Aller au contenu principal
Il est possible que cette traduction ne reflète pas les dernières mises à jour du tutoriel source. Aidez à mettre à jour la traduction ou bien consultez le tutoriel source.
Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17"
Ce dont vous avez besoin
  1. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17", Boîtier inférieur: étape 1, image 1 de 1
    • Retirez les dix vis suivantes, fixant le boîtier inférieur au boîtier supérieur :
    • Trois vis Phillips 13,5 mm.
    • Sept vis Phillips 3 mm.
    important to reassemble the "lower case" successfully: the threads of the seven 3mm phillips screws are drilled at an angle :-/
    mysterioes - Réponse
    Same issue with me. After reassembling my 13-inch and my 17-inch, one of the screws are sticking out ever so slightly. Very annoying, especially since I scratch whatever surface I'm on now.
    Kyle Spadaro -
    Very important note; this guide is NOT correct for the Macbook Pro 17" A1297 late '11.
    The A1297 has an assembly adjacent to the optical drive, identifiable by 4 antenna connectors, 1 usb cable (with very small connector) and one PCI-e flat cable running across the optical drive.
    I did not take pictures, but found one on the web. I'm very new to iFixit and have no idea yet on how to create a guide, but here's the picture showing the assembly on top (this pic only has 3 antenna wires, the A1297 has 4, but at least you'll know what to look for.
    - carefully undo all connections and 2 screws
    - remove the assembly and flip it over
    - again carefully remove the shielding tape
    - undo 3 tiny screws
    - gently pry the airport card from the assembly (the flat cable will be a bit of a pain)
    - reverse process with replacement card.
    image can be found here:
    https://dl.dropboxusercontent.com/u/2446...
    Remon - Réponse
    It helps if you mark the holes where the long screws go so you can easily find them when the time comes to button things up. Also, a little dish or custard cup to hold those tiny screws is essential.
    Human - Réponse
    3 x 13.5 mm screws are actually TWO different types! Return to EXACT SAME HOLES.
    -I discovered this on my mid-2010, but from comments, sounds like it may affect other models as well
    2 x 13.5 mm screws are pointed ends
    1 x 13.5 mm screw is a FLAT end <- CORNER HOLE
    These areTWO slightly different lengths, and must return to correct holes. If you put the flat end screw in the wrong hole, it will stick out slightly. If you put either of the pointed screws in the wrong hole, they will go in all the way, but will not catch threads, and will simply fall out when laptop is flipped back over.
    scottbernardis - Réponse
    I printed out the image above and taped each screw to the photo as I removed each one, just to make sure I put them in the right location.
    Grace Morris - Réponse
    This is a brilliant suggestion! I did this for all the steps that involved removing screws, numbered the sheets, and that made it very easy to put it all back together in reverse. Thanks!
    Steve Adamczyk -
    Be sure to use Loctite on the screws when re-attaching the bottom of the computer. The screws can and will fall out once they have been removed for repairs if you do not put Loctite on them when you reuse them. Otherwise, purchase new screws before repairing the computer as the new screws come with Loctite material on them. (I have personal experience with this problem.)
    johnpartridge - Réponse
    Be sure NOT to Buy this Battery from iFixit. I bought it from eustore.ifixit.com and the Condition of Battery is : Service Battery ,
    from the &&^&^$^ first day.
    Till today my battery Cycle Count is: 80.
    I’ve tried everything as: Battery Calibration, resetting the SMC, PRAM, reinstalling the battery,
    and Service Battery warning still there.
    Just DO NOT BUY crappy, trash from here.
    I have very bad experience.
    Doruntin Koci - Réponse
    Hi Doruntin,
    we’re more than sorry to hear about your bad experience.
    I’ll inform our customer service team who’ll reach out to you and offer either a replacement or reimbursement.
    If ever you’d need assistance again, please feel free to directly write to eustore@ifixit.com, as comments are not regularly checked for service issues.
    I’m confident that we’ll find the solution that suits you best!
