completely stuck. I’ve worked on it for an hour. The other wing moves freely. I’m not sure what to do now.
    Charles Lindauer - Réponse
    The connector is very tight - I couldn’t even see the join between cable end and the socket and couldn’t see the “ears” on the end of the socket. And, of course, pulling didn’t help. I eventually used tweezers to start things off, gripping on the metal of the socket right where the invisible join was. What a delight to have the join open enough to see! After that, it was easy.
    jerryl - Réponse
    Thank You Jerryl - The tweezers did the trick. They want to pop out so you can use your other hand to apply slight downward pressure to keep them in place. Work both ends of the tweezers gently back and forth and you should start to see the gap get bigger.
    Chuck Barton - Réponse
    I used tweezers and the spudger. Take the point of the spudger and push on one side of the “dog ear” while supporting the other side with the closed tweezers on the cable side of the dog ear. (Could use a second spudger) work one side the move to the other repeatedly until the connection disconnects.
    This is allows You to push and support simultaneously and minimize the chance damaging the connector.
    Jonathan Dowling - Réponse
    Removed cover (Step 7). Released adhesive. Pulled directly out of socket to the left.
    Pushing out of this connector is ill advised, as no mechanical ledge to push.
    Joseph Gorse - Réponse
    The late 2013 Macbook connector is slightly different to the picture, I used tweezers to loosen up first and when the joint appeared used the flat edge of the spludger to push the connector using the gap. Don't rush push this from each side gently till it comes out.
    Lanre O - Réponse
    I found this step to be difficult due to the picture and instructions being incorrect for MacBook Late 2013. Unfortunately, I damaged the pins during this step and my camera no longer works. :^( Please update this step.
    Cristina Stoll - Réponse
    @xtstoll I looked at two separate Late 2013 units today, and both are indistinguishable from what’s shown in the instructions. Are you sure you’re working on the right model? A photo of what this cable looks like on your laptop would be helpful.
    Jeff Suovanen - Réponse
    A MAGNIFYING GLASS really helps on this. The cable’s sheathing may need to be pushed back a tad to find a place to get leverace to work the pin out.
    MFMauceri - Réponse
    DO FIRST
    STEP 7 : Untight the rubber heat sink cover on the right fan.
    Lift the cover and flip it back so that you can access the cables underneath.
    STEP 8 : Carefully de-route the cables from the plastic cable guide.
    So you can easily disconnect the connector.
    KRIS - Réponse
    Tweezers saved me on this one! Take your time and keep trying (gently) if you're still struggling
    Elizabeth Jolly - Réponse
    gently set pointed tweezers at the ears on either side and walk it back toward the fan
    Christa - Réponse
    I have jewellers glasses and they were so helpful. Without them I would have broken plenty of bits. I really recommend getting some magnification for this job, some of the bits are sooooo small!
    Gordon Young - Réponse
    I have a late 2013, and using the tweezers to gently create a gap worked excellently. I used the tip of the spudger to push it out the rest of the way, alternating right and left on the edge exposed by the gap, pushing gently even when it wasn’t apparent there was any movement.
    Troy Hall - Réponse
    The way I did it took less than a minute. Ensure the AirPort card is not in place on the board. Get a pair of tweezers to squeeze the ends of the cables into each holder on the card. Apply pressure on the back of the card and the cable end at the same time. If it works, the cables will swivel easily in their slots. Then put the AirPort cable into the board.
    Michael Stroh - Réponse
    I did it in less than a minute. Used a pair of tweezers. First thing is to take out the AirPort card from the slot. Hold it in one hand while using the tweezers to squeeze each of the cable ends into their sockets. Ensure that you are squeezing the back of the card at the same time as you are clipping in the cable ends. You will see that each cable end will swivel around and not come out of their sockets.
    As per other comments, recommend referring to steps 7 and 10 before attempting step 6.
    I found it helpful to remove the airport card first, then use tweezers to gently pull cable 0.5 m from socket, then use pointy end of "spudger" to push connector out of socket.
    Tim Telcik - Réponse
    I got to this point on the reassembly only to realise that i was missing the camera cable! Trapped under the motherboard. Decided i dont need the camera that much to warrant reversing everything again
    Barry Cooper - Réponse
  7. Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014: étape 7, image 1 de 3 Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014: étape 7, image 2 de 3 Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014: étape 7, image 3 de 3
    • Insérez l'extrémité plate d'une spatule (spudger) sous le cache en caoutchouc du dissipateur de chaleur sur le ventilateur droit.
    • Faites glisser la spatule tout le long du cache, décollant ainsi la bande adhésive.
