Aller au contenu principal
Remplacement de l'écran LCD du MacBook Pro 17" Unibody
Ce dont vous avez besoin
  1. Remplacement de l'écran LCD du MacBook Pro 17" Unibody, Boîtier inférieur: étape 1, image 1 de 1
    • Retirez les dix vis suivantes, fixant le boîtier inférieur au boîtier supérieur :
    • Trois vis Phillips 13,5 mm.
    • Sept vis Phillips 3 mm.
    important to reassemble the "lower case" successfully: the threads of the seven 3mm phillips screws are drilled at an angle :-/
    mysterioes - Réponse
    Same issue with me. After reassembling my 13-inch and my 17-inch, one of the screws are sticking out ever so slightly. Very annoying, especially since I scratch whatever surface I'm on now.
    Kyle Spadaro -
    Very important note; this guide is NOT correct for the Macbook Pro 17" A1297 late '11.
    The A1297 has an assembly adjacent to the optical drive, identifiable by 4 antenna connectors, 1 usb cable (with very small connector) and one PCI-e flat cable running across the optical drive.
    I did not take pictures, but found one on the web. I'm very new to iFixit and have no idea yet on how to create a guide, but here's the picture showing the assembly on top (this pic only has 3 antenna wires, the A1297 has 4, but at least you'll know what to look for.
    - carefully undo all connections and 2 screws
    - remove the assembly and flip it over
    - again carefully remove the shielding tape
    - undo 3 tiny screws
    - gently pry the airport card from the assembly (the flat cable will be a bit of a pain)
    - reverse process with replacement card.
    image can be found here:
    https://dl.dropboxusercontent.com/u/2446...
    Remon - Réponse
    It helps if you mark the holes where the long screws go so you can easily find them when the time comes to button things up. Also, a little dish or custard cup to hold those tiny screws is essential.
    Human - Réponse
    3 x 13.5 mm screws are actually TWO different types! Return to EXACT SAME HOLES.
    -I discovered this on my mid-2010, but from comments, sounds like it may affect other models as well
    2 x 13.5 mm screws are pointed ends
    1 x 13.5 mm screw is a FLAT end <- CORNER HOLE
    These areTWO slightly different lengths, and must return to correct holes. If you put the flat end screw in the wrong hole, it will stick out slightly. If you put either of the pointed screws in the wrong hole, they will go in all the way, but will not catch threads, and will simply fall out when laptop is flipped back over.
    scottbernardis - Réponse
    I printed out the image above and taped each screw to the photo as I removed each one, just to make sure I put them in the right location.
    Grace Morris - Réponse
    This is a brilliant suggestion! I did this for all the steps that involved removing screws, numbered the sheets, and that made it very easy to put it all back together in reverse. Thanks!
    Steve Adamczyk -
    Be sure to use Loctite on the screws when re-attaching the bottom of the computer. The screws can and will fall out once they have been removed for repairs if you do not put Loctite on them when you reuse them. Otherwise, purchase new screws before repairing the computer as the new screws come with Loctite material on them. (I have personal experience with this problem.)
    johnpartridge - Réponse
    Be sure NOT to Buy this Battery from iFixit. I bought it from eustore.ifixit.com and the Condition of Battery is : Service Battery ,
    from the &&^&^$^ first day.
    Till today my battery Cycle Count is: 80.
    I’ve tried everything as: Battery Calibration, resetting the SMC, PRAM, reinstalling the battery,
    and Service Battery warning still there.
    Just DO NOT BUY crappy, trash from here.
    I have very bad experience.
    Doruntin Koci - Réponse
    Hi Doruntin,
    we’re more than sorry to hear about your bad experience.
    I’ll inform our customer service team who’ll reach out to you and offer either a replacement or reimbursement.
    If ever you’d need assistance again, please feel free to directly write to eustore@ifixit.com, as comments are not regularly checked for service issues.
    I’m confident that we’ll find the solution that suits you best!