    Sandra Hiller -
    PLEASE OBSERVE: The image of the left speaker used is NOT for a 2011 model. A 17inch MacBook Pro A1297 - LEFT SPEAKER + MICROPHONE - 2011 has IDENTIFYING NUMBER: Apple Part #:922-9821, 922-9822. And its COMPATIBILITY: 17 inch MacBook Pro Unibody A1297 - Early 2011 MC725LL/A 2.2 i7 - Early 2011 MC725LL/A 2.3 i7 - Late 2011 MD311LL/A 2.4 i7 - Late 2011 MD311LL/A 2.5 i7
    kenneth krabat - Réponse
  2. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 2, image 1 de 2 Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 2, image 2 de 2
    • Calez vos doigts entre le boîtier inférieur et l'évent, et soulevez pour libérer les deux clips qui maintiennent le boîtier inférieur sur le boîtier supérieur.
    • Lors du réassemblage, alignez soigneusement le boîtier inférieur, puis appuyez fermement dessus jusqu'à ce que les deux clips s'enclenchent.
    • Retirez le boîtier.
    I recommend using anti-static protection, i.e., wearing a ground strap, or at least touch metal chassis inside the computer before unplugging cables. Otherwise, you might create an ESD discharge into your RAM and have to replace it like I did!
    d68ef792 - Réponse
  3. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17", Batterie: étape 3, image 1 de 3 Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17", Batterie: étape 3, image 2 de 3 Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17", Batterie: étape 3, image 3 de 3
    • Chaque fois que vous travaillez près de la carte mère, il est judicieux de débrancher d'abord la batterie pour éviter les courts-circuits.
    • Si elle est présente, saisissez la languette en plastique attachée au connecteur de la batterie et tirez-la vers le bord avant de l'appareil. Pour les modèles fin 2011, le connecteur de batterie n'a pas de languette mais simplement une prise qui s'insère directement dans la carte mère - pour la retirer, tirez-la vers le haut.
    • Si la languette en plastique est absente, utilisez une spatule (spudger) pour soulever le connecteur de sa prise.
    • Tirez la languette parallèlement à la face de la carte mère.
    This step is a little difficult in reverse, that is, when re-attaching the battery. It helps to tilt the laptop up so you can see the edge of the board that accepts the plug. It may look like there are two slots for it, it goes in the bigger slot that is further away from the board.
    yary hluchan - Réponse
    Is this step really necessary? It is not part of the instructions how to replace the HDD in Apple's User Manual of the 2011 17" MBP.
    Tobias Hahn - Réponse
    As it says in the step: "Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits." It is not required, but it is simple insurance to avoid a $1000+ repair should you accidentally short components on the board with something metal.
    Andrew Bookholt -
    There was no tab on my model. Battery is affixed to board and screws must be removed.
    bhodges2 - Réponse
    Mine also, and looks as if removing connector could damage motherboard.
    Stephen -
    The battery on my 17” mid-2010 (MC024LL/A -A1297 ) is held by 3 specialty screws CR-V1 (3-wings similar to Mercedes-Benz tri-star)
    It has a tab which I pulled straight up
    The connector to the motherboard came away easily by pulling toward the front edge.
    Peter Grierson -
    * There is no tab on the A1297 (late 2011) model's battery connector. Be careful with the connector, it chips off the edges easily! Otherwise the same as bhodges2 & Stephen's notes.
    ** (Pleas also include the exact Model and Part numbers like P/N: MD311D/A; Mod.: A1297 in the comments and notes for your MBP)
    Pingumann - Réponse
    Why are there no guides for the Late 2011 17" MacBook Pro A1297 (2.4GHz i7 quad core, MD311LL/A)??? I just replaced the RAM in mine and discovered that not only is there no tab on the battery connector, but the connector pulls straight up, perpendicular to the logic board, rather than parallel. I almost ripped the wires out of the connector by trying to pull it out parallel to the logic board like this guide instructed! After finally getting it out, my advice to those with the Late 2011 model is to use a spudger to loosen the edges of the connector then lift the connector straight up to get it out safely.
    Dave - Réponse
    I replaced the display on my late 2011 model and noticed that it was quite different than the tutorial given here so I detailed all the differences to help others with late-2011 models on my blog: http://johnfixesstuff.blogspot.com/2014/...
    jmueller -
    I just put an SSD in a model #A1297 - MC226LL/A and the battery connector had to be removed by pulling it parallel to and away from the logic board — in other words, not up. I was definitely a bit confused when I tried to pull it up.
