Introduction
Wireless connectivity issues? Use this guide to replace an inoperative AirPort/Bluetooth board.
Outils
Pièces
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
Carefully peel the AirPort/Bluetooth ribbon cable off the top of the black plastic AirPort/Bluetooth housing.
Disconnect the camera cable by pulling its connector away from the socket on the logic board.
29 autres ont terminé cette réparation.
5 commentaires
I didn't even have to replace my daughterboard -- I ordered a used one, but simply "reseating" (removing and attaching it again) the ribbon cable to the daughter board fixed my problem that the WiFi and Bluetooth card was invisible to the OS.
Thanks anyway for these great instructions! Without them I hadn't even thought about that the WiFi functionality was on a daughterboard... I thought other than in most "Windows laptops" that functionality was integrated into the main board.
Excellent guide! The whole thing took me about 30 minutes and as soon as I turned on my mac again the WiFi worked perfectly.
I replaced both the card and the ribbon cable. Still get the message that there is no WiFi device installed. 15" MBP, mid-2010. The Bluetooth and Ethernet still work. But it is very inconvenient not having WiFi. Any thoughts on what else to try would be appreciated.
Raymond Steinbart
Excellentguide as usual, but not sure the anntena cables should have be replaced in their housings before the Airport/ Bluetooth bracket was secured. Was there a reason I missed.
Is it possible to upgrade? Is there any “successor” known for Bluetooth 4.0 ?
Thanks
