Introduction
Use this as a guide to repair the USB cable when its internal connection to the controller is damaged.
Ce dont vous avez besoin
Use tweezers to completely remove the sticker from the rear of controller.
Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
Orient the motherboard so that the side with the rubber buttons is facing up.
Remove the rubber buttons by pulling up on the on the rubber pad on the points where the rubber cylinders that poke through the motherboard are so that each cylinder slides out nicely.
To reassemble your device, follow the instructions starting from step eight in reverse order.
For specific instructions on soldering, check out the iFixit soldering guide.