    • Soulevez le cache et retournez-le de façon à accéder aux nappes en-dessous.
    Back (case) side of rubber attachment is flimsy-ish, so need to be delicate when peeling rubber back.
    cahcadden - Réponse
    assume everything is delicate and needs to be worked gently.
    Christa -
    True @cahcadden.
    Worst case you could accidentally tear it off
    (thank god, that didn’t happen to me, but belive me —> it was a close call)
    Shahzad Arif - Réponse
    The glue will be gone, don't fret about it. You can just let it flap back when you are done, you can order this item from Amazon: B09WMWH3LM - contact shoes glue.. A little smear on both parts goes a long way. In my case I already had the stuff from other things I fixed for my wife.
  8. Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014: étape 8, image 1 de 3 Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014: étape 8, image 2 de 3 Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014: étape 8, image 3 de 3
    • Avec vos doigts, enlevez les nappes Airport et caméra du ventilateur.
    • Les nappes sont collées au ventilateur, dégagez-les donc soigneusement pour éviter de les endommager.
    • Retirez avec soin les nappes du guide-câble en plastique.
    It's a bit tricky to re-route the cables when you're installing the new display, so pay close attention to how they're originally routed, to make sure you don't pinch them or torque them.
    PriorityMail - Réponse
    I used scotch tape to temporarily hold the cables in place until I was ready to reinstall the bottom cover, but I removed the tape at that last step (didn’t want it coming loose later, and possibly obstructing a fan).
    ChrisMBP - Réponse
  9. Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014, Écran complet: étape 9, image 1 de 2 Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014, Écran complet: étape 9, image 2 de 2
    • Utilisez l'extrémité plate d'un spudger pour retirer les deux caches en caoutchouc des charnières, un de chaque côté de l'appareil.
    I lost one of these rubbers. Is it OK if I dont buy a replacement? What happens if I dont?
    haloerika - Réponse
  10. Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014: étape 10, image 1 de 2 Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014: étape 10, image 2 de 2
    • Retirez les deux vis Torx T5 de 3,1 mm fixant les caches en aluminium des charnières au boîtier supérieur.
    • Retirez les deux caches en aluminium des charnières du MacBook Pro.
    These were T4’s when I pulled them on a couple MBP’s and a silver plastic spacer came out with them.
  11. Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014: étape 11, image 1 de 3 Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014: étape 11, image 2 de 3 Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014: étape 11, image 3 de 3
    • Utilisez la pointe d'un spudger pour retirer le verrouillage du câble de données de l'écran et faites-le pivoter vers le côté DC-In de l'ordinateur.
    • Tirez le câble de données de l'écran tout droit hors de sa prise sur la carte mère.
    • Ne pas soulever le câble de données de l'écran, car sa prise est très fragile. Tirez le câble parallèlement à la surface de la carte mère.
    "Pull the display data cable" is misleading unless you first read the following comment "Do not lift up on the display data cable". Those two statements together might lead you to "With the hinge away from you, SLIDE the display data cable out by pulling the handle to your right, not up."
    jefowler4th - Réponse
    This is also a difficult step as it isn’t clear that the connector is held in place by a clip that is initially flat against the board. It must be rotated up at a 90 deg angle to the board. then you can work the connector back out parallel to the board.
    Walt Goede - Réponse
    A bit confusing. First, you want to lift up the cable lock. After this step, you want to back out the cable from the socket by rocking the cable side-to-side whilst gently pulling it towards the edge of the macbook pro. Do not lift up. You want to in effect slide the cable out of the socket.
    Dean Dillavou - Réponse
    It think I break the data cable…Is that possible to change only this part?
    camille.laflamme.r - Réponse
    After going through all of the steps, replacing the battery, and re-assembling, something is wrong with the display and the laptop is no longer usable as a laptop. It only works with an external display. This step appears to have been the culprit. Although I understood the directions and was very careful, either the cable or the socket may have been damaged. As I look back, I question why ANY of this needs to be done, with the exception of opening the case and disconnecting the battery cable to replace the battery. You’d be better off following the idiots who used dental floss and made YouTube videos. I still recommend the iFixit tools and solvent. In any case, thanks iFixit for directing me to take the extra steps that destroyed my MacBook Pro.
    Russ Topping - Réponse
    You did look up display disassembly instructions... That's what these are for, if you didn't need to do these steps then why are you even on this page??
    jacobdanderson -
  12. Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014: étape 12, image 1 de 1
    • Retirez quatre des six vis Torx T8 de 5,3 mm fixant l'écran au boîtier supérieur.
