Aller au contenu principal
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement
Ce dont vous avez besoin
  1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement, Battery: étape 1, image 1 de 1
    • Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
    Before upgrading to a larger HD, you'll want to "clone" your original HD using the donation-ware program "Carbon Copy Cloner" (http://www.bombich.com/). Put the new HD in an external case; clone the original; test the clone (by starting up with it), then take apart the MacBook to put the new HD in the MacBook, and the original in the external case for use as a backup, etc. (You can't just drag the contents of the original HD to the new HD, and expect it to work; not since the days of OS 9 and before.)
    amiller770 - Réponse
    Can I put more than two gigabytes of RAM in?
    Noah Nsangou - Réponse
    mine has 2g*2=4 gb ram in. you should be fine
    on mac forum it suggested to put 4gb and a 2gb in a1261.
    david -
    I made the mistake of wanting to do a clean install of OS and start fresh after installing a SSD. Now I can't install most browsers on OSX Leopard. Does anyone know what is the most current version of OS I can put on this system? (disk or download) Can I get to Snow or Lion?
    2006 17" MackBook Pro Model#A1151
    2.16 GHz Intel Core Duo
    Memory: Two 1GB 667 MHz
    Hard Drive: Corsair Force GS: SSD 128GB
    scannon - Réponse
    You can install OS X 10.7 LION and no later version. Although LION runs ok with 2GB RAM it does help to get 1GB + 2GB = 3GB. Even if you install 2 X 4GB you will only utilize 3GB. Installing a SSD seems to make no difference since the SATA bus is only 1.5GB/s. A good 5400rpm disk is good enough. I even run BootCamp and Windows 7. Works fine. Not fast but fine. My A1212 refuses to die :-)
    asle -
    There seems to be some discrepancy about whether or not installing a SSD will help. See Phil's earlier comment from October 2015: there, *he* claims that having an SSD increases the load times significantly, (even though -- of course -- 1.5Gbps is not ideal)...
    His quotation, (re-)cited integrally:
    Just replaced my old HD with a Corsair Force LX SSD (which is SATA 1-3 compatible as required by this model) with success now my old 'outdated' laptop has super fast loading times and is postively flying faster than the speed of 'sound'. Thanks for the guide. Only problem I faced was replacing the top panel which after a few minutes of panic realised the rubber mounted Mic next to the left speaker had risen up when I had removed the top panel so after carefully pushing it back into place the panel fitted back how it should, so beware of this possible problem.
    Phil - 10/07/2015
    at0gjm -
    Bonjour j'ai besoin de cette bactérie que dois-je faire ?
    basile kouamé YAO - Réponse
  2. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement, RAM Shield: étape 2, image 1 de 1
    • Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
  3. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement: étape 3, image 1 de 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement, Upper Case: étape 4, image 1 de 1
    • Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
    One of the screws here wouldn't bite going back in. I'm 100% certain it's the same screw that came out of it but it wouldn't bite going back, neither would any of the other two in this section in that particular hole.
    Damon B - Réponse
    To Damon - possibly the thread on the bottom of the upper case is obstructed.
    I found that I needed to fight the latch magnet with the right-most screw in the photo. The screw was pulled away from the hole so a magnetized screwdriver was not enough to place it. I needed tweezers to hold the screw in place until it bit.
    Yishai Sered - Réponse
    No, these screws won’t bite going back in — struggled for an hour. Lost hope of success.
    Case screw holes perfectly lined-up, neatly closed body, screw threads/head are fine (Apple quality screws), perfect screwdriver.
    The left one is in, other two simply will not bite whatsoever. Slightly irritating eventually turned to madly infuriating. I have a similar, earlier model and that was smooth to replace these exact, slightly angled screws (so I have experience).
    Q: Are the centre and right-hand screws absolutely essential — or can I give up and leave them out?
    (By the time you read this, that’s what I’ll have done)(out of sheer frustration)
    Steve Arkwright - Réponse
  5. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement: étape 5, image 1 de 1
    • Remove the following six screws:
    • Two 14.5 mm T6 Torx screws on either side of the RAM slot.
    • Four 3.4 mm Phillips screws along the hinge.
    Note for re-assembly: For the hinge use the longest four Phillips screws.
    R L - Réponse
    The Philips screws in Step 5 are longer than the other Philips screws. Would be better if the instructions differentiated them. Otherwise it is possible to use the wrong screws in Step 7 when reassembling.
    Alex - Réponse
    These instructions are actually wrong. The 14.5 mm screws are for along the hinge, the 2 on either side of the RAM slot are about 10 mm.
    Andrew Patterson - Réponse
  6. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement: étape 6, image 1 de 1
    • Remove the four 3.4 mm Phillips screws on the port side of the computer.
    When reassembling, please be careful not to screw into the wrong spot. I accidentally screwed into the DVI port and it was hard to remove the screw after that. I had to disassemble the whole thing again, only to find that I couldn't remove the screw from within as it was encased. After much scraping and prodding with a sewing needle, I was able to get that screw out. Phew!
    isotope434 - Réponse
  7. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement: étape 7, image 1 de 1
    • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
    Screw on the right is shorter
    mikefal - Réponse
    What are these two screws called?
    ian - Réponse
  8. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement: étape 8, image 1 de 1
    • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
  9. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement: étape 9, image 1 de 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
    WOW this step is very hard!!! its a serious suction cup..
    nya - Réponse
    Once the upper case is free...Carefully tilt the upper case from the front towards the screen as their is a ribbon cable directly beneath the keyboard and trackpad that will need to be removed in the next step.
