Introduction
This guide will show you how to replace the Mid Wall on from your laptop.
Ce dont vous avez besoin
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Remove the following eight screws securing the lower case to the chassis:
One 3 mm Phillips screw.
Three 13.5 mm Phillips screws.
Four 3.5 mm Phillips screws.
Remove the four 10.3 mm Phillips screws securing the mid wall to the upper case.
7 autres ont terminé cette réparation.
