Aller au contenu principal
MacBook Unibody Model A1342 Lower Case Replacement
Ce dont vous avez besoin
  1. MacBook Unibody Model A1342 Lower Case Replacement, Lower Case: étape 1, image 1 de 1
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 Lower Case Replacement: étape 2, image 1 de 3 MacBook Unibody Model A1342 Lower Case Replacement: étape 2, image 2 de 3 MacBook Unibody Model A1342 Lower Case Replacement: étape 2, image 3 de 3
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
74 autres ont terminé cette réparation.
2 commentaires
Apple has a recall on this part, so you can get a replacement for an improved version free and save yourself $149.99. Check out http://www.apple.com/support/macbook-bot...
Shane - Réponse
Would the Macbook Pro back cover also fit this?
wow - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 19
30 derniers jours : 59
Total : 69,738