    Doug Hogg - Réponse
    With some dexterity and carefulness, the MagSafe could be removed from its place without the need to remove the whole logic board!
    Phil Boy - Réponse
    Same here, I used a head-band light to see it and got it done without removing anything but the battery connection, the charging port and the display data cable. Then I had to do it again because amazone sent me the wrong charging port, the board has different width between screw holes, and on closer look, different components soldered on, also. AND, one is labeled 2008, the other 2009… make sure you get the correct one, the other ( “wrong”? ) might work, but I’m not risking it! So why does the 2008 fit in my 17” macbook pro(5,2) mid-2009 and the one labeled 2009 does not fit ? It is what it is…
    Tom Seaman -
    Peter Grierson - Réponse
  4. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17", Ventilateur droit: étape 4, image 1 de 3 Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17", Ventilateur droit: étape 4, image 2 de 3 Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17", Ventilateur droit: étape 4, image 3 de 3
    • Utilisez l'extrémité plate d'un spudger pour soulever le connecteur du ventilateur droit hors de sa prise sur la carte mère.
    • Il est utile de faire pivoter le spudger sous les câbles du ventilateur pour débrancher le connecteur.
    • La deuxième et la troisième photo montrent respectivement la prise et le connecteur du ventilateur. Veillez à ne pas casser la prise en plastique lorsque vous soulevez le connecteur avec votre spudger. La carte mère représentée sur la deuxième photo peut être légèrement différente de celle de votre machine, mais la prise reste identique.
    Needs a better photo to show how the plug is able to come off the socket vertically. In particular, the underside of the plug should be shown.
    Alexander Atkins - Réponse
  5. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 5, image 1 de 1
    • Retirez les trois vis cruciformes de 3,1 mm fixant le ventilateur droit sur la carte mère.
    • Dans le MacBook Pro 17" Unibody fin 2011, ces vis seront des Torx T6.
    The fan fixing screws on my 17-inch, Mid 2010 MacBook Pro were Torx 6, not Philips 00.
    Michael - Réponse
    ... And the fan fixing screws on my 2009 MBP were *smaller* that the size implied by the tool requirements for this project. I initially tried a Phillips 00 screwdriver but it nearly stripped the screw head. It was necessary to switch to a Phillips 000 bit to actually get two of the screws to move.
    RichardL -
    my mid 2010 mbp had Torx 7
    nielsdolieslager - Réponse
    Mine stripped and now I can't get it out, Phillips #00 is too large
    Fernando Tejeda - Réponse
    Not a big deal maybe but I have an Early 2011 and it doesn’t have the plastic tab on the battery connector (as if it were a Late 2011) AND it uses torx screws. So if you’re planning to tear into a 2011, get a torx screwdriver—there’s a chance you might need it even if you don’t have a Late 2011
    Segue - Réponse
  6. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 6, image 1 de 1
    • Retirez le ventilateur droit du boîtier supérieur, en tenant compte de son câble qui pourrait rester accroché.
  7. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17", Carte mère: étape 7, image 1 de 1
    • Utilisez l'extrémité plate d'un spudger pour soulever le connecteur de ventilateur gauche hors de sa prise sur la carte mère.
    • Il est utile de faire pivoter le spudger sous les câbles du ventilateur pour déconnecter le connecteur.
    On my 2011 MBP, the wiring is twisted a half turn. Its not possible to insert the connector the wrong way around, but it just seems sloppy that it was designed to require stressing the wire this way.
    anon - Réponse
  8. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 8, image 1 de 2 Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 8, image 2 de 2
    • Retirez les trois vis cruciformes de 3,1 mm fixant le ventilateur gauche sur la carte mère.
    • Retirez le ventilateur gauche du boîtier supérieur, en tenant compte de son câble susceptible de rester accroché.
    on my early-2011, these screws were Torx
    Segue - Réponse
  9. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 9, image 1 de 2 Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 9, image 2 de 2
    • Utilisez la pointe d'un spudger ou votre ongle pour retourner le clapet de retenue de la nappe du rétro-éclairage du clavier.