    Sandra Hiller -
    PLEASE OBSERVE: The image of the left speaker used is NOT for a 2011 model. A 17inch MacBook Pro A1297 - LEFT SPEAKER + MICROPHONE - 2011 has IDENTIFYING NUMBER: Apple Part #:922-9821, 922-9822. And its COMPATIBILITY: 17 inch MacBook Pro Unibody A1297 - Early 2011 MC725LL/A 2.2 i7 - Early 2011 MC725LL/A 2.3 i7 - Late 2011 MD311LL/A 2.4 i7 - Late 2011 MD311LL/A 2.5 i7
    kenneth krabat - Réponse
  2. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 2, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 2, image 2 de 2
    • Calez vos doigts entre le boîtier inférieur et l'évent, et soulevez pour libérer les deux clips qui maintiennent le boîtier inférieur sur le boîtier supérieur.
    • Lors du réassemblage, alignez soigneusement le boîtier inférieur, puis appuyez fermement dessus jusqu'à ce que les deux clips s'enclenchent.
    • Retirez le boîtier.
    I recommend using anti-static protection, i.e., wearing a ground strap, or at least touch metal chassis inside the computer before unplugging cables. Otherwise, you might create an ESD discharge into your RAM and have to replace it like I did!
    d68ef792 - Réponse
  3. Remplacement de l'écran LCD du MacBook Pro 17" Unibody, Batterie: étape 3, image 1 de 3 Remplacement de l'écran LCD du MacBook Pro 17" Unibody, Batterie: étape 3, image 2 de 3 Remplacement de l'écran LCD du MacBook Pro 17" Unibody, Batterie: étape 3, image 3 de 3
    • Chaque fois que vous travaillez près de la carte mère, il est judicieux de débrancher d'abord la batterie pour éviter les courts-circuits.
    • Si elle est présente, saisissez la languette en plastique attachée au connecteur de la batterie et tirez-la vers le bord avant de l'appareil. Pour les modèles fin 2011, le connecteur de batterie n'a pas de languette mais simplement une prise qui s'insère directement dans la carte mère - pour la retirer, tirez-la vers le haut.
    • Si la languette en plastique est absente, utilisez une spatule (spudger) pour soulever le connecteur de sa prise.
    • Tirez la languette parallèlement à la face de la carte mère.
    This step is a little difficult in reverse, that is, when re-attaching the battery. It helps to tilt the laptop up so you can see the edge of the board that accepts the plug. It may look like there are two slots for it, it goes in the bigger slot that is further away from the board.
    yary hluchan - Réponse
    Is this step really necessary? It is not part of the instructions how to replace the HDD in Apple's User Manual of the 2011 17" MBP.
    Tobias Hahn - Réponse
    As it says in the step: "Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits." It is not required, but it is simple insurance to avoid a $1000+ repair should you accidentally short components on the board with something metal.
    Andrew Bookholt -
    There was no tab on my model. Battery is affixed to board and screws must be removed.
    bhodges2 - Réponse
    Mine also, and looks as if removing connector could damage motherboard.
    Stephen -
    The battery on my 17” mid-2010 (MC024LL/A -A1297 ) is held by 3 specialty screws CR-V1 (3-wings similar to Mercedes-Benz tri-star)
    It has a tab which I pulled straight up
    The connector to the motherboard came away easily by pulling toward the front edge.
    Peter Grierson -
    * There is no tab on the A1297 (late 2011) model's battery connector. Be careful with the connector, it chips off the edges easily! Otherwise the same as bhodges2 & Stephen's notes.
    ** (Pleas also include the exact Model and Part numbers like P/N: MD311D/A; Mod.: A1297 in the comments and notes for your MBP)
    Pingumann - Réponse
    Why are there no guides for the Late 2011 17" MacBook Pro A1297 (2.4GHz i7 quad core, MD311LL/A)??? I just replaced the RAM in mine and discovered that not only is there no tab on the battery connector, but the connector pulls straight up, perpendicular to the logic board, rather than parallel. I almost ripped the wires out of the connector by trying to pull it out parallel to the logic board like this guide instructed! After finally getting it out, my advice to those with the Late 2011 model is to use a spudger to loosen the edges of the connector then lift the connector straight up to get it out safely.
