Introduction
Wireless connectivity issues? Use this guide to replace an inoperative AirPort/Bluetooth board.
Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Remove the following screws from the optical drive side of the rear vent:
Two 10 mm T8 Torx
Two 5.2 mm Phillips
Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
29 autre(s) ont terminé cette réparation.
3 commentaires
Terrific guide; no problems, at all! Don't forget you need to add the Wi-Fi service back to the list of services:
1. Go to System Preferences → Network and click the + button to add a service.
2. Select Wi-Fi as the Interface and provide a service name.
For more info, please see http://apple.stackexchange.com/questions....
Hello!
Does anyone know where I could find this bt card but with Bt 4.0 LE in order to get handoff and continuity to work on this A1342 Macbook?
Thanks!