    • Assurez-vous de faire levier sur le volet de retenue et non sur la prise même.
    • Retirez la nappe du rétroéclairage du clavier de sa prise.
    “Pull” ??? Don’t you mean to say “slide horizontally towards the gap where the fan was?”
    anon - Réponse
    On my early 2011 Macbook Pro unibody 17” - there is another small cable to disconnect between this, the keyboard backlight ribbon cable and the optical drive cable. Not sure what it’s for, but thought to mention is. It is small metal plug and socket and says “AC” on it.
    Cyrus Buckley - Réponse
    I managed to pull the tiny retaining flap off of the socket entirely, then lost it… Not to worry, the ribbon cable sits securely in the socket even without the flap, and the keyboard backlight functions perfectly after reassembling the laptop
    D K - Réponse
    slide/wiggle gently parallel to the board - mine was sticky
    Andrew A - Réponse
  10. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 10, image 1 de 1
    • Avant de débrancher le câble de la caméra, il vous faut enlever un petit dispositif de retenue en plastique collé sur la carte mère.
    • Utilisez la pointe d'un spudger pour déplacer le petit dispositif de retenue en plastique loin de la prise du câble de la caméra et faire de la place pour enlever le câble de la caméra.
    exactly HOW do you remove it? pull up? slide horizontally?
    anon - Réponse
    On my late (?) 2011 MBP, this connector is very tiny, and the cable covers the screw holding the optical drive.
    The connector has two tiny metal tabs. Use your fingernails to slide it backwards horizontally towards the optical drive.
    anon - Réponse
    Bit of a levering horizontally. Remove the carbon fibre patterned tape off the top of the connector to expose the connector then slide (break the adhesive bond) on the small oblong black plastic passed, towards the optical drive module. The connector can then be disengaged. It's quite difficult to unlatch the connector! Take extreme care
    Paul Buckingham - Réponse
    not on my 17” late 2011
    On my late 2011 MBP there are two connectors at this place: One big connector like the silver one shown on the fotos (but in my case it is black), and the tiny one as discribed in the comment from anon 10/14/2017). In contrast to the fotos, this tiny connector is on the opposite side of the big one, on the edge close to the right fan. To disconnect this connector, follow the instructions from anon 10/14/2017.
    The cable going to the big connector is in my case a wide black ribbon cable running diagonically over the optical drive. To remove the connector of this cable from the socket, pry it upwards carefully with your fingernails or a spudger.
    Sebastian Plickert - Réponse
  11. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 11, image 1 de 1
    • Tirez le câble de la caméra vers l'ouverture du lecteur optique pour le déconnecter de la carte mère.
    • La prise du câble de la caméra est très fragile. Ne irez pas cette prise vers le haut car elle risque de se détacher de la carte mère. Tirez le câble de la caméra parallèlement à la surface de la carte mère.
    This step and the previous one (plastic retainer) were very different on my logic board. It's an early 2011, 17" that I bought second hand. I'm wondering if the logic board was previously replaced.
    Leo Magellan - Réponse
  12. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 12, image 1 de 1
    • Utilisez l'extrémité plate d'un spudger pour soulever le connecteur du lecteur optique vers le haut et hors de sa prise sur la carte mère.
  13. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 13, image 1 de 1
    • Utilisez l'extrémité plate d'un spudger pour soulever le connecteur du subwoofer et du haut-parleur droit hors de sa prise sur la carte mère.
    • Faites levier en dessous des fils.
    how do you reconnect this?
    jcatron3 - Réponse
  14. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 14, image 1 de 2 Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 14, image 2 de 2
    • Utilisez la pointe d'un spudger ou votre ongle pour faire retourner le clapet de retenue de la prise de la nappe du capteur infrarouge.
    • Assurez-vous de faire levier sur le clapet de retenue et non sur la prise même.
    • Retirez la nappe du capteur infrarouge de sa prise.
    The IR sensor cable also connects the Hall Effect switch that detects whether the lid is closed or open (and thus shuts off the display, puts the computer to sleep, wakes it up, etc.) to the logic board.