    • Nous vous demandons à dessein de laisser une vis attachant l'écran au boîtier pour faciliter les étapes suivantes.
    • Lors du remontage, assurez-vous que les vis traversent les deux boucles de mise à la terre sur la nappe webcam/Airport.
    Are the grounding loops on the webcam/airport under or on top of the upper case hinge?
    tonylbvre - Réponse
    They were on top for me
    matthew - Réponse
    These guy are imposssible to get out - Either I need to get lifting or somethings &&^&@@
    yannick - Réponse
    For me they’re T9 torx screws. They’re pretty hard to unlock because of the blue thread lock, use a good quality screwdriver.
    Adrien - Réponse
    Remove the two screws over the airport/webcam grounding loop. Makes the process easier.
    See also MacBook Pro 13" Retina Display Early 2013 LCD Cable Replacement for replacement of the LCD cable.
    Harvey Thompson - Réponse
  13. Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014: étape 13, image 1 de 1
    • Ouvrez le MacBook Pro d'environ 110 degrés et placez-le de côté sur la table, comme illustré.
    • Tout en maintenant l'écran et le boîtier de votre main gauche, retirez la vis Torx T8 restante de la fixation inférieure de l'écran (le plus près de la table).
    This is more easily achieved by inverting the MacBook and placing the “C deck” / keyboard surface on a desk such that the display hangs down vertically, i.e. at 90° to the C deck. Removing the last screws then just leaves the display held by gravity into the channels - it can’t fall or twist as with the “place on edge” method shown here - the risk shown with the exclamation mark in Step 14 below is eliminated.
    stephen_desaulles - Réponse
    This tip helped me SO much for both assembly and re-assembly. I strongly recommend doing this - for reassembly, it is much easy to ‘snap’ the display half in place into the keyboard side, then tighten the screws in the 3-screw piece directly on the table. (Very important - on reassembly, put in all three screws on both sides before trying to close the macbook - I broke my hinge the last time I did this, when didn’t put in all 3 screws before trying to close it.)
    Ginny -
    Agree with placing MacBook keyboard down on edge of desk so monitor hangs over edge: place a cloth over the edge to avoid screen damage, you can then support the bottom of the screen with your legs. I tried the other method for disassembly, this is easier and less scary by far.
  14. Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014: étape 14, image 1 de 1
    • Veillez à maintenir l'écran et le boîtier supérieur avec votre main gauche. Si vous les lâchez, vous risquez de faire tomber l'écran ou le boîtier supérieur et donc de les abîmer.
    • Tout en tenant l'écran et boîtier avec votre main gauche, retirez la vis Torx T8 restante de la fixation en haut de l'écran.
  15. Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014: étape 15, image 1 de 3 Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014: étape 15, image 2 de 3 Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014: étape 15, image 3 de 3
    • Saisissez les deux moitiés de l'appareil, une dans chaque main.
    • Poussez délicatement la moitié inférieure de l'appareil vers l'avant pour la détacher de l'ensemble écran.
    • Mettez soigneusement chaque composant de côté, en vous assurant de poser la moitié inférieure sur le côté clavier.
    The hinge on my replacement display is not open 110 degrees. It's completely closed. How do I open it to screw in the torx screws that connect the display to keyboard?
    i12i5 - Réponse
    I had the same problem. Did you finds a solution for pulling back the hinges on the replacement screen to 110 degrees?
    Steve Dawson -
    Pliers work! You can twist one hinge at a time with pliers. They should move surprisingly easily. (Fingers clearly aren't quite strong enough)
    Steve Dawson -
    Use your screwdriver instead of pliers! :D
    jfigueroagerena -
    I used an old credit card (or 2, stacked), so as to not risk scratching the screen.
    Andrew Ngu -
    I also used pliers, but you’ll want to wrap a paper towel or thin cloth, etc. around the hinge flap so you don’t scratch it with the pliers when you move it.
    Delaney Cunningham -
    How can I remove the long and thin black plastic cover that seats in the bottom of the screen so I can tight the screw that seats in other end of the hinge?
    gkmaia - Réponse
    All went well, but the new screen now has a slightly greater distance from the body when the MacBook Pro is closed. I don't have any explanation for that, since the distance can't be influenced. A large distance would mean that the hinges are too close to the body, because they are screwed to the bottom of the body. Any ideas?
    orkus - Réponse
    The little flange that holds the wires and fastens onto the hinge screws should go on top of the hinge and not below? Just a thought.
    max damage -
    As noted in an earlier step, you must make sure that before you start this entire task, Step 1 should be to “Shut Down” your computer completely. I used a stubby pair of long nose pliers to bend the clips out. Don’t use a screw driver.
