Aller au contenu principal
Mad Catz Rock Band 4 Wireless Fender Power Button Replacement
Ce dont vous avez besoin
  1. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement, Outer Casing: étape 1, image 1 de 1
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement: étape 2, image 1 de 1
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement: étape 3, image 1 de 1
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement, Power Button: étape 4, image 1 de 1
    • Using a size J1 philips head screwdriver, remove the two black 5 mm screws (circled in red) from the back of the power button component. You can identify this by the code J5-B on the component.
  5. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement: étape 5, image 1 de 1
    • Using your hands, lift the small, rectangular circuit board off and follow the connecting cords to the main circuit board.
    • Unplug the cord connected to the battery component from the main circuit board.
3 autres ont terminé cette réparation.
Catherine Lintner
Membre depuis le 09/21/16
581 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 1-1, Cagle Fall 2016 Membre de l'équipe USF Tampa, Team 1-1, Cagle Fall 2016
USFT-CAGLE-F16S1G1
4 membres
6 tutoriels rédigés
Un commentaire
I need two Rock Band 4 Home Button/Bluetooth Replacement Parts, where to locate??
My name is Robert.
Thank you in regards to whom can assist
Robert Houser Jr - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 30
Total : 3,222
