Aller au contenu principal
Macintosh IIsi Ram Replacement
Ce dont vous avez besoin
  1. Macintosh IIsi Ram Replacement, Top Case: étape 1, image 1 de 2 Macintosh IIsi Ram Replacement, Top Case: étape 1, image 2 de 2
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Macintosh IIsi Ram Replacement: étape 2, image 1 de 3 Macintosh IIsi Ram Replacement: étape 2, image 2 de 3 Macintosh IIsi Ram Replacement: étape 2, image 3 de 3
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Macintosh IIsi Ram Replacement, Ram: étape 3, image 1 de 3 Macintosh IIsi Ram Replacement, Ram: étape 3, image 2 de 3 Macintosh IIsi Ram Replacement, Ram: étape 3, image 3 de 3
    • The IIsi uses 4 30-Pin SIMMs (Installed in pairs of 2) for a maximum ram capacity of 65MB. It has 1MB soldered to the logic board as well.
    • Start with this SIMM. Push these 2 metal tabs outward, then push the ram forward. It can then be lifted out. You have to remove the SIMMs in order, starting with the one you just removed. You can then work your way through all of them.
  4. Macintosh IIsi Ram Replacement: étape 4, image 1 de 3 Macintosh IIsi Ram Replacement: étape 4, image 2 de 3 Macintosh IIsi Ram Replacement: étape 4, image 3 de 3
    • 1st Photo: The RAM Module
4 autres ont terminé cette réparation.
Chris Green
Membre depuis le 10/11/09
36 978 Réputation
49 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 528 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 2,215
