Introduction
Wireless connectivity issues? Use this guide to replace the AirPort/Bluetooth board.
Ce dont vous avez besoin
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Pull the camera cable connector straight out of its socket on the logic board.
Peel and remove the piece of EMI tape wrapped around the AirPort/Bluetooth assembly.
43 autres ont terminé cette réparation.
21 commentaires
Pessoal; Será que temos com trocar essa peça Bluetooth 2.1 por um 4.0?
Folks; Do we have to change this piece Bluetooth 2.1 for a 4.0?
My computer was having trouble with the internet and after much research I came to the conclusion it was my airport/bluetooth board. A bunch of stores I went to said it would cost me around $200-$300 to replace ($100 for board and $100-$200 for installation). Then I found this cite and all of its manuals. I was able to order the part online from this site for only ~$50 and following the steps in the instructions was super easy. Would definitely give 10/10 for this website and manual.
I'd also like to point out I ordered the ifixit tool kit as well (just cause it looked awesome and I have no will power), but only the 2 tools mentioned in the instructions were needed. So no need to go overboard such as myself
Good chance it is the ribbon. I replaced the board with the one I ordered from this site. Worked great for about 2 months then had the same issue. Figured out it couldn't be the board that was causing the problem. So I played with it and I think it's my ribbon connections. All I do is every few months when I start to get the problem I open it up and reconnect the connections on the ribbon and it's good for another 2 months. I assume a permanent solution would be to buy a new ribbon but I haven't done that yet
I second this. My old computer started having bluetooth issues and I needed more power, so I bought a new one and gave the old to my wife. WiFi went out shortly thereafter. PRAM resets worked for a few minutes, but never very long. Replaced the ribbon (very easy, a bit cheaper), and bluetooth works great now, and wifi too. I would try the ribbon first (cheaper and much easier to do).