    I was able to disassemble a display form a broken macbook pro and am looking to set up this separated display as a monitor attached to another computer. Does anyone have a solution on how to get this set up?
    nicko1995 - Réponse
    using the 2 credit cards stacked together worked best
    Athanasius Pernath - Réponse
    This was a relatively east repair compared to replacing a logic board in my older Macbook Pro 15. I needed to replace the LVDs cable which required using another tear down guide not part of this one. MacBook Pro Retina Display Teardown.
    I really appreciate the authors. You guys saved mt $600 which is what my local Apple Store quoted to replace the entire display which the computer didn’t need. All it needed was a fairly inexpensive cable available here for $20/
    Thanks very much.
    FFCS Family - Réponse
    Can somebody please post the link for the replacement display. I found it $599 in amazon. Is there a cheaper price somewhere?
    H Cg - Réponse
    My replacement display remains black. I can hear startup noises but black screen. I’m wandering if I got a bad screen or I wired something incorrectly. Any suggestions?
    Priscilla Hill - Réponse
Pour réassembler votre appareil, suivez ces instructions dans l'ordre inverse.
140 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
37 commentaires
Just completed my mid-2014 Retina display replacement. Fantastic instructions - took me ~30 minutes, constantly referring to printed instructions, edits and comments. It's not as hard as it looks. Only complaint is the recommended spudger is too soft to accommodate some of the maneuvers and ends up mashed and bent. It took some time to replace the AirPort connections but that's the only time I sweated...
chrisslay - Réponse
Will this work with a mid 2015 model? Specs: 2.5GHz i7, 16 GB RAM, 512GB SSD and 2GB ATI Radeon R9 ?
Pierre Bugeja - Réponse
See the full compatibility listing at this link on iFixit ... MacBook Pro 15" Retina (Late 2013-Mid 2014) Display Assembly
John Tyler -
Hello, I see the same part number listed for different models for different years, how can I be sure to order the correct one? I have mgxa2b/a EMC2876 mid 2014 it has 12-pin camera connector. If I search for EMC2876 all the screens are really expensive but would another one work, do I just need 661-8310 with 12-pin camera connector? or something more specific do I need to ensure it is listed for EMC2876?
Thank you.
chloe - Réponse
There is a full compatibility listing of all MacBook Pro models that use this display part. Go to this Link on iFixit.com == MacBook Pro 15" Retina (Late 2013-Mid 2014) Display Assembly
John Tyler -
Thank you, very detailed guide and easy to follow.
Rolan Shkolnik - Réponse
how do i check which display is compatible with my macbook? I read online there are two types of display, LG and Samsung. I have a late 2014 macbook pro retina 15 inch.
ironstatue - Réponse
@ironstatue - There is a full compatibility listing of all MacBook Pro models that use this display part. Go to this Link on iFixit.com == MacBook Pro 15" Retina (Late 2013-Mid 2014) Display Assembly
John Tyler -
So when taking the aluminum hinge brackets off (step 10), i broke the one bracket... (bent in half and snapped)... the rest of the components are fine, my question is do i need to order a replacement bracket or is this a part i could live without?
Matthew Stathis - Réponse
I just installed my replacement monitor and my fans are running non-stop and also my laptop is running very slow. Any suggestions?
jenny - Réponse
Same here, anyone?
Pete Jacob -
I followed this guide and sadly, the monitor came on dead. Returned the old one; it does not work. An external monitor works, the camera works. What might be the problem? Doesn't seem to be the backlight because nothing shows up with a flashlight. Please help!
Frieda Vizel - Réponse
If everything is working besides the display, I would imagine it has something to do with data transfer from the display to the logic board. Try to make sure the connection in step 11 is secure and done correctly. Did your old display work before the change and when you switched it back it didn't? If the connector not being seated correctly is not the issue, it is possible that you damaged the socket during removal. Let us know what your investigation reveals!
Scott Havard -
does anyone know if a mid 2014 lid will be compatible with my mid 2012 laptop please?
jon collins - Réponse
Same question here. Glad if anyone has some experience with this case.
Daniel Pruemers -
thank you. the hardest step is reconnecting the airport antenna cables. just have patience< and use tweezers, spluger and a q-tip. apple tried to charge me £750 for the replacement. i did it myself for £250
Trying to check out dude!
Joseph Wooldridge - Réponse
Did mine today but now have kernel task at 500% and fans running flat out
Pete Jacob - Réponse
Thanks a million :) great guide.
