Aller au contenu principal
MacBook Pro 15" Unibody Mid 2009 RAM 교체
Ce dont vous avez besoin
  1. MacBook Pro 15" Unibody Mid 2009 RAM 교체, 하단 케이스: étape 1, image 1 de 1
    • 하단 케이스를 상단 케이스에 고정하는 다음 나사 열 개를 풀어주세요:
    • 3mm Phillips/십자 나사 일곱 개
    • 13.5mm Phillips/십자 나사 세 개
  2. MacBook Pro 15" Unibody Mid 2009 RAM 교체: étape 2, image 1 de 2 MacBook Pro 15" Unibody Mid 2009 RAM 교체: étape 2, image 2 de 2
    • 하단 케이스 벤트 근처를 두 손으로 들어올려 하단 케이스를 상단 케이스에 고정하는 클립 두 개를 분리하세요.
    • 하단 케이스를 분리하고 치워 놓으세요.
  3. MacBook Pro 15" Unibody Mid 2009 RAM 교체, RAM: étape 3, image 1 de 2 MacBook Pro 15" Unibody Mid 2009 RAM 교체, RAM: étape 3, image 2 de 2
    • 칩 양쪽의 탭을 동시에 밀면서 RAM에서 해제하세요.
    • 이 탭들은 칩을 제자리에 고정하며 해제하면 칩을 “튀어 나오게” 합니다.
    • RAM 칩이 튀어 나오면 소켓에서 똑바로 빼세요.
    • 두 번째 RAM 칩이 설치된 경우 이 과정을 반복하세요.
기기를 재조립하려면 이 지침을 역순으로 따르세요.
159 autres ont terminé cette réparation.
Merci à ces traducteurs :
en ko
100%
Christian Kim nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
5 commentaires
I bought and installed 4GB x2 RAM for my Mid 2009 15 inch MacBook Pro and it was easy and is working great. Before this I had 4GB and it was being maxed out. It was very easy. I did purchase the required tools which made it simple. I also swapped the battery at the same time. I am writing this from the same computer and it is working well. Good luck!
1tom2go - Réponse
I had no trouble installing the 4 GB RAM I bought for my Mid 2009 15 Inch MacBook Pro. The mistake I made though was not realising that my machine has two RAM slots. I only bought one chip! So now I have to buy another one.
If you read this before you buy some RAM, make sure you check how many slots your computer has!
Also, I must say the customer support from ifixit is great. I messaged them about this and some other issues I was having and I got a detailed response from them within a couple of days. Thanks guys!
oliverbarrand - Réponse
Thanks! You saved my life.
saltyhf - Réponse
I replaced my original 2x 2gb ram with 2x 4gb RAM following your instructions. However, upon boot up, it’s only showing 1 of the 2 4gb chips. Any tips on how to get both seated correctly?
Matthew Longo - Réponse
Never mind. I was able to pop the second chip back out and get it seated properly.
Matthew Longo -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 54
Total : 61,653
