Aller au contenu principal
Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement
Ce dont vous avez besoin
  1. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement, Outer Casing: étape 1, image 1 de 1
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: étape 2, image 1 de 1
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: étape 3, image 1 de 1
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement, Sync Component: étape 4, image 1 de 1
    • Remove the two black 5 mm screws (circled in red) from the back of the power button component using a size J1 philips head screwdriver. You can identify this by the code J5-B on the component.
    • Lift the small, rectangular circuit board out and set it aside.
  5. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: étape 5, image 1 de 1
    • Locate the sync component hardware. It is a small circuit board that sits sideways with respect to the other circuit boards around it.
    • Remove the two 5mm black screws (circled in red) holding the circuit board in place using a size J1 philips head screwdriver. The component should now slide out vertically.
  6. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: étape 6, image 1 de 1
    • Follow the wires connected to the sync component back to the main circuit board. Unplug the component from the main circuit board.
2 autres ont terminé cette réparation.
Hollynn Ricker
Membre depuis le 09/28/16
451 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-1, Cagle Fall 2016 Membre de l'équipe USF Tampa, Team 1-1, Cagle Fall 2016
USFT-CAGLE-F16S1G1
4 membres
6 tutoriels rédigés
Un commentaire
How do I replace the sync wire? Where can I purchase a new sync component?
Ange - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 32
Total : 2,307