Hani Farran - Réponse
My original screen decided to only display white and random lines of colors. ordered a new screen from the A-stock, product arrived in perfect condition. This guide made the swap too easy. I especially liked the part about "walk"-ing the connector out of the socket, since that is arguably the most difficult part of this entire repair. Thanks for explaining it so easily and detailed.
It’s a pretty straightforward job - the instructions are very accurate and well detailed. The things to watch out for are that steps 7 and 6 should probably be swapped, and be careful to slide the display data cable parallel to the logic board rather than “pull”. The coax connectors for the wifi also pull off easily - one display I received was missing one, so I transferred a connector from the old to the new one, carefully spreading the crimp with a safety pin then recrimping. I got a little too much practice because the first replacement I got (not from ifixit - they were out of stock) had a bad backlight, so I had to swap my old one back in (and try the new one again…, then the original) so I did it about 5 times total. I have some stiffer blue spudgers that are more scraper-like from the ifixit kit that work better than the black pointy one for the wide connectors.
I finished it and thought I had everything right, but the backlight is not working. By flashing a light through the plastic apple in back of the computer I can see that what’s showing up for the computer is the original setup. It’s got a WELCOME running across the screen (from what I can see), but I’m afraid to select anything even if I can because I don’t want to erase the hard drive. I would be happy if I could at least get the backlight working. Using another monitor, sometimes it shows up, but I get stuck in the PASSWORD RESET loop. Any help would be appreciated!
My Pro is a mid-2015 build, and the screen I installed is mid-2014.
Lou Schiano - Réponse
These instructions were perfect for replacing the screen.
herrky - Réponse
Perfect except there wasn’t sufficient warning about the fragility of the camera cable connector. I applied gentle pressure to one side then the other and walked it out as described and pulled the socket right off the main board. I’m not very excited about this.
Louis Goldring - Réponse
These directions were great except they didn’t mention the fragility of the camera cable connector. I applied gentle pressure on one side then the other and walked the connector from the socket, as directed, and pulled the socket right off the main board. I’m not very excited about this.
Since I completed this repair, after pulling the camera cable connector socket off the board, the computer is running slowly and the fan is constantly on.
Any ideas about what’s causing this?
received my package today, I followed the steps above and everything worked pretty well, my screen is now back to life!
Thank you I fix it.
Bayan - Réponse
I just completed the installation, and unfortunately there is no picture or video even though the green light blinks when I try using the cam for apps like FaceTime and photo booth. Not sure if I did something wrong or it’s just a defective part.
Tony Vincent - Réponse
Thank you! I followed this tutorial this morning and got an old machine up and running again! Only problem is I broke the camera attachment but I’m totally fine with that. I never used it anyway! ;D
Jen Wells - Réponse
Is it possible to damage the logic board when replacing the display? I just got my repaired laptop from the Apple store and it is not turning off. Aplle says is the logic board that is damaged andvwant me to pay again. I believe that thay have actually damaged the board during the display replacement.
Many thanks
David Paule - Réponse
Camera is not working after assembly.
Which connector is responsible for that and should be checked again?
Microphone and Display are working perfectly, just the camera and the green light not working.
Benedikt von Reis - Réponse
Just did this repair after a drop and half the screen went out. Really not too bad and the instructions are great. Many thanks to the contributors.
Jonathan Rand - Réponse
macbook pro mid 2014 screen can replace macbook pro 2015 screen ? sir
Dany Svay - Réponse
Hello, i’m asking myself about the screen scratches, is there a glass in front of the display, or i need to change all the display if i dont’ want to see these scratches. i remember old macbookpro with a glass befor the display, now i have a retina 15’ A1398;
Thanks
CUVEREAUX Basile - Réponse
I replaced the screen on my Mid 2014 Macbook Pro. After replacing the screen, I get no video. So I put the cracked screen back on (which used to show video) and it now shows no video. So then I tried both screens on another logic board with the same results, no video on each. Can anyone offer some advice?
Kevin Mahler - Réponse
A secondary screen works just fine but, I can’t login on the secondary screen. Upon further investigation it appears the main screen is working but the backlight is not. Any suggestions?
Kevin Mahler -
I have this MBP and I have decided to remove the screen entirely in order to connect to an external monitor permanently. The issue I have now is the wifi antenna is connected to the screen and not the laptop. Can I simply cut the wire short on the antenna and still receive wifi signal if I leave the 3 antennas plugged into the logicboard?
Andy - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 46
30 derniers jours : 297
Total : 122,132