    Troy - Réponse
    Be very careful not to bend the screw tabs on the top case the perimeter screws attach to. Bending them causes them to quickly fatigue and potentially break off. When reassembling the top case, be sure the tabs are all *inside* the case before reseating it. If you get resistance, pull the case back up, check the tabs and reseat the top case again.
    Sheldon Carpenter - Réponse
  10. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement: étape 10, image 1 de 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board.
    • Remove the upper case.
    Disconnecting this cable is optional, if instead you tip up the top case ~75 degrees, propping it up with something non-metalic (wedged in or by the battery compartment). Unplugging a connector from the main circuit board always carries slight additional risk.
    It's not really necessary to disconnect the trackboard/keyboard ribbon cable. You can simply lean the upper case against the LCD.
    Russ Greene - Réponse
    how reconnect this cable?
    anatole - Réponse
    I did this with and without step 10 (removing the upper case with detached cable). Removing the cable is risk, putting it back on was not so easy. But then, leaning the keyboard part against the LCD while replacing the hard drive is also risky.
    tobybaier - Réponse
    After having successfully removed/reattached the ribbon cable several times while trying to revive this computer for back-up use the securing/release tabs on the connector broke. The connector then will not hold the cable properly and connecting fails. Tried various methods of propping the cable in the connector to get full contact but eventually all efforts failed, too. Result: essentially a dead motherboard as no replacement for the connector seems available. Sadly, not worth the extra effort to try further repairs.
    Steve colton - Réponse
  11. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement, Left Speaker: étape 11, image 1 de 2 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement, Left Speaker: étape 11, image 2 de 2
    • Disconnect the two antenna cables attached to the AirPort Extreme card.
    • The cable with the gray shielding attaches to the left side connector, while the cable with the white shielding attaches to the right side.
    • For the A1261 model, The cable with the black shielding attaches to the left side connector, while the cable with the blue shielding attaches to the right side.
    • If you have a MacBook Pro 17" Model A1229 or A1212, there are three antenna cables attached to the AirPort Extreme card instead of two.
  12. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement: étape 12, image 1 de 1
    • Remove the single black 4.3 mm T6 Torx screw from the top right corner of the AirPort Extreme card.
  13. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement: étape 13, image 1 de 1
    • Lift the AirPort Extreme card up and slide it out of its connector.
  14. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement: étape 14, image 1 de 1
    • Remove the two silver T6 Torx screws from the top left 8 mm and bottom right 10 mm corners of the left speaker assembly.
    • The magnet in the MagSafe connector may pull the upper screw towards it after the screw has been freed.
  15. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement: étape 15, image 1 de 1
    • Lift up on the left speaker assembly and rotate it slightly. It is not possible to entirely remove the speaker yet, as it is still connected to the left I/O board beneath.
  16. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement: étape 16, image 1 de 1
    • Disconnect the two cables securing the left speaker to the I/O board.
    • Lift the left speaker out of the upper case.
  17. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement, Left I/O Board: étape 17, image 1 de 1
    • Disconnect the hard drive ribbon cable and the left I/O board ribbon cable from the logic board.
    • Disconnect the right speaker connector from the left I/O board.
  18. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement: étape 18, image 1 de 1
    • Remove the two silver T6 Torx screws securing the gray metal retaining bracket to the right side of the hard drive. 8 mm upper and 10 mm lower.
    • Lift the gray metal retaining bracket out of the computer.
  19. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement: étape 19, image 1 de 1
    • Remove the four 4.2 mm black or silver T6 Torx screws securing the left I/O board to the lower case.
    • Disconnect the large power connector from the left I/O board.
  20. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement: étape 20, image 1 de 1
    • Move the orange hard drive ribbon out of the way with one hand. Use your other hand to lift up the right side of the left I/O board and slide it out of the computer.
  21. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement: étape 21, image 1 de 1
    • Turn the left I/O board over.
    • Use a spudger to disconnect the short orange cable from the left I/O board.
  22. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement: étape 22, image 1 de 1
    • If you have a MacBook Pro 17" Model A1229, this step is not necessary.
    • Peel up the L-shaped piece of black tape on the I/O board to reveal the two silver Phillips screws beneath.
  23. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement: étape 23, image 1 de 2 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Replacement: étape 23, image 2 de 2
    • Remove the following four screws:
    • One 3.2 mm black Phillips screw with a small head.
    • Three 1.3 mm silver Phillips screws with large heads.
    • If you have a MacBook Pro 17" Model A1229, remove the four 1.3 mm silver Phillips screws with large heads.
    • The I/O board is now free from the ExpressCard cage.
26 autres ont terminé cette réparation.
iRobot
Membre depuis le 09/24/09
1 Réputation
636 tutoriels rédigés
2 commentaires
Great guide! Thanks!
Now to change the hinges and LCD screen! Already upgraded RAM (6GB), SSHD (1TB), and a new keyboard.
IT'S ALIIIIIVVVVEEEEE!!! LOL
Jason - Réponse
Are the A1229 Macbook I O Board Magsafe interchangeable with A1151 Macbook 17" ? Thanks
leticiaartist - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 9
Total : 20,836