    How do I know? I re-pasted my late 2011 17" MBP and forgot to reconnect it. The machine would not sleep automatically when the lid was closed anymore. Re-connecting the cable fixed it.
    Kevin - Réponse
    thanks for the info !!!! i got the same problem with sleep because the cable was not properly connected
    Chin Soon Cheong -
    I can heartily recommend having a good magnifying glass at hand, it becomes much more obvious how all these tiny pieces fit together! At least for those of us without perfect vision...
    Lami - Réponse
  15. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 15, image 1 de 3 Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 15, image 2 de 3 Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 15, image 3 de 3
    • Retirez les quatre vis suivantes :
    • Deux vis cruciformes de 3,5 mm
    • Deux vis cruciformes de 1,6 mm
    • Retirez les protections des deux connecteurs de la carte mère.
    On my early 2011 laptop, the screws on the left hand shield were T6 screws. The others were Phillips head.
    Mark Morgan - Réponse
    The same applies to the late 2011 model.
    on my early 2011 model it seems that on the left hand shield (with the Torx screws) the track pad connector is stuck to the underside of the connector. It lifted off the logic board when I tried to remove the shield and I am leaving it like that until I can manage to access it better - maybe when the logic board is out.
    Lami - Réponse
  16. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 16, image 1 de 1
    • Utilisez l'extrémité plate d'un spudger pour soulever le connecteur du trackpad vers le haut et hors de sa prise sur la carte mère.
  17. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 17, image 1 de 2 Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 17, image 2 de 2
    • Utilisez votre ongle pour soulever le clapet de retenue sur la prise de la nappe du clavier.
    • Retirez la nappe du clavier de sa prise.
    • Pour le réassemblage, il est utile de mettre un petit morceau de bande adhésive sur la nappe du clavier (en prenant soin de ne pas coller les contacts) pour faire une sorte de petite poignée. Alignez la nappe avec la prise et tirez doucement avec la bande pour la sceller complètement.
    Thanks for the great guide!
    Tip for re-seating the keyboard cable: put a piece of sticky tape on, fold over at the top end, re-seat the connector (carefully!) with a spudger and (gently!) pull the tape 'over' the connector on the logic board until you feel it nudges in fully. Notice the emphasis on "carefully" and "gently"... :)
    LeonSteyns - Réponse
    Thanks for this manual! I used it to replace the keyboard. I would not recommend it as an easy job and it is not described on Ifixit for unknown reasons. But I did it and everytinhg worked fine. 2 remarks about the conncetion for the keyboard. In my Macbook 17 Pro (mid 2009) there is a litlle lever that clamps the keyboard 'cable'. You can get it out easily (I did that too because I did not see it then), but to reassemble it it is better to uplift the little lever and then move the 'cable' in with sticky tape (thanks for that tip!)
    I had to redo it 3 times to get it working. With the lever up and then clamping the 'cable' by pushing it down it worked AND it solved the power button problem. Please be carefull as said in the manual, it is all very delicate!
    And for replacing the keyboard; prepare yourself for a lot of tiny screws! (some of them are stuck and had to be removed with force, be warned!)
    Another tip
    Edlef Heeling - Réponse
  18. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 18, image 1 de 2 Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 18, image 2 de 2
    • Utilisez votre ongle pour faire basculer le clapet de retenue de la prise de la nappe de la carte express.
    • Retirez la nappe de la carte express de sa prise.
    It might be easier to remove the ExpressCard ribbon cable in Step 18 by removing the Hard Drive cable first...use your judgment.
    David DeAnda - Réponse
  19. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 19, image 1 de 1
    • Utilisez l'extrémité plate d'un spudger pour soulever le connecteur de la nappe du disque dur vers le haut et hors de sa prise sur la carte mère.
  20. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 20, image 1 de 2 Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 20, image 2 de 2
    • Utilisez la pointe d'un spudger ou de votre ongle pour faire basculer le clapet de retenue de la prise de la nappe de l'indicateur de la batterie.
    • Retirez la nappe de l'indicateur de la batterie de sa prise.
    When reassembling, slide the ribbon cable underneath the connector then lock it into place.