    Dave - Réponse
    I replaced the display on my late 2011 model and noticed that it was quite different than the tutorial given here so I detailed all the differences to help others with late-2011 models on my blog: http://johnfixesstuff.blogspot.com/2014/...
    jmueller -
    I just put an SSD in a model #A1297 - MC226LL/A and the battery connector had to be removed by pulling it parallel to and away from the logic board — in other words, not up. I was definitely a bit confused when I tried to pull it up.
    Doug Hogg - Réponse
    With some dexterity and carefulness, the MagSafe could be removed from its place without the need to remove the whole logic board!
    Phil Boy - Réponse
    Same here, I used a head-band light to see it and got it done without removing anything but the battery connection, the charging port and the display data cable. Then I had to do it again because amazone sent me the wrong charging port, the board has different width between screw holes, and on closer look, different components soldered on, also. AND, one is labeled 2008, the other 2009… make sure you get the correct one, the other ( “wrong”? ) might work, but I’m not risking it! So why does the 2008 fit in my 17” macbook pro(5,2) mid-2009 and the one labeled 2009 does not fit ? It is what it is…
    Tom Seaman -
    Peter Grierson - Réponse
  4. Remplacement de l'écran LCD du MacBook Pro 17" Unibody, Écran complet: étape 4, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 17" Unibody, Écran complet: étape 4, image 2 de 2
    • Avant de déconnecter la nappe de la caméra, il faut enlever un petit dispositif d'attache en plastique, fixé à la carte mère. Sur les modèles fin 2011, vous pouvez sauter cette étape, car ils n'ont pas ce dispositif d'attache du connecteur de la nappe de la caméra.
    • Avec la pointe d'une spatule (spudger), poussez le petit dispositif d'attache en plastique hors de la prise de la nappe de la caméra, de façon à y voir clair quand vous retirez cette nappe.
    I think I should have a photo of the plastic retainer as there may be more people like me who were afraid to take the part.
    Cassio Machado - Réponse
  5. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 5, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 5, image 2 de 2
    • Tirez la nappe de la caméra vers l'ouverture du lecteur optique pour la déconnecter de la carte mère.
    • La prise de la nappe de la caméra est très fragile. N'exercez pas de pression sur la prise vers le haut, car elle pourrait se détacher de la carte mère. Tirez sur la nappe parallèlement à la surface de la carte mère.
  6. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 6, image 1 de 1
    • Tirez délicatement la nappe Bluetooth vers les ventilateurs pour la déconnecter de la carte Bluetooth.
    • Tirez sur la nappe parallèlement à la surface du lecteur optique.
    These pictures are not whats on my a1297. For example the Bluetooth connector is not set up like this. Its actually set up like the Late 2011 A1286. Not sure which model this is.
    Sean Love - Réponse
  7. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 7, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 7, image 2 de 2
    • Avec l'extrémité plate d'une spatule, décollez la fine couverture en plastique sur le haut et les bords du boîtier de la carte Bluetooth. Pour les modèles fin 2011, regardez la seconde photo, car le connecteur est à un tout autre endroit.
  8. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 8, image 1 de 1
    • Avec l'extrémité plate d'une spatule, soulevez le connecteur de l'antenne Bluetooth pour le débrancher de sa prise sur la carte Bluetooth.
  9. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 9, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 9, image 2 de 2
    • Enlevez la petite pièce de mousse EMI, si il y en a une à côté de la carte Bluetooth.
    • Dégagez la nappe de la caméra de la fente moulée dans le boîtier de la carte Bluetooth.
  10. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 10, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 10, image 2 de 2
    • Dévissez les deux vis cruciformes de 7,1 mm fixant le support de la nappe de la caméra au boîtier supérieur.
    • Ôtez du boîtier supérieur le support de la nappe de la caméra.
