Introduction
Restore balanced sound to your laptop by replacing the left speaker.
Outils
Pièces
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Remove the following eight screws securing the lower case to the chassis:
One 3 mm Phillips screw.
Three 13.5 mm Phillips screws.
Four 3.5 mm Phillips screws.
Remove the four 10.3 mm Phillips screws securing the mid wall to the upper case.
Each connector is different, so the following steps will show you how disconnect each in detail.
Using the tip of a spudger, flip up the keyboard ribbon cable retaining flap.
Pull the keyboard ribbon cable straight out of its socket.
If the smaller connector at the right side of the keyboard ribbon cable is populated by another small black ribbon cable, remove it in a similar way to the above.
Use the flat end of a spudger to pry the left speaker connector up off the logic board.
10 autres ont terminé cette réparation.
