Introduction
This guide has been updated by iFixit staff! Read the new, official MacBook Pro 15" Unibody Mid 2010 Matte LCD Replacement guide.
This guide covers removal and replacement of the Matte Finish LCD. Aside from your screen not being glossy or glared, you know you have a Matte Finish LCD if you have an approx. 14mm brushed aluminum bezel around your screen.
Most people DON'T have this bezel, and so should use the existing Glossy LCD replacement guide instead: Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010 .
The display assemblies of Matte Finish LCD and Glossy LCD version of the MacBook Pro differ in a few ways:
- The aluminum bezel.
- The actual LCD is different (Matte finish, of course)
- The exterior glass of the matte display is optically bonded to the LCD, so you cannot remove the glass with suction cups.
Apart from the display assemblies, the Matte Finish LCD Macbook Pro is identical to a Glossy LCD Macbook Pro of the same screen size.
Note that this guide is marked "difficult". The reason it is marked that way is that you will have to remove the bezel, which is thin aluminum, and the display bumper which is a thin piece of rubber. If you damage these parts (i.e. you put a hard bend in the bezel or tear the bumper), you likely won't be able to get another. This is not necessarily a hard to perform procedure, but could be risky. So please read this guide and consider if it is for you before moving forward.
Ce dont vous avez besoin
Use the flat end of a spudger to carefully pry the AirPort/Bluetooth ribbon cable up off its socket on the logic board.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
At the bottom right corner of the screen, insert the pointed side of spudger between the bezel and wide, flat part of rubber bumper. Pull the bumper towards to hinge to release the adhesive.
Then place the flat side of the spudger between bezel and bumper at the same location, slip the spudger underneath the bumper and lift.
Moving up the right side of the screen, begin pulling the bumper out slowly, in approximately 1"-2" increments. Continue around the screen until the bumper is complete removed.
Is it actually necessary to remove the rubber? I mean to remove the glass from the glossy display this process is skipped so what if I inserted the spudger from inside out instead and worked my way through the same way I would otherwise…?
While applying heat with a heat gun:
Place the flat edge of the spudger under the bottom lip of the bezel on the lower right portion of the display assembly.
Gently pry the corner of the bezel upward, creating enough space to insert the flat edge of the spudger between the bezel and display assembly.
With the flat edge of the spudger under the bezel, gently twist the spudger to release the double stick adhesive tape.
Remove the LCD following steps 33-36 of the guide: Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010 .
Install new LCD following steps 36-33 of the Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010 guide in reverse.
Tooling holes on the left and right upper corners.
Camera.
EMI Pad
On the flange of the display assembly:
Apply the 6mm x 120mm strip, red side up, to the area on the flange between the EMI pad and the adhesive strip on the left side.
Apply the 6mm x 30mm strip, red side up, to the area on the flange between the EMI pad and the camera.
Apply the 6mm x 155mm strip, red side up, to the area on the flange between the camer and the adhesive strip on the right side.
On the upper corner of the adhesive on the left side of the display assembly.
Slip an X-acto knife between the red backing and
Use the X-acto knife to peel enough of the backing so that it can be grabbed with fingers.
Peel about one inch of the red backing and fold it to the inside.
Do the same for the adhesive on the right side and both adhesive strips on the bottom of the display.
For the three strips on the top of the display, peel all of the adhesive backing off.
Carefully align the bezel tooling pin into in the tooling holes at the top of the display assembly. Set the bezel in place and apply pressure.
Pull the rest of the red backing strips to expose the adhesive to the rest of the bezel.
While applying pressure with the flat side of the spudger, rub around the entire bezel to ensure the adhesive sets properly.
After the bezel adhesive has adequately cured, install the display assembly according to the Remplacement de l'écran complet du MacBook Pro 15" Unibody mi-2010 guide.
4 autres ont terminé cette réparation.
Un commentaire
Just finished this and here's my 2 cents:
1) If you use guitar picks to pry the bezel out you cant do it inside out. That means no need to mess with that rubber band that goes around it. Also means it wont look as bad (bowed) once you're done removing it;
2) It is aluminium so you can always un-bend the thing and straighten it up just be careful;
3) I realise it probably wasn't available at the time this guide was made but you can use the tape designed to hold thin edged iMac's displays. That's what I did anyway and it worked like a charm no need to bind anything (had one set of those tapes laying around for future project so that was easy to get :P).
Hope that helps :)