  11. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 11, image 1 de 3 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 11, image 2 de 3 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 11, image 3 de 3
    • Saisissez la languette en plastique noire fixée au dispositif de verrouillage du câble de données de l'écran et faites-la pivoter vers le côté DC-In (prise d'alimentation) de l'ordinateur.
    • Tirez le câble de données de l'écran hors de sa prise.
    • La prise du câble de données de l'écran est très fragile. Ne tirez pas le connecteur vers le haut, car la prise pourrait se détacher de la carte mère. Tirez sur le câble parallèlement à la surface de la carte mère.
  12. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 12, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 12, image 2 de 2
    • Dévissez les deux vis cruciformes de 7,1 mm fixant le support du câble de données de l'écran au boîtier supérieur.
    • Retirez le support du câble de données de l'écran.
  13. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 13, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 13, image 2 de 2
    • Dévissez les deux vis extérieures Torx T6 de 6,8 mm fixant chacune des deux fixations de l'écran (quatre vis au total).
    • Nous vous demandons intentionnellement de laisser une des vis fixant les fixations de l'écran au boîtier supérieur, car cela facilite les étapes suivantes.
    I viewed a YouTube video showing this process. There was a warning about the stripping of the Torx screws being common on this mid-2009 model MBP. Is that something you have come ever across? It's the only thing holding me back from attempting this myself. TY in advance!
    s0mvh - Réponse
    Taking those hinge screws out can be difficult (they are fat, and they resist turning). In my first attempt I destroyed the Torx screwdriver bit (soft metal, I discovered, so the bit twisted into a corkscrew before it snapped off). After buying the ifixit screwdriver set I found that the driver bits were tough enough, but the screws still would not budge! So, I used a small mole-grip wrench to hold the metal part of the screwdriver, and GENTLY turned until I felt the screw give way with a click. Luckily, the threads did not strip. However, if you find that even with that extra torque from the wrench, it is still resisting in a big way, go one more step and try a very tiny drop of thread-loosening fluid on it. (That last suggestion, however, is risky, so be careful.... do not let any fluid get anywhere except the screw, and then give it time to work).
    RichardL -
    What's the url to the youtube video you mentioned?
    David Fear -
    Too late. I should have read the comments first but I was rushing. I just stripped two of them. They are in there super tight.
    Sean Love -
    I just did this now (11:21 am, Sept 18 2014) A tip for removing glass bezel on the frame if you don't have a heat gun. I used a very sharp but super thin razor (the one for shaving) and slice the adhesive. Be careful not to hit the lcd. After slicing all around, get any thin plastic card and slide it all around the bezel until the glass comes off. I have a mid 09 macbook pro 17" that had a broken lcd and a 2010 macbook pro i7 17" that had a logic board problem but good lcd. Both A1297. I did it twice using my method.
    J A N Marquez - Réponse
    Thanks! This made my display so much easier ...and I just love my new ifixit toolkit. Now... what else can I fix! lol Much appreciated!
    Leshell - Réponse
    Be super careful with this part. I just stripped two of these t6 screws and have two more that will not budge. Now I have to figure out how to get them out. How did these get so tight? What a headache.
    Sean Love - Réponse
  14. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 14, image 1 de 1
    • Ouvrez votre MacBook Pro de sorte que l'écran est perpendiculaire au boîtier supérieur.
    • Posez votre MacBook Pro ouvert sur une table comme sur la photo.
    • Pendant que vous maintenez l'écran et le boîtier supérieur de la main gauche, dévissez la vis Torx T6 restante de la fixation inférieure de l'écran.
  15. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 15, image 1 de 1
    • Veillez à maintenir l'écran et le boîtier supérieur avec votre main (gauche). Si vous les lâchez, vous risquez de faire tomber l'écran ou le boîtier inférieur et donc de les abîmer.
    • Dévissez la dernière vis Torx T6 fixant l'écran au boîtier supérieur.
  16. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 16, image 1 de 3 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 16, image 2 de 3 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 16, image 3 de 3
    • Saisissez le boîtier supérieur de votre main droite et faites-le légèrement pivoter vers le haut de l'écran de sorte que la fixation supérieure de l'écran s'éloigne du bord du boîtier supérieur.