    Phil Melendez - Réponse
  21. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 21, image 1 de 3 Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 21, image 2 de 3 Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 21, image 3 de 3
    • Soulevez le clapet en plastique noir attaché au dispositif de retenue du câble de données de l'écran et tournez-le vers le côté DC-In du MacBook.
    • Retirez le câble de données de l'écran de sa prise.
    • La prise du câble de données de l'écran est très fragile. Ne soulevez pas le connecteur vers le haut lorsque vous le débranchez, car la prise risque de se détacher de la carte mère. Tirez sur le câble parallèlement à la surface de la carte mère.
    Be SUPER EXTRA CAREFUL when connecting this cable back!!! Use a magnifying glass or headset to see what you are doing.
    When I plugged it in the first time (finished the rest of the process and restarted the mac) I got green lines all over my screen…
    I replugged it a total of 4 times to get it right even cleaned it with alcohol. Now everything is working, but I freaked out a bit :)
    Tom - Réponse
    I would describe the removal as “sliding back towards the corner". “Pulling out", to me, implies pulling up away from the board.
    MaFt Morley - Réponse
    When reassembling, slide the cable underneath the connector. It doesn’t snap on.
    This is the trickiest step in this whole process, both detaching and reattaching. I’ve been through this logic board repair scenario with my Early 2011 about 4x now, and if, when you reassemble, you’re still having problems with your display of any sort, this is your number 1 achilles heel is this connector getting dirty (use high purity over 90% isopropyl alcohol often found at drug stores next to the regular 70% stuff for cleaning) or not seating properly. I have broken off the connector bracket mount that goes over the top but was able to use pure silicone to safely reattach it. Don’t break that top bracket off sliding this puppy out; it’s a very dicey situation!
    Segue - Réponse
    I had no idea what "toward the DC-in side" meant. "DC-in" refers to the Magsafe connector/port in the corner of the machine (upper right when the machine is facedown with lower case removed).
    The plastic flap and its little metal bracket broke off from the cable when I tried to rotate it out of the socket. Will this cause problems? I'm assuming it was just a handle. I was successfully able to slide the cable out, and then back into the socket on reassembly, even after the bracket/tab broke off.
  22. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 22, image 1 de 1
    • Retirez les huit vis suivantes fixant la carte mère et la carte DC-In au boîtier supérieur :
    • Six vis cruciformes de 3,2 mm
    • Deux vis cruciformes de 7,6 mm
    The Six 3.2mm screws can in some cases be torx instead of phillips
    Finntastic - Réponse
    I've got a great idea for keeping the tiny screws safe and also labelled up e.g. these 6+2 screws belong to the logic board - simply use 'Post-It' sticky note upside down on your desk and use the sticky bit to keep the screws from rolling around getting themselves lost :-)
    Paul Reddington - Réponse
  23. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 23, image 1 de 2 Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 23, image 2 de 2
    • Manipulez l'ensemble carte mère uniquement par ses bords.
    • Soulevez l'ensemble carte mère du côté le plus proche du lecteur optique et retirez-le du boîtier supérieur.
    • Notez que vous enlevez d'un bloc la carte mère et la carte DC-in.
    • Dégagez délicatement les ports et la carte DC-In du côté du boîtier supérieur et retirez l'ensemble carte mère, en tenant compte des câbles susceptibles de rester accrochés.
    When lifting the logic board be careful! The rubber foam around the microphone may have adhered the microphone to the uppercases grill work so as you lift you could rip the connector from the ribbon cable.
    * Take a small spatula and thought the fan opening carefully dislodge the microphone from the grill as you lift the logic board.
    * To locate the microphone note on the next slide the small unit between the fingers of the hands.
    Dan - Réponse
    You need to remove the Phillips screws near the optical drive. I don’t see that in the instructions anywhere.
    David - Réponse
    Attach the DC connector with screws first when reassembling.
  24. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17", Dissipateur de chaleur: étape 24, image 1 de 1
    • Retirez les huit vis Phillips de 8,3 mm fixant le dissipateur de chaleur à la carte logique.
    • Assurez-vous de garder trace des ressorts tenus sous chacune des vis.
