Aller au contenu principal
Macintosh Classic II Back Cover Removal
Ce dont vous avez besoin
  1. Macintosh Classic II Back Cover Removal, Macintosh Classic II Back Cover Removal: étape 1, image 1 de 3 Macintosh Classic II Back Cover Removal, Macintosh Classic II Back Cover Removal: étape 1, image 2 de 3 Macintosh Classic II Back Cover Removal, Macintosh Classic II Back Cover Removal: étape 1, image 3 de 3
    • Here is one of the vintage computers in my possession. It is a Macintosh Classic II M4150. Apple considers this obsolete and " information about these products is no longer updated as of 9/1/98 "
    • On powering it up, It originally greeted me with a checkerboard pattern that quickly converted into this pattern. The checkerboard pattern is/was commonly caused by bad Ram memory. Considering the age of this computer, leaking capacitors are a strong possibility. Time to check.
    • This computer contains a CRT. That means there are some high voltages involved when working on this. Use proper CRT safety while working on it.
    • The cover is held in place by four (4) T-15 screws. Two (2) on the bottom
  2. Macintosh Classic II Back Cover Removal: étape 2, image 1 de 3 Macintosh Classic II Back Cover Removal: étape 2, image 2 de 3 Macintosh Classic II Back Cover Removal: étape 2, image 3 de 3
    • and two (2) under the top (handle)
    • The bottom ones are easy to remove
    • The top ones are a bit of a challenge due to the depth of the holes.
  3. Macintosh Classic II Back Cover Removal: étape 3, image 1 de 3 Macintosh Classic II Back Cover Removal: étape 3, image 2 de 3 Macintosh Classic II Back Cover Removal: étape 3, image 3 de 3
    • There was just not enough room to get a good grip on the driver.
    • Luckily this iFixit driver has a hole on the top part. I used a tool to gain some mechanical advantage. While applying downward pressure on the driver, turn the tool to the left to loosen the screw
    • Once loosened, the iFixit extension that came with my set, works perfectly to remove the screw,
  4. Macintosh Classic II Back Cover Removal: étape 4, image 1 de 3 Macintosh Classic II Back Cover Removal: étape 4, image 2 de 3 Macintosh Classic II Back Cover Removal: étape 4, image 3 de 3
    • Here are the four (4) screws. The two bottom screws are M4X15mm The top screws are those typical found in plastic to sheet metal joints.
    • With the screws removed the cover will slide off.
    • BEst practice is to lay it down and pull the case straight up. It may take some force due to the tight fit and years of storage etc.
  5. Macintosh Classic II Back Cover Removal: étape 5, image 1 de 3 Macintosh Classic II Back Cover Removal: étape 5, image 2 de 3 Macintosh Classic II Back Cover Removal: étape 5, image 3 de 3
    • Here is what the inside looks like.
    • Remember the High Voltage. Do not touch anything with bare hands etc. Right now it's look but don't touch
    • Power supply (Sweep Board)
    • Flyback Transformer
    • Video card
    • CRT
    • SCSI Hard drive
    • Hard drive on top with the Floppy drive on the bottom
Pièces jointes
oldturkey03
Membre depuis le 09/29/10
789 037 Réputation
119 tutoriels rédigés
Équipe
Global Fixers Membre de l'équipe Global Fixers
Community
34 membres
596 tutoriels rédigés
2 commentaires
Good job! Any pictures on replacing and resoldering the new compacitors?
Andy - Réponse
@andy77473 I should still have those, but it will have to wait till after the weekend. Really busy with some other important stuff :-)
oldturkey03 -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 21
Total : 413