    • Faites pivoter et éloignez légèrement l'écran du boîtier supérieur.
    • Soulevez et éloignez l'écran du boîtier supérieur en veillant à ce que ni les fixations ni les nappes ne restent accrochées.
    • Lors du remontage, mettez l'écran en place et installez les vis Torx de la fixation d'écran, puis fermez l'écran et posez l'ordinateur portable à l'envers pour vérifier l'alignement de l'écran avec le reste de l'ordinateur. Si nécessaire, desserrez les vis et réalignez l'écran avant de les resserrer.
  17. Remplacement de l'écran LCD du MacBook Pro 17" Unibody, Vitre avant de l'écran: étape 17, image 1 de 3 Remplacement de l'écran LCD du MacBook Pro 17" Unibody, Vitre avant de l'écran: étape 17, image 2 de 3 Remplacement de l'écran LCD du MacBook Pro 17" Unibody, Vitre avant de l'écran: étape 17, image 3 de 3
    • Le joint en caoutchouc autour de l'écran se déforme facilement sous l'effet de la chaleur. Il vaut donc mieux l'enlever avant d'utiliser le pistolet à air chaud pour démonter la vitre de l'écran.
    • Insérez un outil en plastique sous le joint en caoutchouc noir dans le coin supérieur gauche de l'ensemble écran.
    • Soulevez délicatement le coin du joint au-dessus du boîtier arrière.
  18. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 18, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 18, image 2 de 2
    • En commençant par le coin déjà dégagé, enlevez le joint le long du bord gauche de l'écran.
  19. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 19, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 19, image 2 de 2
    • Continuez à enlever le joint en caoutchouc le long du bord supérieur de l'écran.
  20. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 20, image 1 de 3 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 20, image 2 de 3 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 20, image 3 de 3
    • Continuez à enlever le joint en caoutchouc le long du bord droit de l'écran.
    • Enlevez le joint le long du bord inférieur de l'écran pour qu'il soit complètement défait, puis mettez-le de côté.
  21. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 21, image 1 de 1
    • Au cours des étapes suivantes, vous aurez besoin d'une pistolet à air chaud pour ramollir la colle fixant la bordure extérieure noire à l'écran tout le long de la face intérieure de la vitre avant.
    • Avant de commencer, veillez à nettoyer la vitre avec un chiffon non pelucheux humidifié avec une solution lavante douce ; cela permettra à la ventouse à levier de mieux adhérer et à vous de vérifier plus facilement l'absence de poussière lors du remontage.
    • Réglez le pistolet à air chaud à température basse et commencez à chauffer la bordure extérieure noire, du côté du coin supérieur droit de l'écran.
    • Pendant que vous chauffez, il est normal qu'une couche de condensation se forme à l'intérieur de la vitre et/ou à l'extérieur de l'écran LCD. Vous pouvez l'enlevez avec du nettoyant pour vitres une fois que la vitre est séparée de l'écran.
    Problem: A model A1297 does not have the black border, it has an aluminum bezel. Wondering if it too, comes up by heat?
    buz - Réponse
    I didn’t want to wake people in the house at midnight with a heat gun so i tried something else and it worked fantastically well.
    1) i used an oil-filled electric radiator and set it to high
    2) I put a small box (about 6 x 9”) on that radiator
    3) i put the display face-down on the box ; the box deflects the heat to the edges and slowly heats the edges to a nice hot temp not too hot.
    4) I used 4 credit cards as i didn’t have guitar picks. I was able to do all four sides with one heating process.
    I was still able to touch the surface it was probably under 180° (the magic temp that virtually any electronic device can survive).
    I’ve used toaster ovens to preheat an iPad for screen removal; this works much better it only heated the edge.
    awr - Réponse
  22. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 22, image 1 de 3 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 22, image 2 de 3 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 22, image 3 de 3
    Outil utilisé dans cette étape :
    Heavy-Duty Suction Cups (Pair)
    $14.95
    J'achète
    • Une fois que la vitre a été suffisamment chauffée, fixez une ventouse à levier à côté du coin supérieur droit de la vitre.