    My heat sink did not look like this. It did not have the ninety degree bend to the left at the bottom. It was just "T" shaped, not like the "J" shape depicted here. Does this mean the logic board was previously replaced? (Early 2011, 17-inch, 2.2GHz)
    No, I think that it is just different on the early 2011 model, mine is the same. There are lots of small and larger differences between this guide and our model. There are only 6 screws,
    Lami -
  25. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 25, image 1 de 1
    • Pressez le câble du capteur thermique du dissipateur de chaleur entre votre pouce et la pointe d'un spudger.
    • Soulevez le spudger vers le haut pour soulever le connecteur du capteur thermique de sa prise sur la carte logique.
    My mid-2009 MBP didn’t have a connector (socket is on the board, but there’s no cable to be plugged into it). Found in an Apple technician manual a mention that some versions of the MBP don’t have the thermal sensor, so apparently that’s okay.
    Steve Adamczyk - Réponse
  26. Remplacement du dissipateur de chaleur du MacBook Pro Unibody 17": étape 26, image 1 de 1
    • Retirez le dissipateur thermique de la carte logique.
    • Si le dissipateur de chaleur semble collé à la carte logique après avoir retiré les huit vis, il peut être utile d'utiliser un spudger pour séparer les deux composants.
    • Si vous avez besoin de monter le dissipateur de chaleur sur la carte logique, nous avons un guide de pâte thermique qui rend le remplacement du composé thermique facile.
    Bonjour. Peut-on remplacer la pâte thermique d’origine par des pads thermiques au graphite? Merci
    Kazahaya gmail - Réponse
Pour remonter votre appareil, suivez les étapes dans l'ordre inverse.
33 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
85%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
10 commentaires
After compleating this repair , my mac had the normal hard drive noise then a chime did not even grey screen . almost instantly I smelt fire and saw smoke pouring out of the case.. maac was on battery at the time .. I opened it up and disconected the battery and then I saw the video display cable (Step 21 ) it had glowing embers on the tape and tottally melted one side of it ... the connector to the logic board has black marks , but i do not know if the damage is extened to the logic board or if I can get away with a new dispay data cable , dont even know where to source one here in NZ .. any help would be great
kevinleroy - Réponse
I completed this guide. When I finished the macbook would not turn on => PANIC
I went over and the problem was the keyboard cable. The Step 17 is a little difficult in reverse. Pay special atention at the correct position of the keyboard ribbon cable.
It was a little scare. Otherwise all perfect! Thank you very much!
maruxa - Réponse
Successfully changed the thermal paste by following this guide. My MacBook Pro had some issues after I put it back together because of loose and improperly seated cables. In my case, the display cable wasn't seated properly and the IR-sensor cable was loose. So if your machine doesn't turn on, or something seems to be working incorrectly, it's definitely worth double checking the cables.
jongoldsz - Réponse
did changing the thermal paste lower your temps? what was it before, what is it now? thanks for sharing.
B S -
Yes B S, the temps will be lower. Apple is known to put only a tiny amount or bad quality thermal paste on their machines, so even is a Mac is brand new, temperatures will be better if the thermal paste is replaced. I have replaced thermal paste on numerous computers and have never regretted it :)
Tsaku -
Très bon guide pour changer la pâte thermique de mon MacBook Pro Late 2011 qui commençait à trop chauffer.
Cela permet de se rendre compte qu’après un changement de carte mère effectué par Apple, la moitié des vis est mal serrée, il y a 10 fois trop de pâte thermique sur le processeur et le chip graphique au point que ça a coulé sur les petits composants sur le côté des puces.
Merci
Olivier - Réponse
Dommage :/ Au prix qu’Apple demande, le travail devrait pourtant être bien fait… Content que vous ayez pu régler votre problème, un changement de pâte thermique est toujours une bonne idée :)
Tsaku -
This guide sucks. It tells you to use the wrong size bit on step 5 which stripped the screw needed. Now I cant get it out. Very frustrating. Ifixit screwed me over on this one.
J Jones - Réponse
Thank you for this guide, smooth and easy !!!
analfabetagoloso - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 22
30 derniers jours : 67
Total : 38,965
