Introduction
Use this guide to replace a center antenna whose cable may be worn-through by fatigue.
Ce dont vous avez besoin
Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Remove the following screws from the optical drive side of the rear vent:
Two 10 mm T8 Torx
Two 5.2 mm Phillips
Remove the single 3 mm Phillips screw securing the AirPort/Bluetooth antenna ground strap to the rear speaker.
Insert the flat end of a spudger between the thin rubber strip surrounding the front display bezel and the rear display bezel.
Use the flat end of your spudger to carefully pry the front display bezel away from the adhesive securing it to the rear display bezel.
Continue prying until the front display bezel is free along the right side of the display and behind the right clutch hinge.
Remove the two 3 mm Phillips screws securing the clutch cover to the rear display bezel.
Remove the three Phillips screws securing the center antenna and its cable to the rear display bezel.
3 autres ont terminé cette réparation.