    • Si vous utilisez une de nos ventouses, posez-la, la poignée mobile parallèle à la surface de la vitre. Puis, tout en appuyant légèrement la ventouse sur la vitre, relevez la poignée mobile jusqu'à ce qu'elle soit parallèle à l'autre poignée.
    • Soulevez délicatement le coin de la vitre de façon à insérer un médiator de guitare entre elle et l'ensemble écran.
    • Avec le médiator, faites céder délicatement la colle fixant la vitre avant à l'écran.
    • Soulevez la vitre le long du bord droit de l'écran jusqu'au milieu.
    • Laissez le médiator en place au milieu du bord droit de l'écran et enlevez la ventouse.
  23. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 23, image 1 de 3 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 23, image 2 de 3 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 23, image 3 de 3
    • Avec un pistolet à air chaud, faites ramollir la colle sous la vitre le long des bords droit et supérieur de l'écran.
    • Fixez une ventouse à levier du coin supérieur droit de la vitre avant.
    • Soulevez la vitre pendant que vous la séparez du reste de l'ensemble écran avec un autre médiator de guitare.
    • Progressez le long du bord droit de la vitre avant jusqu'à ce qu'il soit séparé de l'écran.
  24. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 24, image 1 de 1
    • Progressez le long du bord supérieur de l'écran, en faisant précautionneusement céder la colle avec le médiator.
    • Arrêtez-vous environ 2,5 cm avant d'atteindre la caméra iSight. Laissez-y le médiator et enlevez la ventouse à levier.
  25. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 25, image 1 de 3 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 25, image 2 de 3 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 25, image 3 de 3
    • Répétez les étapes 22 à 24 pour le côté gauche et le bord gauche supérieur de l'écran.
  26. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 26, image 1 de 1
    • Après avoir travaillé sur trois côtés de la vitre, vous devez normalement avoir quatre médiators de guitare sous la vitre, comme sur la photo.
  27. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 27, image 1 de 3 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 27, image 2 de 3 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 27, image 3 de 3
    • Le pistolet à air chaud réglé sur température basse, faites chauffer le bord inférieur de l'écran pour ramollir la colle qui maintient la vitre en place.
    • Un certain nombre de câbles et la carte AirPort se trouvent sous le cache charnière, ne chauffez donc pas trop longtemps cette zone.
    • Soulevez lentement le bord supérieur de la vitre et faites-la pivoter délicatement pour l'éloigner de l'écran.
    • Si nécessaire, utilisez un outil en plastique pour dégager toute partie du bord inférieur de la vitre, toujours attachée.
    • Avant le remontage, veillez à nettoyer l'intérieur de la vitre ainsi que l'écran LCD, car toute poussière ou empreinte digitale à l'intérieur se verra et gênera dès que l'ordinateur sera allumé.
  28. Remplacement de l'écran LCD du MacBook Pro 17" Unibody, Cache charnière: étape 28, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 17" Unibody, Cache charnière: étape 28, image 2 de 2
    • En tenant fermement le cache charnière, faites-le glisser vers la charnière droite de l'écran.
    • Le cache charnière se déplacera d'environ 1 cm. Ne le forcez pas au-delà.
  29. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 29, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 29, image 2 de 2
    • En soulevant le bord gauche du cache charnière, faites-le doucement balancer d'arrière en avant sur son long axe pendant que vous l'ôtez de l'écran.
    • Ôtez le cache charnière de l'écran, en évitant qu'une nappe ne reste accroché.
    How the he'll do I get it back on?
    liam Carroll - Réponse
    How the he'll do you get the cover back on?
  30. Remplacement de l'écran LCD du MacBook Pro 17" Unibody, Écran LCD: étape 30, image 1 de 1
    • Dévissez les quatre vis cruciformes #00 de 2,3 mm fixant l'écran LCD à la coque arrière de l'écran.
  31. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 31, image 1 de 3 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 31, image 2 de 3 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 31, image 3 de 3
    • Soulevez un des coins supérieurs du panneau LCD hors de la coque arrière à l'aide d'un outil en plastique.
    • Saisissez les deux coins supérieurs du LCD et faites-le pivoter vers le haut et légèrement hors de l'écran.
    • Tirez le LCD vers le haut du panneau de l'écran en dégageant les tarauds de vis sous la coque arrière de l'écran.
    When replacing the LCD not only do the screw tabs at hinge side have to slide into their slots but also LCD extends at that end into a slot leaving the groove free for the clutch cover
    osdoctor1 - Réponse
  32. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 32, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 32, image 2 de 2
    • Faites soigneusement passer le câble LCD à travers la fente dans la coque arrière de l'écran.
    • Vous devrez peut-être faire légèrement pivoter l'écran pour faire passer le câble.
  33. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 33, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 33, image 2 de 2
    • Retournez l'écran LCD et posez-le face vers le bas en veillant à ne pas trop tirer sur le câble de l'écran.
    • Décollez le morceau de bande adhésive recouvrant le connecteur du câble de données de l'écran sur le bord le plus proche du LCD.
  34. Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 34, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 17" Unibody: étape 34, image 2 de 2
    • Avec la pointe d'une spatule, ouvrez le fin clapet de retenue en acier, qui maintient le câble de données de l'écran dans sa prise sur le LCD.
    • Tirez le câble de données de l'écran tout droit hors de sa prise sur l'écran LCD.
    • Ôtez le LCD de l'ensemble écran et mettez-le de côté.
Pour remonter votre ordinateur, suivez ces instructions en sens inverse.
32 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Brett Hartt
Membre depuis le 04/12/10
127 897 Réputation
143 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 817 tutoriels rédigés
8 commentaires
As much a question as a comment. I have the antiglare version of this MBP which has a 10mm aluminium surround on the screen (it isn't listed on the MBP page) so this guide only applies, as far as I can tell, up to step 16.
As I'm not sure how things progress from there on, I think I'll not venture so far.
Alf - Réponse
There is a guide for the 15" MacBook Pro that illustrates replacing the matte screen. In fact, you can pretty much follow that guide all the way through for the 17" as well. There are a few differences but not enough to trip you up.
Replacing the screen, the only trouble I encountered was with the front bezel. Be EXTRA careful when removing the bezel so that you don't warp/bend/crease it in any manner. Use generous amounts of heat and take the extra time. If the bezel does become out of shape, it will be difficult to glue it back on to the lid.
Hope that helps.
nunchukS -
I have a Question.. My cover can't stay in place any more, is there some kind of glue to fix it..?|thanks
MArtinG - Réponse
Does anyone have any idea where to source a replacement gasket?
orders - Réponse
April 30, 2016 - My Mid-2010 17" Macbook Pro Unibody (A1297) 6,2 did not look like the pictures shown in this guide. Starting at the step where the Bluetooth Cable is removed.
Where can I get a version of this LCD Replacement that matches my laptop? What other info is needed to determine?
Thanks,
Bill Fulbright
William Fulbright - Réponse
I find it quite annoying that apple uses rubber which deteriorates in warm climates. All my cables from them fall apart in about a year. Today i noticed the rubber seal around my Macbook Pro 2015 started to come loose in a corner.
Rombout Versluijs - Réponse
I have a question, more than a comment. I am following this guide and the 15” guide because I have the bezel around my screen, but I am unable to get the screws out of the bracket holding my monitor in place. I broke two T6 bits trying. Does anyone know where I can source out new screws to replace the ones I’m going to need to drill out?
Daniel Sikkema - Réponse
Nice detailed explanation. We use all Mac at our place SITARA FOODS, a home made pickle maker from India. It's pretty evident to that atleast 1 Mac break in span of 3 months. It is super expensive to replace the screens. Now after going through this guide I have asked one of my employee to but the screen on ebay along with necessary tools and fix it in office itself. We can save good money using your guide here.
Kevin - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 58
30 derniers jours : 234
Total : 71,980
